Question about NEC Cell Phones
What does FDA FDN & MIC mean... flashing on my phone? I need a list of features and instructions, where can I find one
Hoe I do disable outgoing call FDN restricted
Fixed Dial Number (FDN), allows you to restrict outgoing calls to a limited set of phone numbers on your Samsung Galaxy Note 2.
How to enable FDN on Samsung Galaxy Note 2
  • From the Home screen, tap Phone icon.
  • Press Menu key and then tap Call settings > Additional settings > Fixed Dialing Numbers.
  • Tap Disable FDN.
  • At the prompt, enter your PIN2 code and tap OK.
Mar 10, 2015 | Samsung Galaxy Note II GT-N7100 16GB Gray-...
What does outgoing call are restricted by fdn mean
FDN(Fixed Dial Number) if enabled, allows you to restrict your outgoing calls to the limited set of phone numbers that are included in the Fixed Dialing Number list.
Jun 10, 2014 | Motorola Mobility Verizon Wireless Droid...
What does Fixed Dialling Numbers mean?
Fixed Dialing Numbers or FDN list is a SIM card based security feature which allows the phone to be "locked" so that it can only dial certain numbers, or numbers with certain prefixes.
A PIN2 code (numeric password) protects the allowed list of numbers from being changed by any person who does not know the PIN2 code.
In FDN mode, your device will restrict outgoing calls, except for the numbers stored in the FDN list.
To activate FDN mode,
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Enable FDN.
2.) Enter the PIN2 supplied with your SIM or USIM card and select OK.
3.) Select FDN list and add contacts to be used in FDN mode.
To De-activate
1.) In idle mode, open the application list and select Settings ? Call settings ? Fixed Dialling Numbers ? Disable FDN.
Warning: PIN2 is a serious SIM-based security feature of the handset. If you are not sure of your PIN2, please do not enter random PIN2. When you access a menu requiring the PIN2, you must enter the PIN2 supplied with the SIM or USIM card. Contact your service provider/ Network for your PIN2. If the wrong PIN2 code is entered three times in a row, PIN Lock(PUK2) will be automatically activated.
Oct 31, 2011 | Samsung I5500 Galaxy 5 Unlocked Android...
How to unlock my motorola from its fdn code
To unlock your mobile with codes are some what better for your mobile to use without any problem, because codes are the best way to unlock your mobiles , just simply follow the instructions & enter the code means automatically your mobile get as unlocked,
Just visit this site www.onlinegsmunlock.com , it has the step by step instructions for unlocking your motorola mobile from the network lock.............
Sep 12, 2011 | Motorola Cell Phones
LG KS 360. FDN enabled.. means what?
i have managed same problem as u. FDN means fixed dial number so all u have to do is to go in meniu...settings..security...and nr 4 is the submeniu u need.(just select stopped/turn off ..but be carefoul, it will ask you the pin2 of the sim u have in) After this,will appear a message" finalised" and u may call wherever u want.
Aug 27, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
WHATS A FDN?
FDN (fixed dialing mode) is the setting where you can't dial a number that's not in your sim card data. It is supposed to be used as a security measure when you're away from your phone and don't want someone to use it to make an unauthorized call -- unless the number is in your sim card you won't be able to make the call.
If this helps please vote.... I need the ratings. :)
Aug 07, 2009 | LG KS360 QWERTY Keyboard Phone BRAND...
Modifying FDN list of LG phone
how ca i find my FDN pincode if my phone is new never used I just baought
Jul 28, 2009 | LG Vu CU920 Cellular Phone
There is (FDN) Fixed Dail Number under, More then Security. Does anyone know how this works? LG VU CU920.
FDN is a feature that will limit calls made from the phone to only those numbers that are listed in the address book. If you do not have the number stored in your address book, you cannot call the number. This is useful for when you loan you phone to someone or otherwise want to limit the numbers called from it.
Apr 19, 2009 | LG Vu CU920 Cellular Phone
Blackberry 7100g
About fixed dialing
If you enable fixed dialing number (FDN) mode, your device only makes calls to contacts on your FDN list. Your device can dial emergency numbers in FDN mode, even if the numbers are not in the FDN list. If your service provider plan includes SMS, you can also send SMS messages to contacts on your FDN list
so if you have this enabled chances are you have to turn it off.
this is how you turn it on so you should be able to use it as a guide to turn it off.
Turn on fixed dialing
1. In the phone options, click FDN Phone List.
2. Click the trackwheel.
3. Click Enable FDN mode.
4. Type the PIN2 code provided by your service provider.
5. Click the trackwheel.
or if you wanna keep it on and add friends to the fdn
Add contacts to the FDN list
3. Click New.
6. Type a name and a phone number.
7. Click the trackwheel.
8. Click Save.
and finally some shortcut keys:
To open the phone, press the Send key.
To end a call, press the End key.
To call a selected contact or phone number, press the Send key. To call a speed dial number, hold the assigned key.
To add an extension to a phone number, press the X key. Type the extension number.
To call your voice mail access number, hold 1.
To type a letter in a number field, hold the Alt key.
To type the first letter on a key, press the letter key once.
To type the second letter on a key, press the letter key twice.
To turn on or turn off mute using the Mute button, press the Mute button.
To turn on or turn off mute using the keypad, press the exclamation point (!) key.
To turn speakerphone on and off during a call, press the period (.) key.
To change the volume during a call, roll the trackwheel.
Aug 02, 2008 | RIM BlackBerry 7100G Smartphone
Cell Phones Logo
150 people viewed this question
Top NEC Cell Phones Experts
Computer Repairing
Computer Repairing
Starnley Johnwells
Starnley Johnwells
Are you a NEC Cell Phone Expert? Answer questions, earn points and help others
