Question about Hitachi Heating & Cooling
Split a/c. RAS/RAC-35YHA3 1. Book says Green light on, filter needs cleaning. Filter and air way clean. ?? 2. Heat function ok, Cool function ok. Auto, heater comes on and keeps going. I swictched back to manual when the room temp. got to 28 degrees. Can you offer any solutions please? Cheers.
  • Anonymous Apr 05, 2011
    No mention in handbook about timer or warning light reset.
  • martinkuiper
    martinkuiper Dec 08, 2012
    Check and clean filters. Switch system off with remote control. Reset filter sign with louvre button on remote control. Enjoy your Hitachi Airconditioner.
    Problem Solver:
  • 5 Answers
I believe the filter light is just a timer set for "x" any days or month. Most t-stats are that way. If you have the manual, you can reset it. Also make sure fresh batteries are in the controller. Good luck.
Posted on Apr 05, 2011
How to remove filter light in Hitachi split AC
Ensure you replace the filter on the AC or
How to clean filter of split AC
When its turn off,not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Apr 10, 2016 | Hitachi Heating & Cooling
Turns on and then turns immediately off. Does not blow any air.
Check if it gots a fuse or safety plug, maybe even a different outlet. Besides that I don't know maybe the filter needs cleaned? I'm not expert.
Feb 02, 2016 | LG LS-L1210HL 12000 BTU Heat and Cool Mini...
Hitachi A/C. The green light of air filter indicator is on.
When its turn off, not unplugged, press at the same time ''Function Button" and the ''AUTO Swing" button on your Remote Controller.
Aug 10, 2012 | Hitachi RAS-09UH Air Conditioner
I have two senville mini split 18000 and they both frost up with in 1 Hr. of use both have been pumped out and recharged
Dear Friend! Before recharging gas.did you check leak testing? If not, again you will same problem.
And some more reasons for frost up:
1. Indoor coil & air filter dust blocked-clean it. 2.Less rpm of indoor fan motor- replace capacitor or motor.
Thanks, it's helpful to you.
Jan 10, 2011 | LG LS-K1830CL Cool Mini Split Air...
LG neo plasma air conditioner does not blow cold air
To get proper cool, keep the tips as follows:
1. Check air filter is cleaned. 2. Check indoor coil is cleaned. 3. Checkindoor blower motor is working. 4. Keep in cool mode. 5. Set temp minimum 3degrees less than room temp.6.Check compressor is working with correctpressure.
Thanks. Helpful?
Jan 04, 2011 | LG LS-J0910HL Heat & Cool Mini Split Air...
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Blowing out warm air
Turn thermostat switch to 'cool' setting. It's a 'heat pump' and is in the heat mode.
Nov 05, 2009 | Coffee Makers & Espresso Machines
Pop saying check filter
Hi there...FIRST remove the dust filter and clean it with some compressed air, or you can leave it in place and use a vacuum cleaner hose to suction off the dust. Some projectors have a sensor that gets reset when the filter is removed. A lot don't. Check the onscreen menu for a reset option for the dust filter. This option may be only accessible with the remote control...DON'T reset the lamp hours! The most important thing with LCD projectors or any other projector, for that matter, is to keep the dust filters clean--think of someone putting their hand over your nose and mouth. The projectors emit a *huge* amount of heat and need plenty of air flow to remain cool. Also, the benefit of cool air keeps the delicate LCD panels from aging prematurely!---Rick
Jun 26, 2009 | Hitachi Performa CP-RS55 Multimedia...
Heating & Cooling Logo
372 people viewed this question
Top Hitachi Heating & Cooling Experts
ka4iup
ka4iup
bobalix
richie46
Are you a Hitachi Heating and Cooling Expert? Answer questions, earn points and help others
