Question about Vacuums
My Kenmore model 116 33300300C smells like burning when we use it. The bag has been replaced
  • blazanik Apr 05, 2011
    Hi - I can not see the belt
    When it is turned on it spins quickly and smoothly...
If it is a burning rubber smell it may be the belt slipping. Make sure your brushes are clean and spin freely and then put the belt back on and see if that helps.
Posted on Apr 05, 2011
  • 2 more comments
    Hello - I am not sure how to take this apart but the brushes do spin freely.
  • bmosley354 Apr 05, 2011
    Can you see the belt? and is it on the pulley where it should be?
    Can you see if the brushes are spinning when you turn it on? My wife has had our vacuum smell like burning rubber before and it has always been the brushes and the belt slipping.
    I am at a loss unless it is slipping at the motor or the motor is getting hot. Sorry I could not be of more help.
Burning smell Kenmore 50558
If the burning smell is an electrical smell it could be motor or wiring problems which are best handled by a professional. If it smells like burning rubber it is probably the belt. If it smells like burnt wood it could be the belt slipping on the brush roll, if the brush roll is made of wood. Dust and debris can also accumulate behind the end caps of the brush roll causing friction which can cause a burning wood smell.
Mar 30, 2014 | Kenmore 5055, 50557 and 50558...
I have the model 36932 with direct drive. lately, there is the distinct smell of rubber when starting up and running. There is no belt on this machine. What could be causing the smell? roger
Check that the rotating brush is not seized and the belt is not slipping on it or the motor drive shaft. The belt will burn through if the machine is left to run any longer.
Feb 02, 2011 | Kenmore 31913 Progressive Direct Drive...
Kenmore vacuum model 116.3592250 works fine, burn smell
is that the one with the direct drive brushroll? those brushroll motors inside the brushroll always go bad. that is one of the worst designs from kenmore. is the brushroll turning?
Dec 31, 2009 | Vacuums
Kenmore Elegance Upright Bagged Vacuum Belt Broken and Smelling
It sounds like the brushroll has caused your belt problem and will be the cause of your burning smell as well. What commonly occurs is that carpet fiber,hair,string, thread,etc got wound around the brushroll and some will get caught in the end caps which is where the bearings are.The end caps need to be removed and cleaned so that the bearings can allow the brush to rotate freely.Check that there is no melting of the end caps or the base plate where the end caps fit into the machine._Good Luck
Oct 26, 2008 | Kenmore 34612 Bagged Upright Vacuum
Upright Vacuum Cleaner Lost Suction
If you had the dryer sheet under the intake filter for any length of time you risk burning out the motor . If
it smells like burning hair and plastic then the motor is toast. Also check the hose and dust passage, but I fear that it is the motor.
Sorry...
Sep 24, 2008 | Kenmore 31913 Progressive Direct Drive...
Burning smell from motor...what needs replaced?
Without the complete model number, I don't know for sure what componets you have, most likely is the motor. You will have to take the motor cover off and check it out. You can go to sears.com, click on parts, enter your complete model number, scroll down to cannister and it will bring up a parts list where you can order parts, also a diagram of the cannister.
Jul 05, 2008 | Kenmore 25812 / 25813 Progressive Bagged...
Smells like it is burning up when I use it!
You should unplug the machine, then remove the plate that covers the beater bar. Remove all debris from the beater bar, (strings, hair, etc.) and insure the belt is in proper position. If you have run it very long out of proper position, it may require replacement. Next before you put it back together remove any debis that may have collected in the intake behind the bar. You can also lubricate the bar with machine oil or WD-40.
Mar 09, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Vacuums Logo
248 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
