Question about Plumbing
Water Pump Gasket needs replacement - Plumbing
  • 8,404 Answers
So ... whats the problem? You unbolt the pump, clean the surfact, apply the new gasket with goop on it and reinstall the bolts. Do you have a question about that?
Posted on Apr 05, 2011
I have a 2006 ford 500 sel the water pump has water coming out of it do i need to replace the water pump or is there a seal or gasket that may have gone bad? That i could replace
Most water pumps have weep holes underneath that direct leaking water downward.
Sounds like you need to replace the water pump and of course get a new gasket. don-ohio
May 21, 2017 | Ford Cars & Trucks
Does a water pump gasket problem lead to other gasket problems- such as intake or head gaskets/ and is it associated with having coolant loss issues?
If the low coolant from the water pump leaking has caused the engine to overheat, then the cylinder head(s) can warp and the head gasket(s) will leak also.
Feb 04, 2015 | Cars & Trucks
Replace water pump torrent
drain coolant until below water pump level. loosen water pump pulley bolts.then remove drive belt by rotating belt tensioner.remove drive belt from the right of idler pulley.carefully release the drive belt tensioner spring tension.then remove water pump pulley bolts and pulley.remove water pump bolts and water pump pay attention to the position old water pump when removing water pump so you can line up new water pump holes to the engine. be sure clean engine water pump mounting surface use gasket remover dont scratch engine surface when cleaning removing old gasket material. take new water pump gasket get it mounting holes line up with new water pump mounting holes.when done getting engine water pump surface clean.water pump gasket paper you need to put thin layer of sealer on both sides of water pump gasket use RTV SILICONE.LET SET UP 10 MINUTES. PUT GASKET ON WATER PUMP BUT FIRST MAKE SURE LINE UP GASKET HOLES WITH WATER PUMP HOLES BEFORE PUTTING ON THE GASKET SEALER.when gasket sealer set up 10 minutes then install new water pump with gasket to the engine torque to 89 inch lbs.or 10 NM that is about 7 ft lbs torque.you should be able turn water pump by hand if you cant turn water pump by hand got too tight damage water pump shaft bearing.when all done wait for THREE HOURS. before adding coolant i let RTV CURE SOME. torque water pump pulley bolts 18 ft lbs.
Dec 28, 2012 | 2006 Pontiac Torrent
Need instruction for replacing water pump 2004 GMC Envoy 4.2 liter engine.
TO REPLACE WATER PUMP.FIRST YOU HAVE TO DRAIN THE COOLANT SYSTEM. REMOVE AIR INTAKE DUCT AND RESONATOR. REMOVE THE RADIATOR SHROUD AND FAN CLUTCH ASSEMBLY REMOVE THE DRIVE BELT. REMOVE WATER PUMP PULLEY.YOU NEED A PIN SPANNER WRENCH OR STRAP WRENCH TO HOLD WATER PUMP PULLEY WHILE LOOSEN WATER PUMP PULLEY BOLTS .YOU CAN BUY STRAP WRENCH OR RENT PIN SPANNER WRENCH AT AUTO ZONE PARTS STORES OR OTHER STORES HAS TOOLS CAN BE RENT. ONCE WATER PUMP PULLEY REMOVED. REMOVE THE WATER PUMP MOUNTING BOLTS. REMOVE WATER PUMP. IF WATER PUMP STUCK YOU CAN TAP WITH SOFT FACE HAMMER OR A LONG PIECE OF ROUND WOOD.WHEN WATER REMOVED.YOU NEED TO CLEAN THE SEALING SURFACE CAREFUL DONT SCRATCH SEALING SURFACE. YOU CAN BUY CAN OF SPRAY GASKET REMOVER.CLEAN SURFACE GOOD THEN WIPE WITH LACQUER THINNER OR ACETONE.THEN GET WATER PUMP NEW GASKET MATCH HOLES UP WITH GASKET TO WATER PUMP. ONCE HOLES MATCH UP APPLY RTV SEALANT ON BOTH SIDES WATER PUMP GASKET. THEN PUT GASKET ON WATER PUMP THEN INSTALL WATER PUMP TO VECHICLE.TORQUE WATER PUMP BOLTS TO 89 INCH LBS .TIGHTEN WATER PUMP PULLEY BOLTS TO 18 FT LBS THEN PUT EVERY THING BACK VISA VERSA.
