Question about Stihl Chain Saw Handle Models 044 046 Ms440 Ms460
I have a stihl 044, older saw and its not running properly. When I try to start it with the full chock, I get fuel ranning out of the muffler every time I try to start it. I take off the air filter and "hot start" it and it starts but didn't idle then dies. I adjust to idle and it idles ok but when I put the air filter back on I have to increase the idle more. When I give it full throttle, it may or maybe bog down or run ok for a bit, then I let off the throttle and it spits and then dies. Any suggestions?
  • Stihl Master
  • 2,239 Answers
I would say it is flooding, you realy need to pressure test the carb to check the seating of the inlet needle, a simple bulb tester is all you need, connect it to the fuel inlet on the carb ( where the fuel hose is connected ), pump approx 2/3 psi into the carb, it should hold this steady with no leak, any leaks then you will have to fit a new inlet needle, let us know how the test goes.
Posted on Apr 05, 2011
My o34 Stihl chain saw ran good one day the next day won’t start I rebuilt cab got fire no start I tried starting fluid in plug still no pop to try to start saw is 34 years old well maintained
Have you checked the compression on the cyl. A saw that old may have lost compression and also have you checked the muffler to be sure it is not plugged. I base this on you saying you have fire to the plug.
Oct 08, 2017 | Stihl Garden
Stihl 024 AV won't start. Replaced carb, plug, air filter, fuel line. Ran fine for 10 min then quit.
Fuel mixed properly and fresh?
if you put a few drops of fuel directly into carb, does it run for a few seconds?
have you checked the piston for scoring? (By removing muffler)
Apr 22, 2017 | Stihl Garden
Cant get enought gas
repair - What should I check if my chainsaw fails to start ...
diy.stackexchange.com/.../what-should-i-check-if-my-chainsaw-fails-to-s...
Feb 26, 2013 - Does anybody have any idea what I can do to get my chainsaw started?... Clean carburetor and fuel lines, especially if it may contain old fuel. ... that prevents it from generating enough current to sustain repeated firing of the spark plug as the engine turns. ... Your muffler is pluged up your saw can't exhaust.
Stihl Chainsaw - starts but won't run - GardenWeb
forums2.gardenweb.com > Garden Forums > Tool Shed
Aug 9, 2006 - Re-chocking (once until it kicks) gets it running again for another 20-30 seconds ... carb body was not letting enough gas through to contunue running the saw at full speed ..... MY STIHL 029 CHAIN SAW BLOWS GAS BACK OUT OF THE .....Can't imagine why shaking the saw around would keep it running. Chain saw won't start
Feb 8, 2012
homelite xl chainsaw
Sep 4, 2009
Husqvarna chainsaw wont start?? HELP
Oct 15, 2006
chainsaw starts then after few cuts shuts down
Mar 30, 2006
More results from forums2.gardenweb.com
chainsaw won't start - any ideas? [Archive] - Straight Dxxe ...
boards.straightdope.com > ... > Main > General Questions
21 posts - ‎11 authors
Jan 31, 2016 | Garden
Stihl saw runs but won't idle.
The paper pumps get stiff and do not pump fuel very well. It's the new Ethanol gas that is the Carb Killers. You need a rebuild kit not just disassemble and clean.
You have IDLE ADJUST Low Speed adjust and High speed adjust. Low and High speed adjust have nothing to do with Idle.
Oct 11, 2012 | Stihl 044 046 Ms440 Chainsaw Muffler
Saw cuts out when i push chock in
Main jet or inlet screen is plugged. Fuel pump or metering diaphram compromised due to old stale fuel, mostly from sitting for extended periods with fuel in tank, or fuel line is deteriorated.
Sep 21, 2012 | Stihl Chain Saw 051 075 088 090 +
How do you start a STIHL MS460 chainsaw
I am a Stihl mechanic. The proper starting procedure is to set the switch to full choke. Pull the starter rope no more than three times.Now raise the switch up one notch and pull it till it starts. Stihl products will flood if pulled more than three times with the choke on. Thanks, George
May 08, 2012 | Stihl Chain Saw Handle Models 044 046...
My weed eater sounds like its ready to die, looses power runs like it ca,nt get eithr gas or air
if it's an older unit start with pulling the muffler and cleaning exhaust port and spark arrestor. while muffler is off sta.rt the unit and check for improvement. if no improvement clean & adjust carb. if improved with no muffler, test again with muffler installed. if unit goes back to running poor replace muffler.
Jul 12, 2011 | Stihl Ts 510 760 Cut Off Saw Repair...
044 stihl sawchain wont idle just dies out and sometimes runs at high idle
This sounds like an air leak. Checking all of your hoses and making sure the crankshaft seals are good is where to go after adjusting the carburetor to factory settings.
remove the muffler and make sure the engine does not look like this:
barterjoe_9.jpg Consult a gold certified Stihl dealer like www.arcolawn.com for parts and tools to repair all of your Stihl equipment.
Good luck
Dec 15, 2010 | Husqvarna Chain Saw 20" Bar
The chainsaw boggs down immediately when it contacts the wood. It runs somewhat choppy as well at idle. It is new to me and this is the first time I ran the saw. Is this a carb adjustment thing? plugged...
Clean the air filter. Remove, clean, and reinstall the muffler and spark arrestor.
If my new saw I would consider a Stihl mechanic tune up $40±. New plug, new fuel filter, pressure/vacuum tests and carburetor adjustment.
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
  • CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
  • Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
  • Clean the spark arrestor and muffler; if the saw cannot exhale it cannot inhale.
  • There are 2 wav (sound - idle & full - may not be highlighted) files that I find most helpful, I think you will too.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 22, 2010 | Husqvarna Chain Saw 20" Bar
Stihl Chain Saw Handle  Models 044 046 Ms440 Ms460 Logo
681 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
brotherscott
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
