Question about Spektrum Dx5e Dsm2 5-channel Air Radio and Ar500 Receiver
Plugged in charger and got not light on charger for transmitter. Replaced rechargable batteries with AA's turned on transmitter not lights on transmitter. Rechecked polarity on batteries and they were in place correctly. Is there a fuse? Is there anything else I can do
    Problem Solver:
  • 12 Answers
What charger?
it needs to be designed for that particular transmitter, four cells, reverse polarity to Futaba and Hitec
http://www.rcgroups.com/forums/showthread.php?t=839823
Posted on Apr 05, 2011
I don't think its even charging.. the red light is on but thereis no white light on on the usb arm. Its been plugged in for 3 hours now and some time yesterday too
Your problem is with charging the camera battery? If so check make sure you have the battery or batteries in their correct orientation as in + to + and - to - also and this happened to me I neglected to remove the protective clear plastic packaging from the terminal posts which didn't allow the battery to make contact. If your camera uses AA type batteries make sure the batteries you are attempting to charger are the rechargeable type, AA Alkaline batteries are not rechargeable
Dec 26, 2010 | Cameras
Re: Battery Charger BC-45W I just purchased a Fuji JZ500 and the battery needed to be charged. When I plugged the charger into the power outlet, the indicator light (yellow) turned on but after a few...
Ok all mine had the same problem however problem has been solved! The power cord that plugs into the charger is a common cord you may have laying around the house. I switched the power cord to my charger and the dreaded blinking stopped! Its just a bad power cord to the charging unit! Hope this helps!
Dec 23, 2010 | FUJIFILM BC45W Rapid Travel Battery...
Red light is flashing off and on
Please refer to your charger user manual: but in general, this indicates that the charger has determined that one or more of your rechargeable is faulty (despite the fact that it may still hold a partial charge).
Smart charger can measure the expected voltage and current flow and will prevent any 'faulty' cells to be charged (those 'faulty' rechargeable batteries may actually still be useful and charged on other less intelligent charger). Try charging them individually (if your charger can handle individual battery) or in different pair combination to locate flaw cell.
Hope it helps.
Jan 28, 2010 | Duracell AA/AAA NiMH Battery Charger with...
When I insert some batteries the red light begins blinking. I also have some Duracells that appear to be charging but when I place them in the appliance they are dead.
All chargers cannot charge all types of batteries. Are your Duracell batteries NiMH or Alkaline? These indications generally happen when you insert a battery type that is not rechargeable.
Dec 13, 2009 | Duracell AA/AAA NiMH Battery Charger with...
WORKING INSTRUCTIONS FOR NIMH CHARGER NO LIGHTS COME ON NOT GREEN
one problem here could be the contacts btetween the batteries and the charger , had a similar problem myself and found bu using a very small , mean small too , you can slightly bend out the contacts and hopefully presto , contact has been made , lights come on and batteries are charging , make sure its not plugged into the wall when you do this , and only use very slight pressure on the contacts
Jul 04, 2009 | Energizer NiMH Compact AA/AAA Battery...
Cant charge battery pack for wii fit balance board
You may want to send an email to customer.services@gem.co.uk. In the meantime, try keeping it plugged into the USB port for at least an hour, or perhaps overnight. See if the light stops flashing and stays on. Then try plugging it back into the Wii Fit unit.
My personal suggestion is to return the charger and battery and buy a 15-minute charger and four more NiMH AA batteries than you need for all of your accessories. Not only are AA batteries compatible with all your accessories, but you won't be out a gizmo while it's needing to be charged.
Jan 27, 2009 | Nintendo Rechargeable Battery Pack 3600mAH...
What color should LED be when charged on duracell NIMH charger
When the batteries are charged fully the light should be green.
Nov 27, 2008 | Duracell NiMH AA/AAA Battery Charger with...
LED Light on or off indicator
on my charger the red lights are only to tell there is power connecting especially when you have two battery's behind each other on the bottom of my charger there is a guide as to how long you should charge each battery as to size which are aaa 7hours max
aa 24hours
c 24hours
d 24hours
9v 24hours
hope this helps glenn............
Nov 20, 2008 | Duracell AAA NiMH Battery Charger with 4...
Spektrum Dx5e Dsm2 5-channel Air Radio and Ar500 Receiver Logo
166 people viewed this question
Top Spektrum Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Spektrum Toy Expert? Answer questions, earn points and help others
