When i open my computer it will only display red in the monitor can you help me fix this problem?
  • 27,725 Answers
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they are probably old and faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error
hope this helps
Posted on Apr 05, 2011
Monitor flashes logo and then turns black.with red lights on
Here's some tricks I would try. Something here, might help...
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or orange or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your monitor on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Good luck.
Aug 07, 2014 | LG Flatron Computers & Internet
Red pixels
Try connecting an external monitor to the computer and check if the external monitor displays the same thing. If the external monitor is fine then you would need to fix the LCD of your laptop. or have it replaced.
If the external monitor displays the same thing, then you would need to update the video driver in your computer. You can use RadarSync to automatically update the drivers.
David
May 30, 2013 | Computers & Internet
No red color displayed
If all software setting done perfectly but till color problem in your monitor, then need to call monitor technician. It may occur from crt neck base loose contact or bad contact. need to replace new one.
normally no need to discharge crt capacitor for repairing dry soldering.
Apr 10, 2012 | LG Studioworks E700S 17" CRT Monitor
How to Fix display problems ( red display, or only for about 2 seconds display)
There are two problems, screen goes black after 2 seconds, red only. The problem is in the video processing board located on the back of the picture tube, it is well shielded against outside interference.
Apr 07, 2012 | IBM J156-1702 17 in.CRT Conventional...
The monintor will not display, the red on off button keeps fading in and out and will not turn green
Check the pwer supply section first.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed SAMSUNG monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Jun 01, 2010 | Samsung SyncMaster T200 LCD Monitor
My new monitor will not display RED. All the
Check for a bent pin in the VGA connector. Each color, Red, Green, and Blue has its own pin for the signal. If its pin is bent then no color!
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 29, 2009 | Samsung SyncMaster 930BF 19" LCD Monitor
Samsung samtron 55v display problem
assuming that u r a professional..
i guess there is no problem with ur monitor, it sounds like itz due to graphic adapter..either the adapter on ur system main/mother board/agp/pci/pcie is damaged or itz simply 'driver corruption'..
don't panic..check for driver update/download n reinstall graphic/display driver..
however, 1st make sure that the Screen Resolution (1024x768 or as applicable) and Color Quality (32 bit or as applicable) is correct..from Display Settings->Settings tab..
always better to contact system admin/vendor....
Dec 30, 2008 | SAMTRON 55V 15" CRT Monitor
Can you help me to fix my monitor?
Check the connector of the Pc sometimes if don't put it right make those simptoms.Good luck
Jun 03, 2008 | ViewSonic VE710b 17" Flat Panel LCD...
Red line
The display cable in your LCD monitor must be replaced.
If you are feeling adventourous then you can look on ebay for a display cable to install but I do not suggest anyone open up a monitor (LCD or CRT) who is not "technically inclined."
If you can get the part then I would take it to a local Tech to replace it.
Mar 14, 2008 | Acer AL1916W 19" LCD Monitor
Samtron monitor color display 56V
there are 15 Pins in Monitor cable which is connected to VGA port on the rear side of the Tower. First, we need to reset BIOS settings, and then try again - onboard video card only. for Add-on Video card try reseating video card in diff. slot if possible / reseat video card and try again. if it does not fix it, it could be the problem with Monitor RGB Connection - near the electron gun in the monitor CRT tube. resolder RGB , it will fix it.
by
Kasi M
Nov 14, 2007 | LG Flatron L1750S 17" LCD Monitor
Computers & Internet Logo
12 people viewed this question
David Payne
David Payne
