Question about Sony Playstation 3 (PS3) Console
I have audio but no video with my HDMI connection
    Scholar:
  • 105 Answers
You may have the resolution on the PS3 set higher (say 1080p) then what your TV supports (1080i or 720p). Use the Yellow/Red/White cable that came with the PS3 to connect to the TV. Go to that input and check the resolution. Start at a lower resolution and check the HDMI input. If the TV does support 1080p, try a different/better HDMI cable.
Posted on Apr 05, 2011
I NEED SONY BRAVIA T32 FULL MANUAL...how to conect to computer and camera
Hello there,
Here is the link to the full manual:
http://support.sony-asia.com.edgesuite.net/consumer/IM/4110401121.pdf
Before connecting your devices...
The signals that enter the TV and connected devices will need to be output in the correct format using the suitable connections. Below are the different types of video connectors. When connecting the TV, use the inputs that are available on your devices that provide the best video performance.
Video performance level Name Aspect Signal transmitted Separate audio connection required arrw.jpg HDMI cnn_hdmi.jpg Picture + Sound No DVI*1 cnn_dvi.jpg Picture Yes
L-AUDIO-R Component video cnn_component.jpg Picture S-Video cnn_s_video.jpg Picture Composite video cnn_composite.jpg Picture RF/Coaxial cnn_coaxial.jpg Picture + Sound No
*1 If the equipment has a DVI jack and not an HDMI jack, connect the DVI jack to the HDMI IN (with HDMI-to-DVI cable and/or adapter jack), and connect the audio jack to the AUDIO IN (L/R) jacks of HDMI IN. (The DVI connector is for video signals only) To enjoy the best visual experience with your system, it is preferable to connect your best devices with the highest quality connections available. For example: your Blu-Ray Disc player or HD Set Top Box with HDMI, followed by your DVD player with Component, then your Video Cassette Recorder with S-video etc.Note: The quality of the picture also strongly depends on the quality of the cable used.
HDMI The High-Definition Multimedia Interface (HDMI) is an all-digital audio/video interface capable of transmitting high definition video and audio signals. HDMI provides an interface between any compatible digital audio/video source, such as a set-top box, a DVD player, a PC, a video game system, or an AV receiver and a compatible digital audio and/or video monitor, such as a digital television (DTV). DVI The Digital Visual Interface is capable of transmitting high definition video, but does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA). It is possible to connect an HDMI device to a DVI device using a HDMI to DVI adapter. Component video Component video is an analogue connection. It is capable of transmitting high definition signals. Component does not transmit sound. You will need to use the audio connectors of your device (usually Optical/Coaxial digital, or RCA) S-Video Separate video, abbreviated S-Video and also known as Y/C is an analogue video signal that carries the video data as two separate signals (brightness and colour), unlike composite video which carries the entire set of signals in one signal line. S-Video, as most commonly implemented, carries standard definition video. It does not carry audio on the same cable. Composite video Composite video is an analogue video (no sound) format. This is the connector you should use if you do not have any other connector available, in terms of quality. RF/Coaxial RF Coaxial Cable connection is used for transferring television signals (audio and video) originating from an antenna or cable box to a Television.
Hope this was helpful to you.
Goodluck
Elect_Comp
Aug 10, 2011 | Televison & Video
Hdmi will not work only use of component cables will.
Hello
The HDMI[1] input on your TV receives digital audio
and uncompressed digital video and audio from an
HDMI device or uncompressed digital video from a
DVI[2] device.
This input is designed to accept HDCP[3] program
material in digital form from EIA/CEA-861/861B-
compliant[4] consumer electronic devices (such as a settop
box or DVD player with HDMI or DVI output).
The HDMI input is designed for best performance
with 1080i high-definition video signals, but will also
accept and display 480i, 480p, and 720p signals.
To connect an HDMI device, you will need:
• one HDMI cable (type A connector)
For proper operation, it is recommended that you use
a short HDMI cable. You should not encounter
difficulty if you use an HDMI cable shorter than 16.4
ft (5m).
HDMI cable transfers both video and audio.
Separate analog audio cables are not required (see
illustration below). Some CDVs (video CDs) may
not output digital audio signals. In that case, you
may hear sound by connecting analog audio cables.
