Question about Garden
I received a reconditioned Bostitch 1850bn and compressor. None of the fittings seems to work with the nailer.
  • 8,404 Answers
Get the proper fittings at your local auto parts store. They come "A" "B" "C" "D" style and some others. Yours is probably a "A" but take the one you want to match with you.
Posted on Apr 05, 2011
How to disassemble stanley bostitch sb1850bn nailer
very carefully as springs like to FLY then hide from us . but does it need disassembled . what is it not doing , or doing wrong .
Aug 31, 2015 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
How do I remove the trigger valve assembly?
i would just look on the box or go to the company website and ask them
Sep 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
Replace seals on bostitch sb-1850bn pin nailer
First make sure to get your parts from a service center or directly through the Bostitch Servicenet site online,,,shipping is a little high but you will be getting factory spec parts,,I usually get two of each of parts that I need just in case
Jun 30, 2013 | Air Tools & Compressors
Replace driver unit bostitch sb-1850bn
try going to a service center or order direct from the Bostitch Servicenet website
Driver stays out after firing
You probably have a worn air seal. Or perhaps some pneumatic tool oil might do the trick. A few drops in the air outlet then bumb some nails into a piece of wood.
Apr 18, 2013 | Stanley Bostitch Sb-1850bn 18-gauge Brad...
I do not know how/or where to insert the end of the hose to the Bostitch 1850BN compressor.
http://www.docstoc.com/docs/56973363/Factory-Reconditioned-Porter-Cable-C2002R-Oil-Free-UMC-Pancake-Compressor
Usually when buying new/reconditioned it doesn't have the female coupling installed.You need to buy it separate and a roll of Teflon tape.On your model its to the right of the psi adjustment knob.Take a look at the link,it connect to the 2 brass peices on the front right.Good luck.
Feb 22, 2011 | Stanley FactoryReconditioned Bostitch...
New model sb-1850bn will not operate at all. Oiled it lightly before trying to use. Air comes out around trigger.
If the air is coming out of the trigger when you try to drive a nail, most likely the driver is broken.
Bostitch nailer have a 7 year warranty on them so, take it to a Bostitch service center and have it repaired there.
Dec 16, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a SB-1850BN Bostitch finish nailer that no longer shoots nails. I think it may be a o-ring in the cylinder but not sure. Is there an easy fix for this situation?
Generally speaking an O-ring kit will resolve this type of problem. Check with your local lumber yards that sell Bostitch products. They may have a Bostich Day at which, for a purchase of nails or some other Bostitch product, the manufacturer will give up to 2 tools a quick overhaul including replacing the O-rings.
Dan
Jan 11, 2010 | Stanley Air Tools & Compressors
Describe your Stanley Factory Reconditioned Bostitch U/CPACK270 Finishing Nailer, Brad Nailer/Stapler & Compressor Combo Kit ProblemCompressor builds to 80PSI and will not shut off or build...
sounds like an air leak of some sort. when you get it up to as high as it will go, turn it off and listen for an air leak. Let me know where it is leaking and i will tell you what to fix
Jul 13, 2009 | Stanley Factory Reconditioned Bostitch...
BostitchCAP60-OF won't pressure up past 95lb and keeps running
This comperssor is oiless thus has a vinyl piston ring that wears quite fast depending on use and conditions at the work site. Slow pressure build or cycle never completes indicates a worn cylinder and piston ring. I would replace the cylinder, piston ring, valve plate, and intake valve. These parts are not expensive and available at www.bostitch.com. enjoy
Dec 01, 2008 | Stanley Factory Reconditioned Bostitch...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
