Question about Garden
Repair pull start rope on victa utility mower
    President:
  • 1,273 Answers
Hello, W/D here.
Here's a link to a number of videos that are sure to get you going. Enjoy.
Best regards, --W/D--
Posted on Apr 05, 2011
Lawn mower rope pully repair
if rope to long then pull out recoil one turn hold rope tight pull knot out of handle down rope rope to were you are holding it tie a knot in rope slowly let rope go back in recoil then pull it all the way out should fit now cut off excess rope but also if you have a long rope it is suppose to mount on handle should be a mount hook for on the handle
Sep 05, 2014 | Garden
Pull rope will not pull
Remove recoil rope assembly. Ensure rope is properly wrapped around. While recoil assembly is removed use ratchet and socket to rotate fly wheel, remove spark plug first, observe compression and exhaust at spark plug whole during rotation of fly wheel. Clean or replace spark plug. Ensure oil is full. 30w. Set spark plug gap. Always use Stabile in gas. Replace coil rope is required. Purchased by the foot at any mower repair store.
May 12, 2013 | Toro Super Recycler Super Bagger Lawn...
My Victa push lawn mower won't shut off. Throttle cable pulls back but won't push forward and springs underneath housing seem extremely loose. What do I need to repair/replace?
Sounds like the inner throttle cable is binding with the outer casing,
This coule be caused by dust and moisture causing rust on the inner cable. I would firstly try to get a light spray lubricant into the outer casing .
I would disconnect it from the throttle lever and spray lubricant onto the inner cable and progressively work the throttle lever to draw the fluid into the outer case. Elevate the lower end so gravity will assist you.
Feb 03, 2013 | Garden
Victa v160 runs for a while then stops
Ignition module is failing
Oct 14, 2012 | Garden
Starter rope broken on victa mower. how do i rewind. Itwill not recoil once pulled out
It sounds like the recoil spring is broken. Take off the recoil unit and remove the pull plate replace the spring if it requires itl davidson lawn mower tech
Feb 08, 2011 | Garden
The recoil spring on my 1986 victa lawn mower will not rewind the starter cord. Is this easy to fix?
Hi and welcome to FixYa, I am Kelly
- Remove the recoil assembly. Depending on engine model you may have to remove the air shroud with the recoil.
- Remove the broken rope assembly from the spool by lifting the knot out of the hole and cut off the knot.
- Pull the remainder of the old rope out of the recoil spool
- Take the remainder of rope out of the pull handle
On the new rope burn the ends with a match. With wet fingers pinch the ends of the rope while hot/melted until it is the same size as the rope. Form a point on the ends
- Install the new rope in the handle by threading it into the handle and tie ONE small knot on the end.
- Pull very hard on the rope until the new knot seats in the handle. Assemble handle.
- PREWIND the spool in the recoil until it stops winding. I.e. max out spring tension but do not over wind it or you will break the spring. Make sure NOT to wind it in the wrong direction or you will break the spring
- Back off the spool until the knot hole is aligned with the rope guide bushing on the outside of the recoil.
- Either use a C-clamp or a 2nd person to hold the pre-wound spool in place.
-Thread the new rope through the outer rope guide and into then through the knot hole in the spool.
-Tie ONE small knot in the rope and pull it HARD back into the knot hole until the knot seats in the knot hole.
-Release C-clamp or have 2nd person let go of the spool. The rope will rewind into the recoil assembly.
-reinstall recoil/air shroud on the engine.
That should get you mowing again.
Thanks for choosing FixYa,
Kelly
Dec 03, 2010 | Briggs & Stratton Garden
I am after a victa mower 2 stroke repair manual
I have a victa workshop manual covering some of the older models which i would be willing to copy the relevent pagesfor you. or might be able to give you soom tips, what model do you have and can you discribe the carburettor, soom victa's use a very odd carb made of plastic
Nov 21, 2009 | Garden
How to replace starter cord on a victa corvette 400 series mower,cord snapped,i put it back on....now it doesnt retract properly when trying to start it
Not sure what engine that machine uses but they are all similar, you need to prewind the reel before you slip the rope thru the hole, let the spring/reel pull the rope in.
Nov 15, 2009 | Garden
Replacing starter pull cord on Cub Cadet mower
1st get same size cord 24" long .remove pull start assy. remove old rope.burn & smash ends flat of new rope(helps it go thru holes on pulley & cover easy). tie small knot in 1 end of rope. unwind spring pressure like if rope is pulled all the way out when starting.align holes in pulley & cover .fish rope thru holes start on pulley side, out thru cover so knotted end on pulley side.when ropes thru slip handle on .rewind spring will wind itself pulling rope in . your done
May 05, 2009 | Garden
Garden Logo
161 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
