Question about Makita 10" Miter Saw LS1030N
While replacing the blade, the spring on the safety cover came off. I can`t figure how it goes, to place it again on its place. Any advice? Thanks Emilio
    Novelist:
  • 157 Answers
Hello. Here is the link to the Parts Breakdown of your unit. It should show what you need to know to reassemble your saw. If not, use the contact information to speak to customer service and they should be able to assist. If this is helpful, please rate it a four-thumbs up, Thank You.
http://www.makita.com/en-us/Modules/Tools/ToolSupport.aspx?ID=370
Posted on Apr 05, 2011
  • Traindoctor May 26, 2011
    I found the diagram to be spot on and was able to reasemble safety guard return spring in correct position, thankyou : frank
I have a Porter Cable biscuit jointer, model 527 and I'm an amateur woodworker, NOT a mechanic. I can't locate my owner's manual on this tool and have the smaller blade in the tool currently. ...
Model 557 is shipped with a 4" diameter blade installed. This blade is used
for all operations except for the "FF" biscuit. The "FF" biscuit requires that
the 2" blade (furnished with the tool), be installed as follows:
DISCONNECT TOOL FROM POWER SOURCE.
1. Loosen four blade cover retaining screws (A) Fig. 10, and remove blade
cover.
2. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
hand until spindle lock engages.
3. Continue to hold spindle lock button while using the 5/32" hex wrench
(furnished with tool), to remove blade retaining bolt and flange, (by
rotating counterclockwise).
4. Remove blade and store in a safe place for future use.
5. Place 2" diameter blade (furnished with tool), onto blade mounting
flange (orient with teeth facing in same direction as directional arrow
cast in housing, see Fig. 14).
6. Position blade retaining flange (flat side out), to spindle, insert blade bolt
and rotate clockwise until hand-tight.
7. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
8. Continue to hold spindle lock button while using the hex wrench
(furnished with tool), to tighten blade retaining bolt securely, (by rotating
clockwise).
9. Rotate the "quick set" depth adjusting turret (A) Fig. 12, to the "FF"
position.
10. Lift safety lever (A) Fig. 13, fully retract the plunge mechanism, and
reposition the safety lever as shown in Fig. 14. Slowly release pressure
on plunge mechanism.
11. Reposition blade cover plate to tool, and secure in place with the four
retaining screws (removed in step 1).
DO NOT OPERATE TOOL WITHOUT BLADE COVER INSTALLED
Sep 06, 2017 | Masonry Tools
Tip
How to change a mitre saw blade
When changing the blade on your mitre saw the first step is to unplug the tool for safety reasons. DO NOT disassembly the safety cover, there is a bolt on the housing that when loosened allows the cover to be moved away from the blade to expose the spindle bolt. After moving the ASSEMBLY away from the blade turn the blade by hand slowly while pushing on the spindle lock to stop rotation. Loosen the blade bolt (usually left hand thread) and place the parts in the order removed, e.g. blade bolt outer flange, blade spacer if used. Reinstall blade noting the rotation of the teeth and replace parts in reverse order. After installation check for rotation by carefully turning the blade by hand and replace safety cover to its original position and tighten bolt.
on Jul 04, 2011 | Saws
How do I assemble the blade guard for my Makita Miter Saw Model LS1030? I accidentally disassembled the guard it when changing to a new saw blade. I cant figure out how to get the tension spring back in...
lay the spring into the plastic safety cover, you will see a catch for one portion of the spring, the cover plate goes over it and there is a tab on it to catch the loose end and then the center plate which screws on to hold everything in place, check by turning the plate that holds it onto the saw for free movement. You can go to makitausa.com and in the header area on the right type in your model number ls1030n and you can download or look at a breakdown to see what I am talking about. Let me know if you need more assistance, just found your question.
May 01, 2011 | Makita 10" Miter Saw LS1030N
Concept MS100 mitre saw blade guard dillema.
I have changed the blade a few times, There is no need to remove the spring, etc. All you do is remove the bolt holding the guard and rotate it counter clockwise and it exposes the blade.
I am looking for parts for this saw. Anyone know where to get them?
Jul 06, 2010 | Makita 10" Dual Bevel Sliding Compound...
Bought new last year the A-5 and seems like already after light use, is not cutting as smooth. Tried to change the blades figuring they were dull but still have the problem. The do seem to chatter a bit....
before adjusting spring pressure check the two screws either side of the hinge *** make sure they are tight and also check to see if this component has pulled away from the body.
Apr 30, 2010 | Oster Golden A5 2-Speed Universal Motor...
Food processor not working
check cover safety tab possible broken or faulty switch
Aug 29, 2017 | KitchenAid KFP740 Food Processor
Replacing the blade guard spring
there is a hold in the lower guard for the loop and the other end wraps around the guard slightly and there is a hole in the back of the upper guard. You can go to Milwaukeetool.com and download a breakdown for the tool Also when you have the blade off I would try using compressed air to clean the area and spray some lubricant on the hub to lubricate. The guard should "snap" back when done sawing. Let me know if you need more help
Mar 24, 2010 | Milwaukee 6378 Saw Circ 8 1/4 15A Worm
Panosonic NN-S525BF Latch Spring Broken
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Jan 24, 2009 | Panasonic NN-S254BF Microwave Oven
Replacing the saw blade
my husband had trouble replacing the spring that goes in the plastic safety cover....he just eliminated the spring and it works just fine...thankyou for responding....L Martinez
Sep 27, 2008 | Makita 10" Miter Saw LS1030N
How do I replace the Cleaning Brush for the drum?????
why in the world are you replaceing the brush? In 25 years of copiers, i,ve never had to replce a brush. If its streaking on the copy, its the blade thats bad. only reason to replace a brush is if its broke,cause of a clog. just vacumm it out.
Jan 31, 2008 | Panasonic FP-7735 Black and White Copier
Makita 10" Miter Saw LS1030N Logo
330 people viewed this question
Top Makita Saws Experts
ray gallant
Are you a Makita Saw Expert? Answer questions, earn points and help others
