Question about Kohler - Toilet - Two-piece - Highline - K3427-RA-G9
What could be the cause of leak after installing new gaskets and screws, above back/rear screw? 1) not from screws 2)tank not cracked 3)securely tightened all 3 screws 3a)hand tightened(only)large flush valve nut
    President:
  • 1,273 Answers
Hello, W/D here.
Most probably, the tank-to-bowl gasket has not seated properly. They are usually neoprene, and tend to bight on the bowl socket rather than to slide into the socket where it can be compressed properly. Remove the tank bolts and look at the gasket. Re-install, using a water based lubricant on the bowl side, with the gasket installed on the tank flange. Wiggle the tank and gasket back and forth a few times, and the gasket will start properly into the cast socket on the bowl. Install the bolts and tighten to finger tight. Wiggle the tank a bit more, and level the top. Tighten the bolts uniformly.
You mention that the flush valve was hand tightened only. If this gasket is not snug (a bit more than hand tight), a leak can occur there as well.
Best regards, --W/D--
Posted on Apr 05, 2011
  • Dave Murphy Jan 21, 2012
    We too have experienced a steady leak through the bolts securing the tank to the bowl. We have adjusted the tank by wiggling the tank and gasket back and forth, re-tightened the bolts and still have a leak. We replaced the tank, installed the new one and have the same problem. Should we simply be able to place the tank on top of the bowl, tighten the bolts, and be able to use the toilet without it leaking? Is there a step that we are missing? Thanks!
We have a toilet problem now for 8 years since we bought our place,the toilet leaks onto our bathroom floor we know where the leak is someone have put silicone around the plastic valve right @ the bottom...
With out seeing it, it is hard to actually know what the problem is, but it sounds like it is either where the water line enters the tank, or the gasket between the tank and the bowl. Either way there should not be any silicone. The water line flows into the fill and shut off valve. If it is leaking from there get a whole new valve for under $20.00. For the gasket between the tank and the bowl you have to remove the tank and replace the gasket.
What many people are unaware of is a small crack in the tank and rarely a small crack in the bowl. If the leak is not from one of the two things I mentioned above it has to be a crack and in that case a new toilet.
If you can not tell where the water is coming from it could be a crack or the wax ring under the toilet may need replaced. You might want to call a plumber and get a free estimate on what the problem is.
Good luck with this.
Rick
Mar 11, 2013 | Toto Round Carusoe Two Piece Toilet, 1.6...
Replace fuel pump
Best to do this in a well vented area because of the fire hazard, so that the gas fumes don't accumulate.
1) Disconnect battery negative cable.2) Jack up car and support on safety Jack stands3) Siphon gas out of tank4) Remove three rubber hoses on rear of tank. These are used for gas fill up; remove hose clamps and disconnect.5) Remove three hoses from front of tank; these hoses go from the fuel pump to the engine. You'll need special fuel line wrenches for this.6) Disconnect two connectors at the front of the tank.7) Remove two bolts that hold the exhaust pipe heat shield. You'll want to use penetrating oil on these; they will be corroded.8) Support tank with a floor jack. Remove the bolts which hold the tank in place. Pivot the tank on the exhaust, tilt and slide out.9) The gas hoses are taped to the tank. Remove the hoses. The fuel pump plate has about 12 screws around it. Remove the screws. Lift the plate out. The fuel pump is retained with one screw. Remove the screw. Filter is retained with a clip; remove it.10) Get your new fuel pump ($250), the rubber gasket for the fuel pump plate, and new filter ($5). Compare the pump with the old one; it must be the exact lenght. I had to go to two different auto parts stores before I got the right one.Installation is opposite of above. Good luck!Fuel pump is not too tough. First, get a Haynes or Chilton manual for reference (about $14).Best to do this outdoors, so that the gas fumes don't accumate. If I recall correctly:1) Disconnect battery2) Jack up car3) Siphon gas out of tank4) Remove three rubber hoses on rear of tank. These are used for gas fill up; remove hose clamps and disconnect.5) Remove three hoses from front of tank; these hoses go from the fuel pump to the engine. You'll need special fuel line wrenches for this.6) Disconnect two connectors at the front of the tank.7) Remove two bolts that hold the exhaust pipe heat shield. You'll want to use penetrating oil on these; they will be corroded.8) Support tank with a floor jack. Remove the bolts which hold the tank in place. Pivot the tank on the exhaust, tilt and slide out.9) The gas hoses are taped to the tank. Remove the hoses. The fuel pump plate has about 12 screws around it. Remove the screws. Lift the plate out. The fuel pump is retained with one screw. Remove the screw. Filter is retained with a clip; remove it.10) Get your new fuel pump ($250), the rubber gasket for the fuel pump plate, and new filter ($5). Compare the pump with the old one; it must be the exact lenght. I had to go to two different auto parts stores before I got the right one.Installation is opposite of above. Good luck!
