Question about Homelite Consumer Products 4.0 Amp, 13 In. Trimmer
Homelite 4.4 amp trmmer edger, handy trim,14inch [350mm] string timmer bgj 0570402. string feeder center and spring tension designagrated while useing need a replacement part
trippssmengi
  • 76 Answers
SOURCE: Homelite
Go to www.homelite.com then in the red up top click on order parts then click launch to parts catalog then scroll down to accept agreement and then you will need to enter your model # and then you can go thru the list of breakdowns and get your part # from the diagrams.
Posted on Jan 05, 2009
  • 45 Answers
SOURCE: Homelite string trimmer mighty lite
does it have spark? did you replace the plug?
Posted on Apr 29, 2009
SOURCE: Replacing the bump head on homelite string trimmer
undo the 2 screws on top of the carb. The bulb is part of a 2 piece cap undo that and it fall out.
Posted on May 16, 2009
  • 11 Answers
SOURCE: How do I the automatic string feeder to work and
i dont remember how to put the line on i got a new head. But when the line gets low hit the head of the atomatic feeder on the ground when runin.
Posted on Jun 11, 2009
#1 Taper
  • 1041 Answers
SOURCE: homelite st-175g trimmer
This is for a duel line trimmer. I hope this will help.
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position. Put cap on and GO CRAZY!
Jim
Posted on Jun 19, 2009
Missing the user's manual for Homelite ut20635r trimmer sold by sears
within the bump head (once opened) you will see add arrows, this indicates which direction you add the line, usually opposite to each other, you will have line hold points (4) within the cup. once you have fulled the cup head with line (octupus needed), thread each line through feeder holes and push line into housing making sure you pull line out through the feeder at same time as pushing into head. pold the hell out of everthing or it will go haywire. Vrey difficult, but after about 300 tries at it, you will still go to the dealer to do it. If you can make any heads or tales of my solution..good luck but its how you do it. Regards Russ
Jul 03, 2012 | Homelite Mighty Lite Lawn Trimmer
Need info on putting line on troy bilt 4-cycle string trimmer. Need to know how to get spool off trimmer to replace trimming string on the spool.
Hold orange spool containing string while twisting the black plastic cap in the center, counterclockwise. This retaining cap is loosely spring loaded, so watch for the spring falling out. Once this locking cap is removed, the spool pulls right off.
Mar 27, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
Describe your Black & Decker Grasshog
The push lock on the string feeder Is sticking. Pull it off, clean it out and put it back on.
good luck
Aug 07, 2009 | Black & Decker Grasshog 12 Inch 18 Volt...
Cord doesn't retract, so I took it apart ...
Pardon the long winded answer. I have had a similar same issue on this trimmer TWICE in the first 3 months. What I found on my trimmer is that there is a spring buffer/assist built into the starter assy between the rope pulley and the plastic part that engages the cogs on the motor. The plastic part that engages the motor has a hole in it to retain one end of the spring and the other end of the spring fits in a slot in the rope pulley. The plastic part with the hole appears to be poorly designed and allows the spring assist spring to fall out of the hole and jam the entire assembly preventing the rope from returning. Pulling it apart allows the recoil spring to escape from under it's cover and prevents it from engaging. Yes, removing the spring can be a little exciting -- take your time and cover the housing opening with a towel before removng the spring to keep it from flying across the room. I rewound the spring by driving a nail into my workbench and using it to retain the center hole and wound the spring until it would fit inside the metal spring cover. There's a bump in the outer winding that fits in a hole in the spring cover and then it slides over a peg in the plastic housing. The cover will retain the spring as you put it back into the housing as long as you take your time. The circled inner end of the spring should show in the center hole and it engages the other part of the recoil assembly that engages the cogs on the motor. Check to see if the assist spring is engaged on both ends before tightening the 3 retainers. All-in-all a pretty poor design that has me looking for another trimmer and this one's going in the trash.
Aug 07, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
Homelite curved shaft timmer line problem
So, is this trimmer suppose to feed the string automatically? If not, then it sounds like the string is wound up on the spool the wrong direction.
Jim
May 28, 2009 | Homelite Curved Shaft Trimmer Bump Feed...
Homelite Consumer Products 4.0 Amp, 13 In. Trimmer Logo
749 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
