Question about Samsung TV Remote Control
I have a series 8000 flat screen with an RF remote. IC: 649E-SWPZ01RX. New batteries but the buttons don't light up. Before it quit I noticed periods when it would light up when it was sitting on the table with no one near it.
My samsung GT-19020T IC : 649E FCC ID : A3LG
Looks like your phones setup and run drives are gone need a new motherboard for the phone
Feb 07, 2013 | Cell Phones
Tip
How to see if your remote control is actually working
For remotes which use an IR connection you can see if they are transmitting using this trick. An IR type of remote will have one or two LED's on the front end. If it doesn't, than it may be an RF type of remote - this tip will not work for those.
Get some electronic device which can view a live image on a screen. A cell phone camera, digital camera, digital video camera, and (I think) even a web-cam will work. If you're using a digital (still) camera, you don't need to take a picture as long as you see a live image on the screen of whatever the camera is pointing at. Take your remote and find the LED on the front end. There may be one or two. (If there's two, one actually isn't an LED, but that's not too important.) Point the front of the remote at the camera (LED's facing the camera), and press buttons. You should see the LED's light up in the live image. While these LED's normally produce light which the human eye can't see, digital image sensors can, and they change this invisible light to light we can see on the screen. (Cool right?) So, if your remote is working then you'll see the LED light up on the display. (To make sure your camera is actually working as I am suggesting here, find a remote which you know does work and try it.)
The LED should light up for every button pressed. If one button doesn't make the LED glow, you may have a bad button - try pressing it firmly. Buttons can wear out. The image of the LED may appear steady or it may pulse or blink on the viewscreen - this is normal.
If the LED doesn't light up, and you know your camera works like this (you've checked a good remote), try new batteries - that solves most problems. Check the battery contacts in the remote - if they're corroded, (white flaky stuff caked on, looks like dried up salt) - you can clean the contacts with a solution of water and baking soda and a Q-Tip. Use a knife to remove any large chunks. Also, some fine sand paper works too. Both the flat contacts and the springs need to be cleaned. Wash any tools (and hands) with soap and water afterwards. Handle corroded batteries as little as possible - or better yet, use gloves.
If you have good batteries and the contacts are clean, and the LED is not lighting up - it's pooched. Try getting a replacement from the manufacturer (call or email/write them), or use a universal remote.
If you've found this tip helpful, please check the box below. =8o)
#Remote #RemoteControl #IRRemote
on Jul 08, 2014 | Televison & Video
8 solder ic number for tcl falt tv
Can you please check for any jammed buttons on the remote and/or control panel? Try switching on the TV manually, while removing the batteries from the remote. If you notice same problem, the area to be looked into is around the system control area: like dry solder, leaky/dry capacitors and this should be done only by a qualified service technician.
Aug 25, 2012 | Televison & Video
My sansung remote quite working, replacement universal remote was programed to the tv but the tv will still not respond. What's next?
You likely don't need a new remote. Certainly not a Universal.
Samsung remotes for LED / LCD TVs are generally RF, not IR.
Most Universal remotes do not generate RF signals, so disregard advice about codes for Universals.
Try this:
First, fresh batteries, and clean battery contacts if needed.
Then, Try Pairing procedure:
  1. TV off
  2. Bring remote within 3 feet of TV
  3. Push Pairing button (Paper Clip or other pointed object in button hole)
  4. Turn on TV
  5. Should be paired. Try remote channel or other buttons.
  6. If not, try 2 more times.
  7. If still not working, push RESET button first and repeat Pairing.
Please rate if Helpful.
Good Luck !!
Jun 18, 2011 | Samsung TV Remote Control
What is the difference between RMC30C1 and RMC30C2
They are pretty much the same except the C1 is designed for the 9000 series TVs and has a twin screen button whereas the C2 is for the 7000 / 8000 series Samsung HDTVs and has no twin button.
Apr 29, 2011 | Samsung RMC30C2 Remote Control
My Harmony 890 won't exit USB mode. I made some changes in the software, updated the remote, and when I unplug the USB cable, the remote continues to think it is still connected to USB, until I remove the...
