Question about RCA P52926 52" Rear Projection Television
My screen on my big screen rca tv is curving in like it it has a bend in it. What could be wrong
  • 1,476 Answers
Tim_perkins4
Your convergence system has failed. I have a tip at http://www.fixya.com/support/r4220499-change_projection_tv_convergence_ics which will solve your problem.
Thanks for using FixYa and for the great rating.
hardrocko
Posted on Apr 05, 2011
I have an older model rca rear projection tv. The problem with the tv is that the picture bends into curve after about 5 minutes after it has been turned on. Please help.
Check the convergence IC's for cold solders, check for leaking capacitors in the area. Check the voltage regulator with a Variac.
Usually these sets just need the 2 big convergence IC's replaced with new ones. Clean all 3 picture tube lenses, mirror and screen. Get the original RCA remote that came with the set and MANUALLY align the convergence.
Rarely the bow on the bottom of the screen is not repairable.
Jul 18, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Turned on my RCA P46924 today and played fine for 5 min. then picture curved and turned to 3 different colors seperated on same screen. Turned TV off and now will not turn back on. Please help?
Ur tv have convergence problems,before ur convengence ICS totally went dead.U must have tools like soldering iron,solders,solder witch,and know how to solders to fix this problems ur self.Must replaced 2 convergence ICS,and some or all it resistors.Tries websites like Tv repair world.com,Tvrepairkits.com to buy a convergence kit to repair it ur self.The shop will cost u $300-350 for parts and labors.
Apr 28, 2010 | RCA P46924 46" Rear Projection Television
60 INC RCA PROJECTION CURVED PIC. TOP BOTTOM
This problem is caused by a faulty Convergence amp. This amp keeps all three colors aligned together and square on the screen. It could also be the power supply section that supplies power to this amp.
A local TV shop should be able to repair this for you for about $350
Jan 06, 2010 | RCA Televison & Video
52 inch RCA Home theater-Sound is distorted/scratchy
I unplugged the tv for 5 minutes. When I turned it back on, I had sound!
Aug 01, 2009 | RCA 32V420T 32" TV
Rca big screen model # P52939
I had same problem on rca big screen M #p46734ba it was hi voltage splitter the part # for mine is 40431-090 GE/RCA splitter it was $36. online
Mar 12, 2009 | RCA Televison & Video
Projection on the screen is too large so the pic is cut off
using the right or left arrows should change your screen sizes 16.9 4.3 and so on
Jan 11, 2009 | RCA D52W19 52" Rear Projection Television
I HAVE A RCA 52 INCH SCREEN WHILE I WAS WATCHING IT THE SCREEN WENT TO A CURVE SHAPE AND THE COLORS ARE GHOSTING. MODEL #R52WH74.WHATS WRONG
you have a very common tv projector problem bad convergence
you need stk ic big chips on large silver heat sink.cost to fix from tv shop is around 250 to 400 depends who you get part are only 45.00 dollars
I hope this helps good luck
doctor video leadingedgelectronics since 1987
Apr 29, 2008 | Televison & Video
RCA 52inch TV
If the screen control for the green picture tube is set too high, then the colors will be greenish, there will be green where there should be black and there will be fine curved lines (retrace lines) in the picture. If you feel confident then you can open the set and look for the focus block which has the 3 focus and 3 screen controls. One row is labeled Screen and the green control will be the center one. Try turning that control down a little and see is the green background and curved lines go away. If they do not go away then there is something more serious wrong. If you do not have experience working on projection sets then allow a qualified tech to handle it for you.
Jul 13, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA P52926 52" Rear Projection Television Logo
53 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
