Question about Oritron Televison & Video
A DVD is stuck in the player and the door will not open, it makes a grinding noise when you try to open it.
  • 2,427 Answers
Well looks like the disc is lodged into the track thats why you cant open it, the grinding noise is the track slipping on the motor gears as it forces to attempt to open and fails..
what we need to do is open this up and remove the disc manually..
  1. unplug the device (dont wanna get electrocuted)
  2. remove the screws to the back and under the player
  3. lift the cover off by sliding it back then raising it up , prying with a bladed screw driver helps.
  4. you will now see the disc stuck under this metal / plastic piece if you can see the disc at all.
  5. remove the screws holding the disc tray top in place. remove the disc and reassemble.
that should solve the problem, let me know how it turns out of if you need more help if you ran into a tight spot.
Posted on Apr 05, 2011
DVD player makes grinding sound and doors don't open
You may have a stuck DVD in the player. Most DVD players have a small pin type hole in the front where you can inser a paper clip to manually open the tray. Otherwise, you have to remove the cover of the drive to actually see what is happening. support hp com Maybe this link will be of some assistance.
Mar 01, 2015 | Televison & Video
Grinding noise whle movie plays on portable dvd player
Is it happening with all the dvds you play on it, if so then you should clean the drive with a branded dvd drive cleaner.
Jun 09, 2012 | Philips Televison & Video
It will not let me insert a disc and when I press the eject button, it sounds like it is going to eject a disc and then it makes a weird noise for 5 seconds. Then, it will say CLOSE for a bit. I got one...
It sounds like you have 2 disks stuck in there. TV repair shop, or try shaking the dvd player lightly while dvd is trying to open. You may need to help open the door, but too much effort could cause harm.
Jul 08, 2011 | Samsung BD-UP5000 Blu-ray and HD-DVD...
The door of my dvd player will not open. It sound like it wants to, but nothing happens.
This sounds like a problem with the mechanism of your player,it is probably stuck.
What you should do is to open up the player and try to open the door with your hand by pulling it,check to see what is stopping it from opening and clear the object stopping the door from opening automatically
Please note that it might just require oiling the door wheel to make the door open and close automatically.
Aug 20, 2010 | Sanyo DVW-5000 DVD Player/VCR
Sony dvd player DVPCX995VMakes grinding noise and door won't open
I was able to fix this myself, however, I did get instructions from Sony that may or may not work. My solution was:
Unplug the unit and carefully (so the disks don't shift) move to a location where it can be easily worked on.
Remove the 9 screws holding the cover on. 2 on top, 2 on each side, and 3 at the back, along the top edge.
Carefully, may need some wiggly remove the cover. There are some rubber pads at the front of the unit that hinder the cover from sliding. Slightly wiggling and pulling to the rear will dislodge it.
Confirm all disks are properly aligned on the carousel.
Pull out any disks that are askew. They will be replaced later in the same way disks are added, through the door.
Look in the rear where the laser unit is.
Carefully slide out disks near the laser. You'll have to move some in order to tip others out.
By taking out 6-10 disks, you'll probably find there's one partially lodged in the laser unit. With adjacent disks removed you can slide the "stuck" disk out.
Plug in the unit and test to see if the grinding stopped.
Unplug the cord.
Replace the cover with the 9 screws. Some wiggly and pushing forward is needed to reseat the cover at the front.
Carefully move the unit back to where it was.
Replace cables and plug in.
Return the disks removed according to the instructions.
This took me about 15 minutes from start to finish.
The following was provided by Sony. I don't know if this works as I had fixed it before Sony responded.
IMPORTANT: If model-specific information is required to complete any of the steps in this solution, refer to the operating instructions supplied with the product. Manuals are available online in the Manuals/Specs/Warranty section of the Sony® eSupport Web site.
  1. Ensure the child lock feature is disabled.
  2. Attempt to open the disc tray.
  3. If the issue is not resolved, turn off the DVD player.
  4. Unplug the power cord from the electrical outlet for 30 seconds.
  5. Plug the power cord back into the electrical outlet.
  6. Attempt to open the disc tray.
  7. If the disc tray still does not open, simultaneously press the POWER + STOP + EJECT buttons.
  8. If the disc tray still does not open, simultaneously press the DISC1 + STOP + EJECT buttons. NOTE: This step may not apply to all models. DISC1 is not available on all DVD players.
If the issue is still unresolved, service may be required. The Sony® eService Web site at http://eservice.sony.com/ can assist you in obtaining service from a Sony Service Center or locating a Sony Authorized Servicer.
Oct 11, 2009 | Sony DVP-CX995V Multi-disc DVD Player
HP dvd play on my laptop malfunctioning
grinding sounds is from the dvd drive itself. Sounds like its not sitting properly in the drive or the holder that it sits in is going bad. Either way replace the drive and that will take care of the grinding sounds. Also the more grinding sounds that happen, the more of a chance you take on your dvds getting scratches on them and going bad eventually.
Jun 11, 2009 | Compaq Presario Notebook
Door will not open on a toshiba sd-6100. Its makes a grinding noise but will not open
there is a tiny hole next to the dvd door. Straighten out a small paperclip and push the end of the wire into the hole to manually open the door.
Apr 06, 2009 | Televison & Video
2 dvd's are stuck in dvd player
This may need a trip to the shop.
I would try to bring the device to a worktable and using gentle probes, ease the door open when activated.
I assume that there is a noise when you activate the door open feature.
Mar 21, 2009 | Toshiba SD-V394 DVD Player/VCR
Panasonic DMR-E85H - DVD door wont open
I opened the DVD door and something looked crooked... I pushed it down to straighten it... it clicked back into place and it works great! haha. I bought it off craigslist for only $15.. great deal. :)
Dec 06, 2008 | Panasonic DMR-E85H DVD Recorder
Malfunctioning DVD player
that is normal for laser to do that.
Basic DVD, CDrom Troubleshooting
wrong disk ,disk error,
First Clean the lens:
http://www.ehow.com/how_2036275_clean-lens-dvd.html
wont open, wont close, makes clicking/grinding noises etc.
http://www.llamma.com/xbox/Repairs/thompson_dvd_tray.htm
Feb 03, 2008 | Cyberhome CH-DVD 300 DVD Player
Televison & Video Logo
174 people viewed this question
Top Oritron Televison & Video Experts
Electro Med Services...
Are you an Oritron Televison and Video Expert? Answer questions, earn points and help others
