Question about Sony PS-LX250H Turntable
How do I chang the belt on this machine...it seems too big
  • 61 Answers
See the video below on how to change turntable belt
http://www.youtube.com/watch?v=bqVRrkXdlME
Posted on Sep 28, 2011
The machine will not agitate. The belt is good and does not slip. The motor is humming, and seems to be trying to run, but something seems to be stuck.
Unplug the machine undo the belt. Turn the big plastic pulley int he middle counter clockwise if it turns freely with no noise then transmission is fine. Then check to see if the pump pulley movesfreely. If it does then you have a bad motor. Any noises before this problem?
Dec 28, 2010 | Maytag Atlantis MAV6000 Top Load Washer
When machine went into spin it was very noisey and the metal tub has rubbed agaisnt the plastic inside and caused A bit of damage were it rubbed but the rubber seal was not touched I have taken the back...
It sounds like the bearings have collapsed..You may have noticed a noisy spin cycle prior to loosness in the inner drum...This is a big job. Get quotes...Good luck...Nomess
May 20, 2010 | Washing Machines
Hi. I've a washing machine rex electrolux logic RE7. I must change the belt but it seems too much hard for me because the belt is too much short but the new belt is the correct belt. how can do this in...
There are two types of drive belt with different characteristics:
• rubber belts (black)
• plastic belts (yellow)
belt for example: 1280 J 8
1280 = this is the working length which is always shorter compare to length of 1280 mm depending of degree of elasticity (plastic or rubber).
J or H = shape of the drive belt
4,5,6,8 = number of teeth
So, if dimensions, shape and number of teeth are the same as the original belt, proceed as shown pictures below:
Always first place the belt on the motor pulley and then on the drum pulley and then turn the drum pulley (big) and belt clockwise firmly until the belt is seated.
Dado
Jan 23, 2018 | Electrolux Washing Machines
Electrolux front loader.EWF1090 i have the replacement belt but am having trouble fitting it. belt seems too tight. is same as the roken one. any suggestions?
put it on the small pulley first, then hold it on the large pulley with your hand and slowly turn the big drum, ensuring the belt stays on the big pulley as you move it. line up where you place the belt on the small motor pulley with the drum or it may slip off again.
Dec 23, 2009 | Electrolux Washing Machines
Squel noise
Changing the belt is not a big job, but you will have to lie on your stomach for a while. You will need to loosen the bolts which hold whatever is used to tension the belt - the pump, the motor, etc.--- it should be apparent when you look at the entire setup. "Buy a new washer" sounds like a Sears solution.
Apr 22, 2009 | Kenmore Washing Machines
Hotpoint WD640P - Fitting a new belt
Put belt on motor pully first then turn big pully around!Like fitting bike chain.
Oct 11, 2008 | Hotpoint Aquarius WD63 Front Load...
Changing Pfaff 1222 sewing machine belt
Have a look at this: remove the top cover and have a look (don't put your fingers in !) at the plastic gear in the middle of the mechanism (left side of he selection keys). It often cracks and then the motor is able to turn the whole mechanism for part of the circumference of this gear and when it passes on the crack, it locks or slows down until the crack is passed. You need to have it changed if this is the case.
Feb 25, 2008 | PfaFF Tiptronic 2030
How to replace belt??
there are two wheels unplug every thing and turn upside down you will find the other wheel
Sep 21, 2007 | Amana ALW480DA Top Load Washer
Sony PS-LX250H Turntable Logo
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
