Question about Dishwashers
DISCONNECT A DISHWASHER - Dishwashers
  • 640 Answers
What do you need help on?What the make and model?Whats the problem?
Posted on Aug 06, 2008
How do you pull out the dishwasher - have hideous ants & need to put diatomaceous earth behind it.
  • Turn off and disconnect the water line from under your sink.
  • Disconnect the drain line from either the air gap or the garbage disposal.
  • If the dishwasher power cord is plugged into a receptacle you will need to unplug that.
  • If it is hard wired into the dishwasher you will need to turn the power off at your house breaker. Please be careful and make sure you have the power truly off by confirming with your dishwasher. Set it to a cycle and make sure its dead.
  • There is an access panel at the bottom of your dishwasher to locate the junction box where the power is connected.
  • (If you have enough cord/drain hose/ water supply inlet hose, you sometimes can just pull the dishwasher straight out. Without having to disconnect anything. )
  • You will need to remove the access panel usually by either two 1/4 inch screws or a phillips some of the new access panels use plastic keepers just turn those from the vertical position to a horizontal position and they just pop right out. Now you can access the junction box where the power goes in.
  • You need to remove the mounting screws at the top of the dishwasher under the counter.
  • The dishwasher should be ready to pull straight out.
I hope this helps
Apr 12, 2015 | Dishwashers
Whirlpool dishwasher door falls open fast when opening. plastic part came off, but don't know where it is from
remove the bottom access covers on the bottom of dishwasher. turn on the dishwasher with water valve in off position so you can here the motor running,while its on, find the breaker and turn off power.you will here motor stop. disconnect power wires from power box on right hand side,then disconnect water line open the dishwasher door and at the top remove screws holding dishwasher in place. pull dishwasher out from bottom.you may have to adjust bottom adjustable screw legs. pull it out and check sides where springs are for the door to open and close. it may have came loose.
Feb 27, 2013 | Whirlpool Gold GU2275XTV Builtin...
Our sink and garbage disposal was clogged up. We got the sink unclogged, but the dishwasher had dirty water in the bottom and won't drain.
Your dishwasher drains into the garbage disposal. It you tried to use a plunger to clear your clogged sink or run the disposal with to much junk in it you may have force debris into the dishwasher drain hose. With both the dishwasher and garbage disposal disconnect from power disconnect the dishwasher drain hose from the garbage disposal. This is usually about a one inch black hose. Clear out any debris in the hose and inlet nipple on the garbage disposal. If debris is compacted far down the hose it will need to be disconnected from the dishwasher end and remove to clear the blockage.
Steve
Feb 10, 2012 | Asko 1385 Dishwasher
How to disconnect
To disconnect ....remove the kickplate...after turning off the electric and water...remove the electric wire from the dishwasher by opening the e;electric box and undoing the wires...also remove the water pipe/hose from the inlet valve...then remove the drain hose from the drain and makes sure that it will not catch as you pull out the dishwasher...then remove the two screws that hold the dishwasher fast to the countertop and the pull the dishwasher straight out from under the countertop...
heatman101
Sep 15, 2010 | Kenmore Dishwashers
Replaced disposal and now dishwasher isnt draining
It sounds like you've done everything fine. I would disconnect the dishwasher drain line from the disposal, have a bucket ready and see if it will drain. It's possible that there is a plug or something else left in the disposal opening that is blocking the water. If the dishwasher won't drain with the hose off of the disposal, there is a problem with the dishwasher that has nothing to do with your disposal installation. Hope this helps and good luck!
Mar 12, 2010 | Dishwashers
Maytag dishwasher needs to be replaced. How to get old appliance out of space?
first make sure the power is off.you need to disconnect the power at the junction box,then you need to turn water supply off and disconnect the supply line from the water valve its easier to disconnect that way than from bottom of dishwasher.then just disconnect the drain line from under the sink.lower levelers on front of dishwasher under neith of it.there are 2 screws that attach to the top of the dishwasher to hold it in place.you have to open the door to see these screws.and thats all there is to it.
May 18, 2009 | Dishwashers
What is the black hose for (trying to disconnect dishwasher. Have followed all the appropriate steps -turning off power/turning off water supply, disconnected everything so far..........except for big...
hi thanks for the question did you disconnect the drain hose from the sink if not disconnect could be big black hose thanks the appliance doc
Sep 26, 2008 | Dishwashers
Bosch dishwasher will not drain
how do you disconnect the waste pipe from the back of a Bosch hydrosensor dishwasher
Aug 09, 2008 | Dishwashers
I need to unplug and move a built-in Maytag dishwasher
Follow these steps:
1. Locate the electrical service breaker for your appliance and turn it off at the breaker panel. If it is plugged in by a serivce outlet, unplug the unit.
2. Turn off the water source under the sink.
3. Disconnect the drain line under the sink.
4. Remove the lower panel under the dishwasher door.
5. Locate the small electrical junction box under the dishwasher and disconnect the wires leads. Remember, standard household wiring is as follows: BLACK (HOT - 110-120VAC), WHITE (NEUTRAL - 0VAC, GREEN (or bare copper) is GROUND. Make sure you reconnect the wires in this fashion with wire lug nuts. If you have a local outlet plug you may leave the wiring instact.
6. Locate the fill valve (Usually on the left hand side of the dishwasher). This is where the water supply line connects. Disconnect the water supply line from the fill valve.
7. The dishwasher should have a couple of mounting screws located where the top of the dishwasher cabinet meets the underside of the cabinet.
8. With everything removed, the dishwasher should now be free and slide out from under the cabinet.
Let me know if you have further questions. I hope this helps you.
NOTE: You can also remove the water supply line at the fitting under the sink if it makes things easier.
Jul 24, 2008 | Maytag Dishwashers
Dishwasher does not work
TO SLIDE THE UNIT OUT YOU MUST UNINSTALL THE MACHINE. START BY UNSCREWING THE TOP. ANY SCREW THAT HOLD THE MACHINE IN ON TOP AND SIDES IF APPLIES. CHECK THE DRAIN AND FILL HOSE TO SEE HOW MUCH LINE YOU HAVE TO PULL OUT UNIT. IF DRAIN HOSE IS SHORT DISCONNECT FROM UNDER THE SINK. IF FILL HOSE IS SHORT TURN OFF WATER GOING INTO MACHINE AND DISCONNECT HOSE. IF ELECTRICAL IS SHORT THEN DISCONNECT FROM TERMINAL BLOCK BUT MAKE SURE THE POWER IS OFF. THAT SHOULD DO IT.
Mar 23, 2008 | Bosch 18 in. SRS43E02 Slim-Line Built-in...
Dishwashers Logo
95 people viewed this question
Top Dishwashers Experts