  1. Ensure your are using the latest version of the Harmony Client Software. (Pairing is done in the software and the newest version is needed) 7.7.0 if you dont have it, see below
  2. Ensure that the `Control Devices` are assigned correctly to the Remote & Extender
  3. Update the Firmware in the extender and remote
  4. Update the configuration
  5. Test the remote
Did this fix the problem? If no, see below
Do the `Status` and `RF` lights on the RF Wireless Extender blink when you start an activity or press buttons in a device assigned to the RF Wireless Extender?
if no, Please try the following:
  1. Plug the RF Wireless Extender in AC power only
  2. Reset the RF Wireless Extender by holding down the `Connect` button on the RF Wireless Extender until the `Status` and `RF` lights start blinking back and forth. (This process takes longer than 60 seconds, and the `Connect` button will need to be held down for the entire time)
  3. Once the `Status` and `RF` lights start blinking, let go of `Connect` and unplug the RF Extender from AC power
  4. Upgrade the firmware on the Extender
  5. Update the configuration
  6. Test the remote
if no, contact logitech.
FIRMWARE:
1. Log into the Logitech Harmony Remote Software on your computer
2. Click on the Downloads button at the top-right corner of your screen
3. Click on the Firmware button. Follow the onscreen instructions to upgrade the firmware on your Harmony remote
4. Once the firmware upgrade is complete, click on the Update Remote button
5. Test your remote.
NEW SOFTWARE:
1. Go to www.logitech.com.
2. Hold your mouse over the Support Tab.
3. Scroll down to Product Support.
4. Choose Harmony Remotes.
5. Choose your brand of Harmony Remotes.
6. Click on Downloads on the right side of the screen.
7. Choose your Operation System (OS)
8. Click on the Download Software button on the bottom of the page.
9. Choose Run.
10. When the software is completed downloading and installing, please open the software.
11. Once the software is open, click on Update Remote.
12. Follow the on screen steps to complete the update.
Jan 05, 2010 | Logitech Harmony 880 LCD Remote Control
Braun 7526 not charging the + light wont turn on? how can i fix this?
In your case, it's hard to know exactly what might be wrong without more information. Was the shaver perfectly fine and then all of the sudden won't turn on? Or was the shaver working for shorter and shorter periods over time and then just quit? Was it exposed to undue heat, such as left in a car or in a place that wasn't air conditioned in the hot summer?
Although the batteries in these shavers are fairly robust, if fully discharged and not used for a long while, it might be that they've got a "low level memory" and will need replacing. If you are handy, you could disassemble the shaver and replace the batteries. They are NiMh AA flat top batteries that you can buy on websites like onlybatteries.com. If you're handing with soldering, you can replace them yourself. If you're unsure about that, you can buy the batteries along with the circuit board as a complete unit that drops right into place. Shaveroutlet.com sells these.
Another thing is that if the shaver was dropped, there's a chance that a metal connector part has come loose and so the shaver won't function. Taking it apart, you can see if this is the case.
The Braun 7000 series are rather old at this point, so sending it off for repair is kind of out of the question, as the costs involved would be more than if you bought another shaver. If you're not wanting to spend the big $$ on the new 9000 series shavers, find a new old stock 8000 series shaver (they are better made than the 7000 series). You can search on "that auction site" and you'll find quite a few Braun 8000 (or 360) series shavers available for sale.
Sep 25, 2009 | Braun Syncro 7526 Electric Shaver
Need the remote code for Samsung 55" led tv 8000 series
You will not have any luck, The Screen only uses RF for control. As far as I know there is no IR receiver on the unit or any RS232!! A nightmare for integrating this product into universal control systems.
Jul 31, 2009 | Samsung UN55B8000 55 in. LCD HDTV
The only screen I get is5/1 nothing else on my denon rc-8000 remote. I can not get any other funtions to work. Not even the back light. Can anybody help? PLEASE
Dear granggreen....Patrick here....
Even if you have performed these functions I want you to do them again. Remove the battery cover, remove the re-chargeable battery and it's blocks that hold it in position. Install new AA batterys, press the RE-SET BUTTON and hold for three seconds. If these steps prove nothing my instinks say that one or all Joy Stick discs are flat. Surgery is needed.
Patrick
Jul 02, 2009 | Denon RC-8000 LCD Touchscreen Remote...
Logitech Harmony 890
Pull the battery out and re-insert it, also update the remote firmware
Aug 12, 2007 | Logitech Harmony 890 LCD Remote Control
Samsung TV Remote Control Logo
63 people viewed this question
Henry  Thomas
Henry Thomas