However, if you connect analog audio cables with
this connection, the HDMI terminal on the TV will
not receive the HDMI digital audio signal and you
will hear analog audio only.
To ensure that the HDMI or DVI device is reset
properly, it is recommended that you follow
these procedures:
• When turning on your electronic components,
turn on the TV first, and then the HDMI or
DVI device.
• When turning off your electronic components,
turn off the HDMI or DVI device first, and
then the TV.
To connect a DVI device, you will need:
• one HDMI-to-DVI adapter cable
(HDMI type A connector)
For proper operation, the length of an HDMI-to-
DVI adapter cable should not exceed 9.8 ft (3m).
The recommended length is 6.6 ft (2m).
• one pair of standard analog audio cables
OK
Dec 16, 2010 | Toshiba 30HF84 30" TV
Connect my xbox on reicever
If your xbox has HDMI connector then you HDMI cable to connect it to the receiver and another HDMI cable to connect receiver to the TV. Receiver should support both video and audio over HDMI.
If your xbox doesn't have HDMI, connect the video directly to your TV using whatever connector/cable is available (in terms of quality from best to worst: HDMI, component, s-video/scart, composite).
Then connect audio to the receiver via optical spdif cable.
Jan 29, 2010 | Yamaha RX-V463 Receiver
How do i hook up to a tv
It depends on what connections does your TV have and what video sources you want to connect to the receiver.
This receiver doesn't have any video conversion capability. What you connect to HDMI-in of receiver, will be only on the HDMI-out. What you connect to component-in, will be only on component-out (and NOT on HDMI-out or anything else). So it doesn't make sense to connect any source via receiver other than HDMI - in such case, connect just audio (either spdif optical/coax or analog stereo) to the receiver and connect the video directly to TV.
For HDMI you can connect it via receiver, because this will carry both audio and video. Connect your sources (DVD player, sat box) to the receiver's HDMI-in 1-4 and connect HDMI-out to your TV.
Dec 27, 2009 | Yamaha Rx-v465/rxv465 Home Theater...
No video from RX-V863
This reciever might not upconvert component or composite to hdmi, which means if you have anything but hdmi hooked up you will not see it. Check your manual for what all the reciver will ouput.
Jul 24, 2009 | Yamaha RX-V863 Receiver
Right cables for connecting devices
You have connected from PC to TV right???
1.To get the video you have to connect to TV
2.Please take a separate cables for to listen audio and to watch video,
for audio connect cables from DVD Player to Home Theater you can listen the audio
for video please connect the HDMI video to TV Where You can enjoy both.
Jan 07, 2009 | Audio Players & Recorders
Having problems with HDMI connection from COMCAST Motarola HD Dual TUNER DVR HDMI DCH6416 to Panosonic Home Theater system SA-PT660 to AKAI LCD HDTV. There is only one HDMI Output on the COMCAST box; one...
Connect the HDMI outputs on your various components to the HDMI inputs on your receiver. Connect the HDMI output on the receiver to the input on your TV. HDMI incorporates digital audio, so no need to buy optical audio cables. If your receiver does not have HDMI inputs for all your components, you will need to make a choice. HDMI = Best, component video + optical audio = second best, S-video+ optical audio = third best
Jan 01, 2009 | Onkyo TX-SR606 Receiver
Connecting my wii to my home theater
  1. Connect your set-top box HDMI output to the Xbox One HDMI input.
  2. Connect the Xbox One HDMI output to your A/V HDMI input.
  3. Connect your A/V HDMI output to the HDMI input on your TV.
  4. Notes
  5. This option requires that all devices support audio over HDMI.
  6. Surround sound from your set-top box will not be passed through the Xbox One.
  7. When you perform this kind of basic setup with an A/V receiver, you're passing both audio and video through another device. Depending on your equipment, there's a small risk of audio or video lag.
  8. Connect your set-top box HDMI output to the Xbox One HDMI input.
  9. Connect the Xbox One HDMI output to the HDMI input on your TV.
  10. Connect the audio output from the TV to the audio input on the sound bar using either HDMI or optical S/PDIF cables.
Nov 09, 2017 | Electronics - Others
Sony Playstation 3 (PS3) Console Logo
65 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
