Question about Kitchen Ranges
Oven door won't stay shut and light stays on. whirlpool
    President:
  • 1,779 Answers
How old is the oven? Did this problem just start? If this is an older oven, and it started having this problem recently, it sounds like the door is bent slightly. Enough to keep the light on. Anyone put weight on the open door, (or as I saw once, someone trip and land on an open dishwasher door, which didn't shut properly afterwards) You can get a piece of paper, put it at the top corner of the door opening, try pulling it out. Try this all around the opening, you should be able to tell where it doesn't close properly. U might be able to 'tweek' it, by trying to bend it to close tighter at the largest gap, BUT this could make it worse, or if it has a glass panel, u might break it. So, tweek at your own risk. countrycurt0
Posted on Aug 05, 2008
2 Suggested Answers
SOURCE:
  • 12 Answers
SOURCE: gas oven won"t stay lit
you eaither have a bad regulator from the tank to the house or you have a bad appliance regulator behind your appliance you would need to check the pressure at the appliance if it is propane you should have between 10-14'' of water colum or if it is nat-gas it should be 4-7'' of w/c
If you need further help, reach me via phone at https://www.6ya.com/expert/jeremy_075aa344198c3329
Posted on Feb 20, 2009
Will not stay on will shut off
Whirlpool Gas Oven Will Not Stay Lit - Appliance Repair Forum
forum.appliancepartspros.com/oven.../482851-whirlpool-gas-oven-will-...
Jun 20, 2012 - 2 posts - ‎1 author
My Whirlpool gas oven will light but not stay lit. It has a glow plug igniter that heats up enough to allow the gas valve to open. Once the burner ... oven lights, but does not remain lit
Feb 19, 2013
Oven does not stay lit
Jun 19, 2012
Oven will ignite but will not stay lit
Aug 3, 2010
Gas Oven won't stay lit
Mar 25, 2008
More results from forum.appliancepartspros.com
Jan 04, 2016 | Ovens
Door won't stay shut, microwave will not start
Contact the maker or Google the model number for "parts"
That part likely will require the unit to be taken apart to replace it.
Jun 16, 2012 | Jenn-Air Microwave Ovens
Whirlpool interior light won't shut off
That is a really good question....what category did you post it under?
May 28, 2012 | Cars & Trucks
My oven will turn on but won't stay lit (
The light may be loose, or one of the micro switches are going.
Apr 03, 2012 | Whirlpool Microwave Ovens
Ovendoor doesn't shut all the way now...
unplug it then plug it back in... it worked for me
Jul 23, 2008 | Whirlpool GMC305PD Electric Single Oven
Oven door stays open
Hi , the oven dorr needs ajustment , lose some attachement bolts ,then close the clearance will shut , so open gently and tightened the bolts.
Jan 06, 2008 | Whirlpool GBD307PDS Electric Double Oven
Kitchen Ranges Logo
357 people viewed this question
Top Kitchen Ranges Experts
Marvin
Marvin
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
