Question about Frigidaire FWS833A Top Load Washer
Spins but wont drain has a slight burning smell
  • Frigidaire Master
  • 43,501 Answers
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Posted on Apr 05, 2011
Wont drain..door locked..what do l do?
put drain hose below water level when empty should spin
Apr 17, 2015 | Washing Machines
Washing machine has smell (burning) and doesnt spin or drain tub.
Sounds like the belt may need to be changed. it eh pulley are spinning but the belt is not, nothing will spin and the friction of the pulley against the belt will cause a burning rubber smell
Nov 27, 2013 | Washing Machines
Water wont drain from tub error code nd
Leave a comment if you need more help.
Thanks for using Fixya.
Oct 07, 2012 | Washing Machines
Hi My F&P washer has been doing a error 51 for a couple of weeks, havent had a chance to get someone to kook at it, I stop it and restart it and it washes all the way through the cycle only did this on...
Error code 37 indicates a blocked or not working drain pump but the slight burning smell likely indicates a burned out drain pump motor. Do not use the machine unless the drain pump problem is addressed as it will result in the damage of the motor controller module. It has been found that electrical problem in the drain pump motor leads to the burning out of the motor controller module.
Error code 51 indicates a blocked or damaged diverter valve. It is where the drain pump and the recirculation pump inlet hoses are attached from. It works in directing (diverting) water to the recirculation pump during the wash stage and to the drain pump during the drain and spin stages. Click on the link below for the troubleshooting details of this problems.
Troubleshooting Fault Code 37 on Fisher and Paykel SmartDrive and EcoSmart Top Load Washing Machines
Mar 17, 2011 | Washing Machines
I got an estate whirlpool washer and it wont spin and i smell a burning smell
YOU HAVE SOMETHING STUCK IN THE WATER PUMP OR YOUR MOTOR COUPLING IS BAD
Jan 15, 2010 | Estate TAWX700JQ Top Load Washer
Washer wont spin, smells like burning glws1649
Burning smell could be the windings in the motor. Better not to use it and have it looked at. If the smell is a rubber smell then the belt is jammed while the motor spins. still needs intervention as it can catch on fire and you will have a bigger problem than the one you have now
Jul 31, 2009 | Frigidaire Washing Machines
Agitator spins slowly and wont drain water-slight burning smell when operating
Hi, Th smell is most likely the belt. If the washer is not draining, the pump could be locked up and this will cause the belt to smell.
The pump is located underneath rear right corner. If you set the drain hose itno abucket and get the water out. you can tip the washer back and see if the pump is froze. I see you posted this premium but I didn't get to it in time cause I was asnwering this.
Hope it helps
Vic
Jun 21, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Frigidaire FWS833A Top Load Washer Logo
172 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