Read more: http://wiki.answers.com/Q/How_do_you_change_a_fuel_filter_for_a_92_geo_storm#ixzz27tyFTkDd
Sep 29, 2012 | 1990 Geo Storm
Could it be the inpulse pipe in the husky 50 rancher making it rave out some times
Certainly a fuel starvation issue, the impulse is a small rubber boot in the cylinder which seals a plastic tube in the back of the carb housing, if the boot has split it will cause problems, there is also a rubber indudction tube above it, make sure this is not split, fuel starvation can be caused by many things, blocked fuel filter in the tank, crack, split or bad fitting fuel hose, dirt in the carb inner screen, air leaks through crank seals or gaskets, lose carbs, incorrectly set up carb screws.
Jun 04, 2012 | Garden
Replace fuel pump 1993 mazda 323
REMOVAL & INSTALLATION
323, Protege, 520-22 626 and MX-6 and 522-24 MX-3 Models
See Figures 1 and 2
  1. Relieve the fuel pressure and disconnect the negative battery cable.
  2. If not already removed, depress the clips on each end of the rear seat cushion and remove the cushion.
Fig. Fig. 1: Detach the fuel hoses and electrical connections from the fuel pump, then remove the attaching screws and the pump
Fig. Fig. 2: Exploded view of the fuel pump assembly for the 323, Protege, 520-22 626, MX-6 and 522-24 MX-3
  1. If not already done, detach the electrical connector from the fuel pump/sending unit.
  2. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
  3. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
  4. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
  5. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
  1. Attach the sending unit to the fuel pump assembly and install the nuts. attach the sending unit electrical connector.
  2. Install the fuel pump/sending unit into the fuel tank with a new gasket and install the mounting screws.
  3. Connect the fuel supply and return lines.
  4. Install the access cover and the mounting screws.
  5. Attach the sending unit electrical connector.
  6. Position the rear seat cushion over the floor, making sure to align the retaining pins with the clips. Push down firmly until the two retaining pins are locked into the rear seat retaining clips.
  7. Connect the negative battery cable, start the engine and check for proper system operation and for fuel leaks.
May 08, 2012 | 1993 Mazda 323
My ryobi grass trimmer will only run on 1/2 choke model RY 30524
Check for fuel supply problems (clogged cap vent, dirty tank fuel filter, clogged or faulty fuel intake lines, leaky or cracked primer bulb, air leak in rear crankcase cover...check 4 screws above gas tank, air leak in carb gasket...check carb nuts, trashed up carburetor...needs cleaning or rebuild, mixture screws need adjusting)....a myriad of possibilities here but I would guess it's a dirty carb....hope it helps
Jun 27, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Iron leaking and plate dirty
If you have hard water, there will be a buildup of minerals where the rubber gasket on the water tank meets the steam chamber that is built into the sole plate. This will make the rubber gasket surface become hard and no longer seak to the team chamber, resulting in water leaking from the tank onto the outside of the iron.
If you are reasonably skilled with tools and have a Torx T20 driver, you can disassemble the iron and remove the rubber gasket between the tank and the steam chamber and soak it in vinegar to remove the mineral scale. First remove the three Torx screws visible at the rear of the iron and gently pry off the gray rear cover plate. This will expose two screws holding the rear end of the sole plate. Remove those two screws. Then gently pry off the stainless steel nose piece on the front of the iron; this is the curved piece that says "high precision" on it. This will then expose the screw that holds the front of the sole plate on the handle. Remove thqt screw. Pull the black connector at the rear of the iron off the two rods to which it is attached, and you can move the sole plate away from the handle. The rubber piece in the handle that is sort of oval shaped and about 2 inches long is the gasket that is probably causing the leak. Gently remove it and soak it in vinegar to remove the scale, and remove the scle from the round hole where it meets the steam chamber in the sole plate. .When they are clean, reassemble the gasket onto the handle and the sole plate onto the handle, connecting the electrical connections, and replace the screws, It is not simple, but it is doable.
