Question about Epson Stylus Photo 820 InkJet Printer
820 ink problem
My printer is set to use black ink only, but uses same amont of color ink as the black ink, is this right. thanks Everett
  • evestal Aug 14, 2008
    Thank you, ill try it, Everett
Hi Evestal,
I've noticed the same thing on my Epson Stylus Photo 820 ink status monitor. If it's set to use only black ink, then logically it shouldn't actually be using any color ink other than when it does a cleaning cycle. Truth is... the built in monitor counts at the same rate for color and black regardless of the true levels. So, unfortunate consumers are likely to restock prematurely on expensive cartridges if they aren't aware that monitor is counting prints, and not actually measuring ink.
I've bought refill kits made by JetTec at Staples and they make a Re-Setting Device for cartridges. Lately my local Staples have stopped carrying this brand but I'm know they're available online. The re-setter is a little plastic device with and LED light that changes color after you match up it's little metal prongs with the microchip on your cartridge to indicate that it has been re-set. Just follow the directions that come with the re-set device. This is also a good way to get the last remaining bits of ink out of cartridges when they're low. The Epson print counter stops you from printing once it "thinks" it's out of ink but the reset device convinces it otherwise untill you really do run out.
Hope this helps. Good Luck.
Posted on Mar 19, 2009
I want to use only the black ink cartridge. How do I change the printer from using color ink cartridge to black only? Right now, it is set to use color ink only and when I depress the "Black" button, it...
Check the Canon control panel that came with the printer (they are not the same from one model to the next) and check for a setting for 'Gray scale.' If you are printing only text, it should default to the black cartridge.
Aug 17, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Out of ink?
Many printer cartridges may have ink but the printer believes otherwise. Often this problem can be solved by placing a small piece of black tape over a window in the cartridge that the printer looks into to identify ink level. If you cartridge has such a window, try a piece of electrical tape. You might be surprised.
May 08, 2010 | Epson Stylus Photo R800 InkJet Printer
I want to use black ink only and stop wasting color ink
Go to Control Panel->Printers. Then right click on your printer and select printing preferences. There you will see an option like Print in Grayscale or Black and White only.
However, please note that some printers although they are set to print in grayscale they also use the color cartridge and some even don't allow you to print in grayscale if the color cartridge is empty. Why is that? Manufacturer's way of charging you more money.
Feb 11, 2010 | Canon PIXMA MP470 All-in-One Printer
Why does color ink in Photosmart C7280 go down when you are only printing using black ink
Unless you set the printer settings to black and white it mixes colored ink to create black. It does this by default. Go to start printers and faxes. Right click on printer icon.Click printing preferences to change this.If youre using hp tool box setting is grayscale black only.
Hope this helps.
Plaese leave feedback.
Dec 10, 2009 | HP Photosmart D7160 InkJet Printer
Can i print black and white text only when colour cartridges are empty but black is full on an ip14300?
you can make a selection from the File->Print option of your word processor or whatever package you are using. it is your command that sets the printer to B&W or color. If your Black ink finishes then the printer even if set to color will print black as near black with color inks.
Sep 14, 2009 | Canon PIXMA iP4300 InkJet Photo Printer
I want to print with black ink only. Where do I
what are you trying to print?
You will need to change your printer settings ... go to the properties of the printer and then select printing prefrences there should be an option to just print black and white only ...
Also this model will not print if either cartridge is empty ... black and colors are necessary to be full .. but you can change and set the default to be black only
Mar 23, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
Print in black ink only
You can try by going into the printers options from the control panel "Printers and scanners" then right click the printer you are referring to and click on "printing preferences"
Click the Tab "Color"
and Check the "Print in greyscale" box and apply
Please rate
Sep 17, 2008 | Epson Stylus 680 InkJet Color Printer
Epson stylus photo 820
Hi Ikarp9090
If both lights are flashing, it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from:
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (820), then close the ssc window. Now right click the ssc icon in the sytem tray and choose Protection Counter. You should see that the current count is above the limit; then choose reset to set it to zero. You will need to fib about having changed the waste ink pads! Turn the printer off then back on again. This will stop the lights flashing and restore normal operation.
However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you must change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back and I will provide further help. It is a pretty simple job once someone explains how to get the case apart!
If this solution helps you, please rate it; if it doesn't, please provide further information by posting a new comment.
Apr 29, 2008 | Epson Stylus Photo 820 InkJet Printer
Colored Ink problem
Make sure the printer settings are set properly to print in color on the PC. Even if there is a color cartridge, if the PC only tells it to print black ink it's not going to use the color cartridge.
Jun 08, 2007 | Lexmark Color Z35 InkJet
Epson Stylus Photo 820 InkJet Printer Logo
154 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
