Question about Greenlee Dm-60 Digital Multimeter
Dm-60 Has been setting on the counter for a couple of years. Measuring dcv, on a 9v battery, readout is unstable and lower than it should be. Measuring acv, reading is about half what it should be. There is a very slight scorched smell but circuit board and components look pristine.
  • 27 Answers
If batteries are fresh (low batteries give false readings on the meter because the meter uses the batteries to benchmark what it is testing), then you might want to consider taking the meter back even if it has been a couple of years. If that is not possible for you then try calling Greenlee themselves and seeing if there is a warranty on the meter-some meters have 7 year warranties.
Hope this helps, James
Posted on Apr 05, 2011
  • whyniger Apr 30, 2011
    I replaced the battery again and let the components set open for a couple of days to dry out any moisture I might have missed.
    Meter is assembled and working fine.
How do i reset my digial bathroom scale
Remove all the batteries. In ones with memory, there are two sets, a 9 volt and 2 x AA.
The GNC WirelessWeight GS-7006 Digital Bathroom Scale accurately measures weight, body fat, water hydration, bone and muscle mass. This item features a removable wireless display that can be conveniently mounted on the wall, so you can see the readout clearly. Built with durability in mind, the scale is made from extra-strong tempered safety glass. The GNC bathroom scale also features an energy-saving auto on/off function and auto zero.
  • Removable wireless wall mount readout display
  • Measures weight, body fat, water hydration, bone and muscle mass
  • Energy-saving auto on/off and auto zero
  • Extra-durable tempered safety glass
  • Weight capacity: up to 330 lbs
  • Requires one 9V and 2 AAA batteries (included)
Jul 16, 2015 | GNC Digital Bathroom Scale
Battery replace
small door on back side (opposite meter), located at the rear of the tape - press down with thumbs (toward center of case) and back - door pops open - 9v battery underneath
May 06, 2014 | Seiko Hc500 Protape 16' Electronic Tape...
How to test aa battery with greenlee dm-20
se the meter to dc volts. if is not automatic, it should be set at the 3 volt scale. Take the red lead of the meter and touch it to the positive side. The black goes on the negative side or the 'bottom, of the battery. Brand new it ill be about1.6volts+-5%. its usefullness is comprimised at 1.4 or 1.3, depending the appplication. Be sure the leads to the meter are in the correct sockets,
Mar 27, 2013 | Greenlee Dm-20 Digital Multimeter
I need a copy of the user's manual for a Greenlee DM-60,I lost mine.
ndiaztorres-
The manual is available at: Link
If this has been helpful, please take a moment to give me four thumbs up.
Regards,
DIYpro
Apr 30, 2011 | Measuring Tools & Sensors
Greenlee dm-60: not working
check internal fuse , check battery , check probes to make sure there is no break in cable
Jun 16, 2010 | Greenlee Dm - 60 Digital Multimeter...
Over chargeing up to 16.8 volts, two bench tests of alternator says it is ok
How are you measuring the 16.8 volts? Is this what your cars readout or gauge reads? Maybe gauge bad. Or are you measuring with a volt meter at battery with engine on? Then regulator on alternator has to be bad. After you drive car is battery overheated? If you look inside battery is it almost boiling? Bad alternator regardless of tests.
Mar 15, 2010 | Cadillac Eldorado Cars & Trucks
2000 Hyundai Accent
00-30-001 2000 ACCENT DMTL DIAGNOSIS: DTC CODES P1401, P1402 AND P1403
p1402 - dm-tl air pump motor is shorted or disconnected.
2000 model year accent is equipped with a new enhanced evaporative emission system. this new system is capable of measuring leaks as small as 0.020" diameter. the new system pressurizesthe evaporative emission system with a diagnostic module for tank leakage (dm-tl), while the previous model's system appliedengine vacuum through the purge valve to detect system leaks.
service information
vehicles that have the check engine light illuminated and have dtc p1401, p1402 and p1403 stored in the ecm should have their electrical systems diagnosed related to the appropriate dtc. these codes are not related in any way to an evaporative emission system leak. the conditions that set the diagnostic codes areas follows:
p1401 - dm-tl air pump motor current draw is higher or lower than expected (normal = 17-36 ma).
p1403 - dm-tl changeover valve is shorted or disconnected
Jun 04, 2008 | 2000 Hyundai Accent
Computer codes
service information
perform the suggested repair
1. inspect for water in the dmtl by removing the 90° air inlet elbow and looking into the air chamber. if water or corrosion is present, replace the dm-tl p/n 31440-25500; air filterp/n 31453-25500; and pipe assembly p/n 31454-25500if corrosion is in the pipe. see detailed instructions on page3 for air filter replacement.
2. inspect for underbody coating sprayed into connector m52 at dm-tl. if underbody coating is present on the male or female connector, spray with electrical contact cleaner to remove the undercoating.
air filter (dm-tl) replacement instructions
  1. disconnect the 90° elbow from the top of the dmtl and insert a clean rag into either the elbow or thedmtl inlet connector.
  2. disconnect the dmtl electrical connector.
    1. disconnect the 2 hoses at the front of the canister (caution: silicone hoses tear/puncture easily).
    2. remove canister assembly and dm-tl as a unit (3 mounting nuts).
    3. disconnect the 2 hoses from the metal transfer pipes.
    4. remove the canister, air filter, and metal tube assembly from the canister protector by removing the 3 mounting nuts.
    5. disconnect the hose at the air filter.
    6. remove the air filter mounting nut and remove the air filter.
    7. install a new air filter.
    8. reassemble in reverse order.
Greenlee Dm-60 Digital Multimeter Logo
116 people viewed this question
Top Greenlee Measuring Tools & Sensors Experts
Wbix
Vuk B
Tom Chichester
Are you a Greenlee Measuring Tool and Sensor Expert? Answer questions, earn points and help others