Apr 14, 2010 | Rowenta DZ5080 Iron with Auto Shut-off
Gas Lawnmower start and then shuts off....
Ok here are 2 possible solutions.
1. If you have a mower with a sediment bowl under the carb and flat paper air filter, try this. Drain gas from gas tank. Remove the screw that holds the air filter cover. Replace air filter is dirty. Remove the two or three screws that are holding the flat plastic back of air filter cover. Remove the little gasket that is between the flat plastic back and sediment bowl. Make sure you remove all of old gasket. Clean the area around the sediment bowl so it is free of dirt and grim. Use a 1/2 socket (usually) and remove the bolt on underside of the bulb. The remaining gas in the bowl and a little left in the tank will leak out. I let it all run out so if any water is in tank it emptys on its own. Remove the bowl and clean it out with clean rag or paper towel. Use some carb and choke cleaner to spray the carb. Reattach the bowl, and tighten the bolt making sure the ruber gasket between the bowl and carb is not twisted or you will have leaks. Install a new gasket between carb and air filter back replace 2 or 3 screws and air filter and cover. Refill with gas, prime it and then try and start it.
2. If your carb is located ontop of the fuel tank, remove the cross tip screws that hold carb to tank and get a new diaphram (fuel pump in a sense). Replace diaphram and reassemble in reverse. You will have to also remove the bolt that holds tank to motor and the little metal rod that goes from the govonor to the choke.
From what you stated I would think it is number 1.
Good luck. Let me know if this helps.
roundo4
Aug 14, 2009 | Craftsman Garden
How do i replace the fuel pump in my 1993 mazda 626 2.5
3. If not already done, detach the electrical connector from the fuel pump/sending unit.
4. Remove the attaching screws from the fuel pump/sending unit access cover and remove the cover.
5. Disconnect the fuel supply and return hoses from the fuel pump/sending unit.
6. Remove the attaching screws and the fuel pump/sending unit from the fuel tank.
7. Detach the sending unit electrical connector, remove the sending unit attaching nuts and remove the sending unit from the fuel pump assembly.
To install:
Jun 13, 2009 | 1993 Mazda 626
Tank leaks
Call Hamilton Beach customer support at 1-800-851-8900. You need a whole new tank. For $5.00 shipping, they will send you a new one. They did me. The gasket that prevents this fell out of my model 47665 brew station. The tiny part that held it in broke and I called them to ask how to fix it. It can't be fixed but for five bucks, they sent me a whole new tank PROBLEM SOLVED!!!! I love hamilton beach. 1-800-851-8900 customer service. Good Luck to ya Katherine
Jun 10, 2009 | Hamilton Beach BrewStation 47224 Coffee...
Changing motor hayward 1.5 HP
Super pumps are very easy. If it is a northstar it is more difficult. Super pump. You will need 1 motor, 1 pump seal, 1 diffuser gasket, 1 housing gasket. turn off breaker, disconnect wires -noting whether it is 110 or 220 volts- , unscrew four bolts on back of pump housing (shaft side of motor), pull out motor with rear housing and diffuser (sometimes diffuser sticks inside), on wire side of motor hold shaft with wrench (flathead in some cases, but it is harder), unscrew impeller counter clockwise (like normal screw - you will nee a big pair of channel locks or a strap wrench), there are two pieces of the back housing and once the impailer is off you can remove the half that is closest to the end of the shaft to reveal four more screws, unscrew those four screws. screw back part of rear housing onto new motor. Install new pump seal to front part of rear housing and impeller, slide on front part of rear housing and then screw on impeller while holding shaft on wire side with wrench (only hand tight), replace housing gasket, replace diffuser gasket, slide into front housing and screw in four bolts. If electrical was 110 you will need to move the jumper on the wire end..if it was 220 then just hook kup wires...doesnt matter which is which as long as green or bare goes to the ground screw.
Mar 14, 2009 | Hayward 2HP Pool Pump Motor A O Smith...
Kohler - Toilet - Two-piece - Highline - K3427-RA-G9 Logo
244 people viewed this question
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