Aug 26, 2011 | GMC Envoy XL Cars & Trucks
How can I replace the water pump on a 2004 Grand Prix GTP superchargered?
WELL YOU NEED TO DRAIN COOLANT SYSTEM.PLACE A LARGE DRAIN PAN UNDER THE RADIATOR TO CATCH COOLANT WHILE DRAINING RADIATOR.ONCE ALL COOLANT DRAINED OUT.REMOVE DRIVE BELT.REMOVE WATER PUMP PULLEY.REMOVE POWER STEERING PUMP AND MOVE IT ASIDE.THEN REMOVE WATER PUMP.MAKE WATER PUMP MOUNTING SURFACE CLEAN THEN INSTALL NEW WATER PUMP AND GASKET IN PLACE.IF WATER PUMP GASKET IS PAPER TYPE PUT GASKET SEALANT ON BOTH SIDES OF THE GASKET.IF YOU HAVE RUBBER GASKET DONT USE NO GASKET SEALANT.INSTALL NEW WATER PUMP TORQUE LONG BOLTS TO 25 FT LBS AND TORQUE SHORT BOLTS TO 16 FT LBS.TORQUE WATER PUMP PULLEY TO 115 INCH POUNDS.TORQUE POWER STEERING PUMP BOLTS TO 25 FT LBS.THEN INSTALL DRIVE BELT.FILL THE COOLANT SYSTEM.START THE VECHICLE AND CHECK FOR LEAKS.
Mar 25, 2011 | Pontiac Grand Prix Cars & Trucks
Hi is it a hard job to replace gasket on a 1990 mazda 626 2ltr water pump
what gasket are you talking about the head gasket? if so its about a week to do the job typically cause have to take heads off and can figure run into multiple problems along the way and need a new valve cover gasket cause it will fall apart and a new water pump and new water pump gasket
Sep 25, 2010 | 1990 Mazda 626
Water pump is out. How do I get id out to replace
is it a 4 or a 6 cylinder engine, well you need to take off the fan clutch if it has one if not skip the step; its just 4 screws, then take off the acc belt, then take off the hose that goes from the radiator to the water pump; at the water pump, then remove the screws holding the water pump; make note what screw goes where some screws may be different sizes; in some 4 cyl 2.3L engines the timing belt cover has to be removed to remove the water pump, then remove the water pump, scrap off all gasket residue from the surface of the engine, take automotive silicone gasket maker and apply a small amount to the new water pump and level it out then put the included gasket over the silicone, then let it set for a couple of minutes, apply a bit more of silicone over the gasket and again let it set then replace the water pump, replace the screws and tighten all of them snug then go back and torque them between 20 and 25ft lb, replace the water hose, replace timming belt cover if removed, replace acc belt, and finally replace the fan clutch and your all set i hope you can get the job done
Jul 27, 2009 | Ford Ranger Cars & Trucks
Replacing engine with a crate engine
You have to get new gaskets like head gasket, valve cover gasket, water pump gasket. You'll need an alternator, if it has a/c you'll need an a/c compressor; you'll need a serpentine belt.
Oct 09, 2008 | 1986 Chevrolet C1500
Water spraying out above the water pump water pump was replaced also gasket
could be a bad gasket or a bad water pump.If the gasket isn't sealed properly you with spray out water.It is possible to get a bad water pump,but not likely.Check the gasket first.
Jul 18, 2008 | 1996 Pontiac Grand Am
Plumbing Logo
23 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
