Question about Sharp LC19DV27UT 18.5 in. LCD TV/DVD Combo
How can I change the subtitle settings on the TV? They set fine through the DVD settings but then don't appear on the TV screen. Thanks for your help.
  • Sharp Master
  • 2,098 Answers
Hi Wendy,
May I know what cord are you using to connect your DVD player to the TV, is it through the HDMI or RCA? Let me know to assist you further.
Jdvillanueva
Posted on Apr 05, 2011
  • Jdvillanueva
    Jdvillanueva Apr 05, 2011
    Please unplug your unit to the outlet then press power button on the front panel for 1 minute to drain the unit and make itself refresh. After that plug again to the outlet then power it on... select the DVD mode again then insert your disc to the player...
    Let me know if that helps...
  • Jdvillanueva
    Sorry I've mislook your model no., there's no cable connection required just select the DVD mode...
What button gets rid of subtitles that have just appeared on my tv. I must have pressed a button to start them but i dont know which one?
You are referring to closed captioning (CC) which is enabled/disabled by a button on the remote or by selection/cancellation during initial set up.
Oct 07, 2016 | Samsung Televison & Video
CC (closed caption) won't show up on DVD movies for LG 42CS570 hooked up with standard DVD player (not Blu-ray). How can I fix that?
Subtitle setting is in the dvd setting not the tv, If the DVD would have CC it would be on the case, CC is encoded in to the tv signal
Mar 01, 2014 | LG 37LP1D 37 in. LCD Television
Subtitles always on
Hi - welcome to FixYa,
There are 2 methods for changing the subtitle settings on your DVD player.
Method 1.
To turn off the subtitles on your DVD player during playback:
1. Press the "SUBTITLE" button on your remote control
The subtitle button is just below the "0" (zero) numerical key on the remote control. It is marked "SUBTITLE" above the button and the button has "ABC" written inside a white rectangle on it.
2. Use the left "<" and right ">" arrow keys to change the subtitle setting
Each time you press an arrow key the subtitle language will change and eventually the language will read "OFF". The subtitles are now switched off during playback.
Method 2.
To turn disc subtitles off from the main menu:
1. Press the "MENU/LIST" button on your remote control (directly below "STOP")
The main menu will now appear
2. Press the down arrow key on your remote once to highlight "A" in the left hand column of the main menu
3. Press the right arrow key on your remote once to move to the right-hand column of the menu
4. Press the down arrow twice to highlight "Disc Subtitle"
5. Use the left and right arrow keys to change the subtitle options until your required choice is displayed
6. Once set, press the "MENU/LIST" button again to exit the menu.
This should solve your problem, but if you need any further assistance, please post back.
Regards,
BElectric
Nov 21, 2010 | LG RH-4820 DVD Recorder
How do i change the language on my pioneer avic-d3 player
here is the link to your manual:
http://www.pioneer.co.uk/uk/support/manuals/AVIC-D3/index.html
Setting the language
You can set a desired subtitle, audio and menu
language. If the selected language is recorded on
the Disc, subtitles, audio and menu are displayed
in that language.
1 Touch “Language” and then touch
“Subtitle Language”, “Audio Language”
or “Menu Language”.
Each language menu is displayed and the currently
set language is selected.
2 Touch the desired language.
When you select “Others”, a language code
input display is shown. Input the four digit
code of the desired language then touch
Enter”.
➲ “Language Code Chart for DVD” ➞
Page 114
from the manual:
English (en), 0514
❒ If the selected language is not recorded on
the disc, the default language specified on
the disc is output and displayed.
❒ You can also switch the subtitle and audio
language by touching “S.Title” or “Audio
during playback.
➲ “Changing the subtitle language during
playback (Multi-subtitle)” ➞ Page 75
➲ Changing audio language during playback
(Multi-audio) ➞ Page 75
❒ Even if you use “S.Title” or “Audio” to
switch the subtitle or audio language, this
does not affect the settings here.
Setting assist subtitles on or off
Assist subtitles offer explanations for the aurally
impaired. However, they are only displayed if they
are recorded on the DVD.
You can turn assist subtitles on or off as desired.
1 Touch “Assist Subtitle”.
Touching “Assist Subtitle” switches
between “On” and “Off”.
Cheers!
Jan 11, 2010 | Pioneer AVIC-D3 Car DVD Player
Subtitles keep coming on
Hiya, have bought an Alba 26" LCD TV myself today. If you go into the menu and then into subtitles change it from English to Dutch. This should solve the problem. :-)
Dec 13, 2009 | Televison & Video
Issue with our Toshiba 50H82 - overnight it has stopped playing DVD's properly - a solid black rectangle obliterates 75% of the screen. Any idea?
Do you see same solid black box in all inputs or just in dvd picture?
If solid box appears only with dvd picture then its generated by dvd player, check dvd player Menu and turn off any subtitle settings.
And if solid black rectangular appears in all inputs of TV like cable etc then check Close Caption feature in TV and turn off CC function.
Hope this will solve your TV problem.
Thanks.
Nov 29, 2009 | Toshiba 50H82 50" Rear Projection...
I would like to be able to record TV shows WITH subtitles/closed captions. I have a Hisense HD LCD TV with built in HD tuner. I would like to be able to record onto a DVD/VCR. I'm getting conflicting...
Hey, I have a deaf brother with this issue. What I done was route the AV output of the TV to the AV input of the recorder. Set your recorders source to AV1 (or whichever you use) and set your TV to the program you want to record, also turn subtitles on. Because you wont have your TV set to the input your DVD recorder is on, you won't be able to see the DVD recorders output, but thats fine. Just press record on the unit - you have to leave the TV on the channel it's recording. Now you should be recording TV with subtitles with no problem :D
Apr 27, 2009 | Televison & Video
Black box appears in TV screen
The problem with the black box happened to me. I had pushed the subtitle button on my remote by mistake. Interestingly enough, as soon as I pushed the SUBTITLE key again, on the remote, the black boxes disappeared.
It also says CC which means closed captioned-- So the bottom on my remote is Subtitle, and then on the subtitle button is cc...
I hope this helps
Jun 04, 2008 | JVC AV-32260 32" TV
Subtitles on Sanyo DVD Player Model DMW-380
For the DVM-390 model, the above problem can be due to the TV Guardian (TVG) mode. I would go to the intial setting options and under Language turn the TVG mode to "Off" and see if that allows the subtitle languages to appear on screen.
May 23, 2008 | Sanyo DWM-390 DVD Player
Need setting to change regional code on samsung DVD P172
This works to change region code 5.
This is how it works.
1)Power on player.
2)Ensure that there is no DVD inside the player.
3)The tray should be closed.
4)Press "Subtitle" on the remote control.
5)Press 53814 for region 5 (For other regions see any of the other cracks)
6)The region code 5 will be displayed on the left top corner of your screen.
7)Now press 9. A 9 will be displayed on the top left corner of the screen.
8)Press Subtitle on the remote again
9)Power off the player.
10)Power it on again and you are region independent!!
Worked for me.
Mar 13, 2008 | Samsung DVD-HD870 DVD Player
Sharp LC19DV27UT 18.5 in. LCD TV/DVD Combo Logo
71 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
