Question about Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522
I have a 50 gal electric rheem 82v52 fury. the breaker keeps tripping
5 Suggested Answers
  • 961 Answers
SOURCE: need to up water temp
The two blue rectangular cover plates, held on by two scews, cand be removed by taking out screws. There might be a little piece of insulation present when you pull off the panel, pull that out. You will see a pointer that is shaped kind of like an egg, pointing at numbers which represent temp in degrees. Start with the lower dial, this is your thermostat, Raise temp setting by 10 deg. Hypothetically, depending on what your present setting is, try setting lower thermostat at 130 and upper at 120. Your lower thermostat should be higher than the upper because of heat rising, it is more effecient and both thermostats don't have to be at the same temp. This will save you money in the long run.
Posted on May 25, 2011
SOURCE: I have a Rheem 82V52-1
Protect yourself.
If water heater is tripping breaker and water heater is wet, then danger of electrocution.
Turn off power.
You do not need special element. Local home center and hardware sell generic elements.
Check side of tank for element wattage, usually 4500 Watts.
http://waterheatertimer.org/How-to-troubleshoot-electric-water-heater.html
If fiberglass insulation is wet, you need new insulation because the insulation and cover cannot be left off the heater.
If thermostat is not covered with insulation, then cooler air will cause thermostat to mis-read temperature, and tank will overheat.
Putting a wet water heater back into service is dangerous.
Manufacturers suggest replacing flooded water heater.
Local Lowes here sells new 40 gallon electric water heater for $207.
Loosen anode rod before installing.
http://waterheatertimer.org/Replace-anode-rod.html
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on May 27, 2011
SOURCE: Rheem 50 gal keeps tripping breaker. What is the
Do not touch water heater that is tripping breaker.
Open following link for troubleshooting steps:
http://waterheatertimer.org/Test-electricity-to-water-heater.html
Upvote the help.
  • 349 Answers
SOURCE: my rheem 50 gal water
Check all wiring at water heater and possible upper thermostat is bad, and in need of replacement.
Posted on Aug 15, 2011
Rheem marathon tripping breaker
Turn power off. Open covers and inspect for burned parts.
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
Test elements. Marathon takes specific element, and does not use generic element from hardware store.
http://waterheatertimer.org/How-to-test-water-heater-element.html
Oct 27, 2012 | Rheem MSR50245 Marathon Electric Water...
My rheem 50 gal water heater model 81mv52d keeps tripping the breaker, what do i need to do to stop this
Aug 15, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have a Rheem 82V52-1 Fury Electric Water Heater. The breaker keeps tripping atfer about five minutes of use. I uncovered the Bottom Element and Tested it with a Multimeter. Reads about 6 Ohms, Seems...
Protect yourself.
Turn off power.
Upvote the help.
May 27, 2011 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
I have no hot water in my house. I have a Rheem model #82V52-2 with a 50 Gal tank, mfg date 11/2005. Please help I don't want to have to pay someone to come over. Thanks!
There are several possible points of failure in your electric water heater. The easiest to check requires no more than a look at your main electric panel and locating any tripped circuit breaker. If done properly, it should even be marked as 'Water Heater.'
These breakers are not immune to failure; they can trip for no reason if defective. If you find a tripped breaker which may have two breakers visibly mechanically connected, reset it by pushing it to the tripped end first and then to the 'On' position. If there are no faults in your heater elements or the breaker, you may be finished already.
The other failures would require that you obtain a multimeter so you can check continuity of several items. Such meters, most digital today, can be found at auto parts stores, Radio Shack and other electronics outlets. If you have a Harbor Freight Tools store in your area, you can buy them there for well under $10 US and the simplest will do the job. You shouldn't have to spend more than $20 US to buy a usable one and any of them are very useful for simple home and auto troubleshooting. They are also numerous on eBay:
Digital meters
If you decide to go this route, comment back to this thread and I will guide you further.
Jul 18, 2010 | Rheem Water Heaters
TRYING TO REPLACE MY OLD RHEEM WATER HEATER MODEL NUMBER 81V52D C SERIAL NUMBER RH 1297B30669 50 GAL US TANK ELECTRIC WHAT IS THE UPDATED VERSION?
I would say your water heater is from the fury series; new model number 82V52-2. I've included a link with my solution that you should take a look at. You could also look at water heaters of a different brand if this one isn't available in your area. Kenmore, GE, and Hotpoint are all very good brands of water heaters.
http://www.rheem.com/product.aspx?id=09DF2BDD-5E11-4D32-B574-84ACFB8A4619
May 25, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 gal keeps tripping breaker. What is the problem?
Upvote the help.
Dec 05, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
6 yr old electric rheem fury 50 gallon all of a sudden runs out of hot water. Only one shower of hot water now where before atleast two.
you have a couple things that may cause this. you may have a bad element a bad thermastat a tripped eco (emergency cut off ) or problem with electric suppling heater.if you have no electric backround or training you should call a pro
Mar 25, 2009 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
Rheem 50 GAL ELEC TALL Water Heater 6YR SC 83VR522 Logo
148 people viewed this question
Top Rheem Water Heaters Experts
Donni Steen
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
