Question about GE GSS22SGM Side by Side Refrigerator
I HAVE A GSS22KGPC side by side it get cold but not very cold cleaned condenser coils stil not very cold. What else can I do?
  • 5 Answers
SOURCE: fridge not getting cold
Hi you have probably a leak. must inspect all piping to see if there is some small residue of oil.if you find oil you find the leak
Posted on Jun 29, 2008
thompsonds20
  • 53 Answers
SOURCE: Loud noise and stops when I open the doors-only
The power supply might be erratic and when the voltage is high the unit starts on it's own and stops when the voltage is low.
Your compressor might be taking high amps and resulting in big thud noise. It announces indirectly that it needs a replacement.
Posted on Jul 10, 2009
  • 832 Answers
SOURCE: Freezer wont freeze and fridge isn't cold enough
Check the refrigerant level, using the systems analyzer.
From the analyzer, you will know if the high and low side of the compressor has the right pressure. If you
don't have the analyzer, then just get the services of
the refrigerator/freezer technician to fix it.
Posted on Sep 28, 2009
heatman101
  • 43501 Answers
SOURCE: No cold air to refrigerator; extra cold air to
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Posted on May 31, 2010
livewire874
  • 618 Answers
SOURCE: how do i clean the condenser coil on a GE side by
Take off the rear panel over the compressor .
Posted on Nov 30, 2010
Excessive condensation dripping inside refrigerator
Bonjour,
Some refrigerators have heaters mounted in different places around the unit to take care of condensation. If those heaters don't work, you see drips. Another common cause to much frost/ice build up on the freezer evaporator coils or in the area beneath, below or around the evaporator coils. That's usually a sign of incomplete defrost cycle. Another cause could be broken or shifted insulation that's letting very cold air get to the back side of a partition that has warmer air on the other side. The warmer side drips condensation.
Based on the condenser coil cleaning results and not having any temperature data. In your case I would guess incomplete defrost. That leads to defrost timer, defrost heater, defrost termination thermostat and clogged evaporator drain line. Or some combination of the four.
Jul 11, 2012 | Frigidaire Refrigerators
Freezer has warm spots. All around freezer is hot to the touch. Compressor is hot, coils are clean, condensor fan is running.
Thats normal.
The condenser coils are located just inside of your exterior cabinet walls on the sides and top.
So the freezer gets cold inside and heat has to be released from the condenser coils.
If this is something new, you may have a problem with the defrost timer
Sep 11, 2011 | Kenmore Side by Side Refrigerator
Hello, Our Eletrolux side by side is 4 yrs old and just today it quit pumping cold air. I cleaned the coils and noted the coil fan is operational and the compresor seems to be working but it is not...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jul 16, 2011 | Electrolux EI26SS55GS Stainless Steel ...
Refrigerator not freezing I clean coil and it is getting cold
heatman101
May 02, 2011 | Hotpoint HSS25GFP Side by Side...
My Frigidaire Mod. # FRS6R5ESB0 P/N 218888702 side by side the freezer is cold close to freeze but not freezing, what can I doo, I already clean the coil condenser and the entire back compartment. Thank...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
heatman101
Dec 25, 2010 | Frigidaire FRS3R5EMB Side by Side...
Hello I have a frigidare refrigerator Model #GLRS64ZEB7 that doesn't get cold. I cleaned the condensing coiled. I tried it and it still didn't work??? The compressor is running the suction line is getting...
Unit is low on freon......
heatman101
Dec 14, 2010 | Frigidaire FFHS2311L Side by Side...
I have a side by side whirlpool frig-freezer , I have had it for about 8 years and it defrosted complet and will not get cold. i cleaned out the coils with the vac, and cleaned everything out of both and...
heatman101
Nov 15, 2010 | Refrigerators
Freezer is not freezing. motor stil works and is still some what cold
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 08, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Kenmore cold spot not cooling properly
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
heatman101
jsrha
Apr 19, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Open Questions:
GE GSS22SGM Side by Side Refrigerator Logo
93 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
