Question about U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613)
Can't access webpage outside of my USR5461
I set up apache webserver on my XP with port 8090.
1) When I enter 'http://localhost:8090/' into the IE -> 'It works!'
2) When I enter 'http://192.168.2.30:8090/' into the IE -> 'It works!' (I set this IP for that PC before - so the router give the same IP for it always)
3) When I enter 'http://:8090/' into the IE -> 'The page cannot be displayed'!
4) I can reach the admin page of the router with 'http://'
5) I set port forwarding as
TCP 8090 to 8090 192.168.2.30 8090 to 8090
UDP 8090 to 8090 192.168.2.30 8090 to 8090
What is the problem??? (I'm connecting via cable)
Does anybody can help me please???
Did you get this resolved. I have the same problem, I get the router's login page when I try to access from outside.
Posted on Aug 24, 2008
I can't open my skype
Dear Zeleykha,
Greetings.. hope you would be fine doing well..
For your problem I would like to suggest:
1 - Try Reinstalling Skype by first removing it from Add Remove Programs (Win-XP) and Program & Features (Win7-8) in Control panel and then installing it.
2 - If you have any webserver technology installed like xampp and wampp may be they are counterfeiting. Solution is you need to change skype connecting ports from options, but first stop apache services then do this.
Regards
Apr 09, 2014 | Computers & Internet
Cannot contect to apache through wrt54g
Highly unlikely. That would block all HTTP sites that use Apache. Even then, how would they distinguish one web server from another type. Your error is based on a specific site, or all internet if Comcast does not show their splash page saying it can't reach a specific site.
Dec 04, 2012 | Linksys Wireless-G WRT54G Router
I am trying to use Joomla on my own computer and can not access the ''local host'', I have installed Xampp, am using windows vista, have a router between me and the internet.
To access "localhost" you must have a web server ( IIS or Apache - IIS is the simplest and is found in add/remove programs, Windows components usually) running on the PC that Joomla is installed on. You must also use http://localhost for it to work. Localhost means you are only doing a loopback to your own pc for testing purposes. By default most web servers run on port 80 if the port is changed then you must use "http://localhost:port". Depending on how your network is set up - If you have a router or firewall you may also have to "open" or do a port forward to port 80 for the software to see the server holding the Joomla pages and also allow internet access as a server. First try the default web page the server has usually default.htm or index.htm as http://localhost/default.htm etc, if it loads then you know localhost is functioning, then try the Joomla page you want to see using it in place of default.htm. If no page loads at the start - then check your Apache(Xampp) configuration file to be sure it is set up and working properly - if I recall it is hhtp.conf open it with notepad to configure and save as "all files" not text. You might also check your Joomla configuration options as well to be sure the correct port and location are used for serving pages.
Nov 04, 2009 | Microsoft Windows Vista Home Premium with...
I now every thing about htaccess
htaccess is a simple text file that resides on a web server. It's called htaccess because the file is named ".htaccess" (with the period in front).
The purpose of the file is to allow the manager of the website to change the way a website functions by changing various configuration options for the software that runs the website (AKA, the webserver software. This software is called "Apache").
The file contains commands for the webserver software. These commands specify the new values for the configuration options.
There is too much detail about htaccess to go into here. The best way to learn about it is to read a tutorial like this one: http://httpd.apache.org/docs/1.3/howto/htaccess.html or to start by knowing what configuration change you want to make to the webserver software and then consulting the documentation in order to learn whether you can change that via htaccess and then how to do it.
Apr 05, 2009 | Apache HTTP Server
My you tube dont work
Go to Start > Control Panel > Windows Firewall> Exceptions> Click on add port.
Call it port 80.
In port number type in 80.
Then click on OK.
Then close all the windows.
Basically on the computer that is running apache (Server), YouTube is unblocking the port called 80. On some systems mainly XP home we found that port 80 was always blocked. Even though localhost worked, computers connecting to it would get an connection error. Also, if you have a 3rd party firewall, you have to unblock YouTube. If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 08, 2009 | Toshiba Satellite A100-S8111TD Notebook
I cant open youtube
Call it port 80.
Then click on OK.
Thanks, Joe
Mar 08, 2009 | Intel Pentum 4 3.2Ghz System (SYP32) PC...
Setting WebServer On Linux
Hello,You can try this http://www.goresellers.com/ site's more DNS ,here you can make your self as a reseller and get your expected DNS are very very cheap rate, also you got an internet business opportunity ,visit this site for more details.
Oct 18, 2008 | Computers & Internet
How to set a folder with small program to run on linux+apache
Dear Rajiv
First make sure that your Apache server is running properly.
For this type http://localhost and see the result.
If you want to test PHP you can create a php test file by yourself.
Goto the www folder in apache director. create a file , name it anything.php. Edit the file and simply write "phpinfo()" without quotes . check the output.
It means that your apache server is fully capable of PHP scripting.
Cheers, Parveen
Jan 25, 2008 | Computers & Internet
Port Forwarding for Apache Server
Hi Robmoll,
Let's get a little bit more in detail. I'm doing the same exact thing you are trying to do with a D-Link DI-624 and I'm using NO-IP instead of DynDNS. I'd like to ask you a question, if I may, what are you actually seeing now using port 80 and how did you disable it? Can you connect another PC to the same router (making a small Home Network) and test locally your Apache and eventually your web-page by typing something like this "http://192.168.0.101/"? Are you already able to see your router from the "outside" trough port 8080? Are you specifying your "private" IP in the port forwarding setting of your router? Do you mind showing a snapshot of your port forwarding settings? Here is mine; you see two different IP's because there are two PC connected.
Regards,
GiBi
Oct 26, 2007 | Actiontec GT704WG Wireless Router...
How do I port forward 80 and do apache home website on verizon westell
As I had mentioned earlier to another gentleman, who had a similar issue; those SOHO routers and modem/routers have issues with their advanced functionalities which includes port forwarding. The first thing you must do is - Make sure 'block anonymous internet requests', is disabled in the router's settings - Go to the following website http://www.t1shopper.com/tools/port-scanner/ - Try to see if there is a service running on port 80 If the port is open (which I believe would be a least possibility), there is something else we are missing here. Get back to me with further observations Good Luck
May 16, 2007 | Westell Wirespeed VersaLink...
U.S. Robotics USRobotics USR5461 Wireless MAXg Router wireless router (S4199613) Logo
197 people viewed this question
Top U.S. Robotics Computers & Internet Experts
Michael Galve
Michael Galve
Aris C.
Aris C.
Are you an U.S. Robotics Computer and Internet Expert? Answer questions, earn points and help others
