Question about BenQ MP515 DLP PROJECTOR SVGA Projector
White lines appear on screen when my projector is turned on
I fixed it by removing the top circuit board and resitting it back to make sure that both connector and pins are inserted properly with the bottom circuit board
Posted on Jun 11, 2013
Marrie
  • 563 Answers
SOURCE: White vertical line on left side of screen
Hi there
This problem can only be fixed properly by replacing the Mainboard.
Posted on Apr 01, 2008
omg, I just figured out why OUR projector was doing this! There was an adaptor plugged into it that we use to hook it up to cable to watch games/tv shows sometimes...once I unplugged that from the projector the lines dissapeared!
Posted on Oct 02, 2008
  • 5 Answers
SOURCE: red lines on the screen
Check out this solution for the same problem:
http://www.fixya.com/support/t305560-even_spaced_vertical_lines_across_whole
Posted on Aug 01, 2009
projdoc
  • 2237 Answers
SOURCE: White Vertical Lines on screen from a JVC projector
bad pcb. get your money back.
Posted on Aug 07, 2009
  • 75 Answers
SOURCE: Half inch crystal/ solid white vertical line on screen
Adjust the horizontal in the menu then try the overscan adjustment. If the image does not look dim you do not need a lamp.
Posted on Jun 05, 2010
Dell 1201mp projector screen flickering black lines with svga cable?
If you projector can not process SVGA then no there is nothing you can do
Dec 16, 2015 | Dell 1201MP Projector
Jun 04, 2010 | InFocus IN72 Multimedia Projector
A vertical white strip appears after few minutes.
Hi fabiano did you ever find a solution the vertical line in your RD-JT91 Multimedia OH projector. I now have the same problem. Gary
Oct 02, 2009 | LG RD-JT91 Multimedia Projector
Thin vertical line appears on projector
I have found that vertical lines that suddenly appear from projectors are due to poorly connected cables. Sut off your projector and wait for the fan to go off. Then unplug the connectors from the computer to the projector and secure them again, making sure to go all the way. Hope this helps.
Nov 25, 2008 | Office Equipment & Supplies
ELMO Projector image not working
Hi schmidtkm
All the sympoms mentioned above is that of a faulty Mainboard that will have to be either repaired or replaced.
Trust me on this one , I work on Projectors every single day of my life.
May 12, 2008 | Elmo Projectors EV-2000AF Multimedia...
I had a smililar problem after taking it apart i realised that i had screwed my mount skrews into the video main board and cracked it along with a few soldered wires, if you havent done any physical dammage to it try a firmware upgrade
Jan 20, 2008 | InFocus IN72 Multimedia Projector
White vertical line in the center of projected image
I have a Dell 2400MP projector that had the same problem of vertical white lines appearing over the screen.
This may seem like a simple solution, and I don't know if this will work for you, but the way I solved the problem was simply to press the bottom side of the projector, until the white lines disappear . Until now, the problem has yet to resurface.
Here's some simple steps:
1. Turn on projector
2. Connect projector to computer
3. Focus projector
4. If white vertical line appears, firmly press underside body of projector
5. See if vertical white line disappears
6. If not, try slowly pressing other parts of the body of the projector and see if white lines disappear.
7. If solution doesn't work, you may need to send it to the service center.
Hope this solution works for you.
Best Regards,
Ghazali Ridzwan
http://www.ghazaliridzwan.com
Nov 28, 2007 | ASK Proxima Proxima DP2000S Data Video...
White lines across the screen
Sometimes if the resolution is set too high, white lines will appear.
Dec 12, 2006 | Toshiba TDP-T9U Multimedia Projector
BenQ MP515 DLP PROJECTOR SVGA Projector Logo
219 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Electro Med Services...
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
