Question about Garden
Can I still get a replacement part for my Ryobi Scorpion model RCT2800A on its Head assembly part # 147275 or just even the Bump head knob assembly part # 147153 somewhere?
3 Suggested Answers
eugbug
  • 479 Answers
SOURCE: My Ryobi Grass Scorpion trimmer
Have a look at the these tips:
http://www.fixya.com/support/r9762653-strimmer_lawn_edger_trimmer_run
http://www.fixya.com/support/r9230929-weed_eater_strimmer_will_not_start
Posted on Sep 05, 2011
custom1911sh
SOURCE: Ryobi grass scorpion rct2800a head keeps coming off. Is there a screw or bolt to hold the head in the housing?
I see the spool shaft on the spool and not the drive cable. ALL my trimmers were designed for the line spool to come off the shaft (usually by removing the plastic bump feed nut). Your drive shaft appears to have a groove in it about 3/4 toward the top. I surmise that notch is where a broken/missing set screw or "c" clip would most likely hold the shaft to the drive cable. If you find it to be true, a factory part would not ne needed to find a replacement part to lock the shaft and drive cable.
Posted on Apr 10, 2013
Repair manual for ryobi line trimmer rlt900
Jerry,
That number is not the model number for the trimmer, which always starts with RY. It is the number for the "bump head assembly" which is considered an accessory. They made 3 for this application as follows:
  • Bump Head Assembly, RLT1000, RLT900, RLT1004K
Once you determine your correct trimmer model number you can go to the link below and find your manual. Hope this helps.
RYOBI Product Manuals
Mar 29, 2015 | Ryobi Garden
Apr 10, 2013 | Garden
Ryobi 26cc gas trimmer. Can't replace line. Used 1 8'' line thru slots in spool. (3'' each side). Don't understand next step. Push down spool and twist? Should spool stay level...
You line up the head with "arrows" by turning the plastic bump knob on extreme bottom. When arrows line up with the head then you insert your line through the slots "OR" you insert the line in one side and it comes out the other side. Then you have to push pressure DOWN ******* the bump head while twisting the bump head clockwise to "pull in" the string until there's only about six inches left remaining on the "shortest" piece hanging out the side. use scissors to make the lines equal in size before staring the trimmer. Hope this helps.
Sep 08, 2017 | Ryobi 30cc 17" String Trimmer Zrry30530...
I was given a used 31cc trimmer but can't get the spool off to replace it. how do i do this?
A typical trimmer has a small bump knob, an inner spool with the plastic string wound on it and the housing for that which is the string head.To remove the small bump knob, hold string head firmly and turn the bump knob counterclockwise. To remove the head entirely, first remove the bump knob. Next, remove the inner spool with string. What should be left is the spring with the end of the gear shaft showing. Some heads are locked on and some just slip over the end of the shaft. Check the gear drive just above the string head for any holes in the collar. An object can be placed in one of the holes to lock the drive and twist the head off.Ryobi's use retaining clips on the shaft which have to be removed.
May 06, 2011 | Garden
Ryobi Reeleasy line trimmer head PROBLEM
sounds like the clip isn't engaging properly. For a bump and feed they have steps that lock when enough cord is set out. If the head is not locked when its on it will recoil in. Try to make sure its not sitting wrong.
Apr 20, 2017 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
How do u remove the bump feed spool from the bump feed string head on my ryobi gas trimmer
Grasp the outer portion of the cutting head in your left hand and turn the inner knob with your right. Depending on model, some bump knobs are threaded and some are post and notch. Use a little spray like wd40 to loosen the mechanism. It may take a firm hand, but the two will separate so that you can reload the line. Consider reloading with the .095 five sided line. It cuts much easier than the round line.
Aug 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Jul 05, 2009 | Garden
Bump head screw lost. Cannot find a rpelacement that fits.
Try going to an outdoor power and equipment store of some kind. They will probably have what you need.
Jim
Jun 01, 2009 | Ryobi Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
