Question about KitchenAid Dishwashers
Door open error - KitchenAid Dishwashers
  • 640 Answers
Whats the model number?I think thr door switch may be bad.
Posted on Aug 06, 2008
I have a daewoo washing machine dwd-g20dl showing error code LE
LE Washing machine door opening error
The washing machine or washer dryer door has been detected as open or unlocked.
·Close the door!
·Check the door lock switch
·Check the door latch
·Check PCB
Jul 09, 2014 | Daewoo Washing Machines
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
I have 2 lift master garage door openers that are producing errors when you hit the buttons to open 2 different doors. 1. I get error code 11 (sensor blocked or miswired)-there is nothing blocking...
If your garage door is up, and you break the beam (by walking through it, for example), you will get the "SENSOR WIRING INTERMITTENT CONNECTION ERROR CODE 1-4 SEE USER MANUAL". This is normal. Both of my Liftmaster 8550 openers do this. It's misleading, but this is what I've found to cause this error.
Oct 29, 2013 | liftmaster Lift Master 377LM 376LM 315 MHz...
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Error code F26
This error code indicates that the door needs to be opened and closed.
The F26 code may appear the first time you try to use the washer. Open and close the door to clear the display.
The F26 code may also appear if the washer has run three cycles without the door being opened. Open and close the door to clear the display.
If opening and closing the door does not remove the error display, press Pause/Cancel twice
Oct 22, 2011 | Whirlpool WFW9200S Front Load Washer
Code 3514 keeps coming one
Error: "Rear access door open" (3514)
How do I resolve the error message "Rear access door open" (error code 3514)
To clear the "Rear access door open" error message:
  1. Remove the rear access door from the printer.
  2. Reinstall the rear access door on the printer and verify that both latches are securely engaged.
  3. Unplug the AC adapter from the printer.
  4. Plug the AC adapter back into the printer.
  5. Wait for the printer to initialize.
  6. Verify that the error has cleared.
Mar 18, 2011 | Kodak Office Equipment & Supplies
What does error code F26 mean? The washer will fill with water, work for about 5 minutes and then post error F26 and stop working. Where do I find the error codes?
If the door has not been opened for 3 consecutive cycles or the door switch is open while the door is locked for more than 5 seconds.
Possible Causes/Procedure
-Door not opened during 3 consecutive cycles.
1. Open and close the door.
2. Verify CCU operation by running a Diagnostic Test or any cycle.
-Door switch open while door is locked.
1. Push the door and check if it is completely closed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.$$$$
May 05, 2010 | Kenmore HE2 Plus Front Load Washer
'user door open' error -where is the 'user door'? We have opened and closed all the parts we can find that open and close.
the door you open to put the cartridge. If the door is closed and you still get the message, it means the door is not activating the microswitch when the door is closed. There must be a tab on the door which presses the switch.
May 22, 2009 | Dell 1815dn All-In-One Laser Printer
Kodak i640 communication Error
I Have had the same problem. I changed the power supply an the error was never detected
Feb 08, 2007 | Kodak i640 Path-Through Scanner
Dishwashers Logo
Top KitchenAid Dishwashers Experts
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
