Why my computer runs slow - Computers & Internet
My computer is slow
Win 7 needs at least 3 gb of memory. Run a chkdsk. Then get a free disk defragger from cnet site. Do a defrag of disk and see if your machine runs faster. Another problem can be a virus slowing your computer.
Jan 25, 2014 | AMD Computers & Internet
Slow computer
Improper computer maintenance may result in slow PC. To fix computer running slow you are required to clean junk and windows errors from your PC using a System Utilities program.
To download a reliable System Utilities, go to famous website download.cnet and search there Reginout. Which I personally use and recommend the friends.
After downloading run all of its tools one by one except Internet Optimizer, to clean all the junk and error files from your computer.
Jan 01, 2014 | Computers & Internet
My pc is running really slow... can u please help me????!!!!?????
There are a number of reasons but mainly 2 kinds causing a PC running slow. Outdated hardware or poor system maintenance. If possible, try upgrade hardware configuration such as add more RAM etc. Otherwise try this program Speed up PC to diagnose & fix the slow pc for issues. Best regards!
Jul 17, 2011 | Computers & Internet
My pc is very slow
-Can you provide more information about your issue?
-Are you using Windows XP or Windows Vista or Windows Seven?
When you say slow, is it slow when you are on the internet or slow when accessing or the computer or generally slow like everything is running slow?
Mar 25, 2011 | Computers & Internet
My laptop is running slow? when im in the internet my computer runs slow
Available RAM is very important for speeding up your laptop while surfing. Check your available RAM by:
  1. Starting the Task Manager (Right click on taskbar and select it)
  2. Select the Performance Tab
  3. Compare the Physical Memory vs Commit Charge numbers.
For example, my fast computer has 3600 megs of total physical memory compared to a commit charge of 1200 megs. Meanwhile, my older, slow computer has only 650 megs of total physical memory with a commit charge of 1400 megs. This means the slow computer is always making 'pretend' memory from hard drive space, and that is why it is so slow. This is most likely the case with your computer as well.
I hope that helps.
Jul 14, 2010 | Toshiba Satellite A135-S2276 Notebook
Runs slow on video downloads
Hello Sir,
downloading speed depends on internet connection not on PC specification.
If your transfer is low then downloading will also be low.
Take note that source from which you are downloading also must have reliable connection.
cheers,
Mike
May 08, 2010 | Gateway 832GM PC Desktop
How do i know what programs i can take out of this laptop? it is running so slow.
You can see what programs run in your system by pressing ctrl+alt+del keys together. then click task manager which will have the list of all the applications running. If you find a particular application making your computer work slow, then click on that application in the list and then click end task which will close that application.
One solution for your computer running slow could be reformatting your operating system. Your system might have been affected by virus which could be the reason for your system's bad performance.
Hope it helped!
~regards,
Jegan
Jun 01, 2009 | Dell Inspiron 1521 Notebook
Computer running slow
Slow with programs or slow online?
Try holding ctrl+alt+del and click on the performance tab to see how much available memory you have.
You possibly could be infected. Try AVG free virus software. It finds them when others dont.
Dec 10, 2008 | MSI KM4M-L Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
