Question about Dell XPS 430 (DXDOBG1) PC Desktop
How can you get to the inside of the Dell XPS 430 system to mount a new dvd drive, the left panel can't be removed
    Genius:
  • Dell Expert
  • 1,325 Answers
Hi there
go to this DELL
site, it gives you illustrated instructions
http://support.dell.com/support/edocs/systems/xps430/en/SM/drives.htm#wp1594978
if this helps, please rate my service
thank you for using FIXYA
Posted on Apr 05, 2011
DVD Burner in my Dell XPS just stopped working?
Check both ends of the data cable for looseness. Check the power plug on the back of the DVD player too. If all is correct then the player itself has failed. It does happen.
Mar 29, 2016 | Dell New XPS 8500 Mini Tower PC i7 3.40GHz...
Dell xps 2720 dvd drive will not eject cd inside
Turn system off and use a paper clip to manually open the drive door. Straighten a paper clip, then insert it in the small opening to the right of the eject button. This should manually open the door and you can remove any disks in the drive. Then reboot and see if it will open and close normally.
Jan 10, 2014 | Dell (0F146) Internal DVD Drive
INSTALLING A NEW HARD DRIVE
WARNING: Before you start troubleshooting remember that you are dealing with electricity that can KILL. http://www.kitchentablecomputers.com/static.php - rules Only work inside the computer case when the power has been switched off and disconnected. Never open the power source. Some of the below steps recommend removing physical parts within the computer. While in the computer it is highly recommend that you be aware of ESD and its potential hazards
http://www.youtube.com/watch?v=A7R5VYsdxIg http://www.youtube.com/watch?v=TyS3-elMozk Hope it helps.
Jan 10, 2013 | Dell XPS 430 (DXDOBG1) PC Desktop
Alert chipset heat sink not detected system halted dell xps 420
Sounds like your heatsink which is inside the computer and sits on top of the CPU is bad. There will probably be a fan that sits on top of the heatsink.
Look on ebay and purchase one for your system.
http://www.ebay.com
I found a new one below on ebay for $14.95 (the link is below)
http://www.ebay.com/itm/New-OEM-Dell-Dimension-9100-XPS-420-430-Heatsink-Assembly-XP850-/350520689627?pt=LH_DefaultDomain_0&hash=item519ca943db
May 12, 2012 | Dell XPS Computers & Internet
Replacing the dvd drive in my Dell Studio XPS 1640. Following instructions from Dell and CANNOT remove the palm rest as described. ...
Remove 10 screws (back plate)
Remove all screws labelled P (as well as black sliding plates)
Turn over and remove two screws under these plates
remove two screws (bigger than the others) from from top of keyboard.
lift full front panel from the back corners (two sticky-out bits on the inner side of the hinges to the screen)
Job done
Apr 19, 2011 | Dell Studio XPS 16 Notebook
My daughter put two cd in my dell xps m1530.any idea how to get them out
Please try the following:
On your dvd drive there is a very small pinhole. Get a paperclip and try to push it through. This pinhole is used for emergencies where the dvd drive does not eject.
Other thing you can do, is to turn your laptop upside down and remove the dvd rom drive from your laptop. Then unscrew the dvd drive to get the cds out.
Jan 31, 2010 | Dell XPS M1530 Laptop
How do I remove the DVD player from my Dell 1530 XPS laptop ?
download the service manual via this link: http://support.dell.com/support/edocs/systems/xpsM1530/en/SM/HawkeSM0_H.zip unzip it and run the index.html file, this with open a local webpage with various options on it. Select 'Optical drive' this will then give you a step by step guide on how to remove and replace the DVD drive, it even includes good detailed pictures. remember to follow the instructions carefully. Hope this helps.
Nov 25, 2009 | Dell XPS M1530 Laptop
My computer keeps going into power save mode dell xps 430 desktop
What operating system are you using? If its windows in the control panel there will be a power management option. Go to that and change the settings for standby mode
Sep 20, 2009 | Dell Studio XPS 435 PC Desktop
Dvd stuck inside slot drive, system had crashed
hello..to get out you`re CD/DVD its very simple you need a small Pin like a paper clip then find the small hole the front side of DVD/CD player and push the hole using the paper clip..about this question kindly Verify>(plus i had already installed the new hard disk because the old one crashed)..what is it??...Thank you
May 08, 2009 | Dell XPS M1330 Notebook
DVD drive bay
yes you should be able to play CD on the DVD reader.
Dimension 2400 have drive slide mounted on the side of the hard drive, cd drive and floppy. they are different for each device. you need the 2 side mount for the dvd. in order to mount them in the Dell.
the drive is inserted from the inside of the box toward the front. The front panel will prevent the device from pop out.
yes, 3 party DVD, CD drive will be shorter and fater that what Dell porvide, but it will work, al long as the opening is accessable.
get the HP DVD driver.
Nov 04, 2008 | Dell Dimension 2400 PC Desktop
Dell XPS 430 (DXDOBG1) PC Desktop Logo
mukhtar21 shaikh
mukhtar21 shaikh
