Question about Acer Aspire 6930-6455 Notebook PC
I am having difficulty trying to get my laptop to recognise when I have plugged in a headset microphone into the jacks on the side. The headset is brand new, not damaged. The laptop keeps using the built in microphone to record and I cannot figure out how to get it to recognise the headset. The headset does work on other computers, I have tested it. This is getting very fusterating. What can I do?
  • 24 Answers
Is there more than one socket? often on a computer there are two. 1 is headphones only the is mic and phones. if this is not the case double click the speaker icon to open sound card driver to select inputs
Posted on Aug 07, 2017
3 Suggested Answers
Sonartech
SOURCE: Acer aspire 4720z Built-in microphone only records loud static
Based on sybabe solution,That leaves me with :
1-The built in Mic element has gone bad or
2- The contacts in 3.5 mm internal jack port are not fully closed when an external mic is not present.
Hope thats helps...
Posted on Nov 17, 2008
SOURCE: Acer Aspire 7720 built-in microphone not working
In the sounds control panel, right click in the area which should show recording devices. Select 'show disabled devices' and bingo!
Posted on May 01, 2009
Can't get the headphone sound working from the laptop
The Laptop has 3 Ports on the side- Pink,Green,Black
Pink Port is LineIn for an external device player jack
Green Port is LineIn for the Microphone jack
Black Port is LineOut for Headset or External Speakers jack
Plug the Green jack on Headphone - into the Black Port on the laptop.
b) Go to Control Panel and open - RealTek HD Audio manager
On the top of Page are 3 Icons -
One Icon is labelled Speakers One is for Digital optics, one is for Mic,
The Speakers Icon is misleading as it is also for Headphones (LineOut)
Select Speaker Icon and make it Default. Also tick Full Range - Front LR
Ignore the 4 vertical Analog Icons on the right side.
You should now have Headphone sound if your volume is not Muted.
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select enable windows 7
click start control panel on the left select hardware and sound then select manage audio devices then recording you should see a microphone right click select configure speech recognition then
you will see earphones with a speaker among a list set up a microphone headset with microphone then next and next again you should see your earphones with microphone being configured
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list
make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab
make sure that you have the right media selected also
select volume make sure the box for microphone has a tick in it
or you might have to depending on your operating system
Click start Control Pannel
click on Hardware and Sound
click on Sound
then you devices should come up ; speakers, Digital Audio, and headphones
plug your headphones in
then select headphones
at the bottom it will say set as default
select that!!
then when you disconnect your headphones it automatically switches to the speakers and when you plug them back in it automatically will switch to headphones
Hope this helps.
Dec 01, 2012 | Samsung Silver 13.3" Ultrabook...
Hello, When I connect my headset on my laptop Asus a7sv I get sound but no sound from the speakers. I have Windows Vista en I downloaded the original driver from the asus website. I tried everything....
Most headphone jacks operate as you describe. There is a switch built into the jack that diverts the audio from the speakers to the headphones for "private listening". If it didn't work this way, there would be no way that you could enjoy an audio track or other program with others having to hearing it, too.
You could get around this problem by using an external speaker set and a "splitter cable".
A splitter cable is simply a three ended cable like the one pictured above. The first end has a male plug that matches the jack on your computer - likely a stereo mini plug. The other two ends are usually the same; but the female version. You would plug the splitter into the SPEAKER jack and the laptop speakers would be silenced. Next, you would plug the the external speakers into one of the splitter jacks and then your headset would plug into the remaining splitter jack. You would connect the microphone plug into the MIC jack on the laptop.
You'll have to tinker with the sound levels as there will be feedback issues - depending on how close and loud the speakers are to the headset microphone.
Please rate this reply - and good luck!
Aug 09, 2010 | Computers & Internet
My loptop has no sound from the headset jack.but my internal speakers has
Make sure you are plugged into the headset jack and NOT either the microphone OR LINE jack which are all the same size.
Dec 05, 2009 | Toshiba Satellite M305D-S4829 Notebook
Where is the sound in./out for hooking up external speakers
Look at the front and sides of the laptop for the headphone and microphone jack ports.
Some of them are coloured Pink for the microphone and green for headphone (audio out). some of them are also black.
Good luck.
Sep 30, 2009 | Dell Latitude D600 Notebook
Computer Does Not Detect Headset Microphone
Sound and Recording jacks stop working on the DV6000 series due to the ribbon cable running under the power button. when the power button is pushed it bends the flex cable and over time it breaks the connection rendering the front jacks useless you can buy a new upper button panel for about 20 dollars on ebay
Aug 02, 2009 | HP Pavilion dv6000z Notebook
Microphone input on Dell Inspiron B130 doesn't work
Your jack may have been damaged, or the apple mic may not be compatible. Purchase another pc compatible mic to check. Or you could try a multimedia headset with mic that plugs into your usb port. Take a look at RadioShack for headsets, I saw one in a store near me. and they should have them online.
Jan 27, 2009 | Dell Inspiron B130 Notebook
Ive just bought a headset for my laptop, but the mic doesnt work though the speakers do. My laptop is vista and it doesnt even recognise that there is a microphone plugged in. Any ideas?
please confirm first that you plug mic jack in right socket-open volume control and check mic not in -mute--and fader in up position
Jul 16, 2008 | Audio Players & Recorders
Dell Inspiron 6000 PC Audio Ports Damaged
You should have sound from the speakers at all times until headphones are plugged into the jack, the jack then overrides the speakers and allows you to listen using the headphones. If the speakers aren't working, it's because they're being overridden by the damaged jack. The only way to correct this is to replace the faulty jacks. You could get a set of external speakers, the con is they're bulky and inconvenient.
Jul 01, 2008 | Dell Inspiron 6000 Notebook
Computer does not recognise the headset
might not have it plugged into the correct jack on the back
Jan 06, 2018 | Altec Lansing Radio Communications
Open Questions:
Acer Aspire 6930-6455 Notebook PC Logo
42 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
