Question about Proform Exercise & Fitness
Proform ekg 765 won't run when standing on. Have run all tests on belt, amp draw, tension, lube, volts from controller, replaced controller...
  • 1 more comment
  • benz_larry Apr 05, 2011
    I replaced controller because it was only putting out a couple volts to motor with the A+ and A- leads disconnected. The motor only draws 2.6 amps at 2.5 mph without anyone on the belt and when I get on, it drops in speed but still only draws about 7 amps. Will almost come to a complete stop if I don't get off. I weigh 210 lbs. Belt tension is correct and I did the test of having the incline up and pushed off and the belt spun until I went off the back. Lubed it up anyway and the pad the belt runs on is completely smooth.
    Have you heard of testing the motor with an 18 volt cordless drill battery? Do you just touch wires to the battery contacts?
    I have a proform ekg 765 that was stopping a couple minutes into a workout. The display would stay on and the reset would not trip and it would restart after trying for a couple minutes. There was a slight variance in speed at the lower settings but past 4 to 5 mph, it ran fine. I lubed the belt pad, checked the belt for 3 to 4 inches of slack, did the friction test of setting the incline to it's highest position and pushing off, all good. The motor pulls 2.5 amps at 2.5 mph and if you get on, it goes to 7 amps. The controller was only putting out 1 to 2 v. to the motor so I replaced it and re-calibrated. Now it runs fine without anyone on the belt but as soon as I step on, (210 lbs) it slows way down and unless I step off, it will go to nothing. The underside of the belt and pad are completely smooth and recently oiled.
  • 5,370 Answers
There is a motor which spins the treadmill belt.When you start the treadmill, the motor starts running to spin the belt.But if the motor cannot take the load it stops working.In your case, the motor and motor control board is got weak and this is causing the problem. ---------- Or the other possibility is the treadmill belt, the belt on which you step.That belt should be smooth, there is grease in the inner side of belt to keep it lube and run fluently.If that oily grease gets dried up then belt gets bit stiff or jammed up.So get this both possibilities checked.First try lubing the belt internally and then try check the motor and motor control board.To locate motor control board its simple.On the side of motor you will see a electric plug in connector, the other end of that connector gets connected to motor control board.Remove that connector , clean it and reconnect after 5 minutes, then check.In some cases this resets the internal control system and everything, works normally.But its not always possible then removing and reconnecting connector helps.In other cases the motor or control board needs to be replaced.If the motor gets weak, then internal coils in motor gets burned up.----------- You mentioned in your comment that you already tried lubing the belt and it runs smooth without stepping on it, so this clears that motor is got weak and its not taking load.This will help.Thanks.Helpmech.
Posted on Apr 06, 2011
    President:
  • 2,187 Answers
The motor might have gone bad. You should notice an increase in the current as you put in load but no work is being done by the motor. If you can remove the motor from the unit to do further test and to observe for physical damages. It may just need cleaning or grease may need to be replaced.
Posted on Apr 05, 2011
  • Nicolo Carlo Parazo Apr 05, 2011
    removal of the motor to conduct additional test would help isolate it. If there is a circuit in between the motor and the power, say the control circuit then you can conclude that its the motor that is the issue. Make sure to apply the correct voltage stated directly to the motor. The rating should be stamped on the motor body.
    not with the drill but I have an ac to dc converter. I cannot remember the voltage requirement of the motor you have but you can get it from the housing of the motor or getting a voltage reading from the circuit while it is on. Touching the correct terminals to the motor would be fine.
I have a treadmill XP Proform 542 and all of a sudden it stopped running. It was fluctuating on the speed and then the belt slowed then stopped completly
1) Please LUBE very well the deck belt, with Silicone.
2) Test the thermo switch inside of motor, for overheating.
3) Test with Battery 12 Vdc fro Motor Cycle, for to see if the motor is o.k
4) If everything is o.k the Controller Board Motor is Faulty, the IGTBs is faulty. Replace.
5) See if the walking belt when you lift with his finger has 2-3" otherwise fit with allen screw rear, see the instruction manual how to do it.
Blessing.
Adjust Walking Belt Tension
cuadra2016@yandex.com
cell+whatsAPP:+50588611441
Nov 13, 2017 | Proform Exercise & Fitness
My Treadmill PROFORM 760 EKG will just stop as I am walking on it.
see the video and proceed according. Lube the rollers front and rear, test the drive belt motor and replace.
God bless you
Jun 16, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
My Proform 770 EKG treadmill's motor is overheating. What is the voltage that should be pulled during use? Should the walking belt be replaced if we replace the motor?
see the video and lube correctly. 2) go to my personal TIPS for motor help.3) however you must see the voltage in the plate of motor. the tolerance will be +- 10% of voltage. can be voltage continuosly or alternating voltage.God bless you6527db9f-a9f8-47a6-9208-af2b680ea3a0.jpg
Apr 01, 2013 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
I have a proform 765 ekg and just replaced the motor because the treadmill kept stopping but it still stops and the breaker kicks off and the motor is real hot. any thoughts on why it still stops
LUBE the deck belt and rollers bearing this happen to due the lack of maintenance. see the video attached. Do it with silicone or wax read your manual.
If after you did lube the problem remain, TIME to replace the old board deck belt.
God bless you
Feb 16, 2013 | Proform Quick Burn Pro Treadmill with 12...
Proform 470 treadmill, belt won't run
see the video attached:
1) LUBE THE DECK BELT
2) LUBE THE ROLLERS BEARING
3) if this NOT has solution , you must test the a) motor y/o main motor board see the block diagram
God bless you
Jul 31, 2012 | Exercise & Fitness
Proform crosswalk 515 control board works but belt won't move/
lube the deck belt, you have deck worn, proceed in according with the instruction manual maintenance. 2) check the drive belt and replace it if necessary and tight 3) tes the input voltage motor, if there are the motor need repair or replace 4) test the output voltage from main board, for input voltage for the main motor, if there are NOT, the board is faulty.
Try if you can RUN the software calibration for diagnose and troubleshooting.
sincerely. God bless you.
Apr 28, 2012 | Proform Crosswalk 500 Treadmill
Belt stops during workout and have to step offf
you need LUBE in according with the instruction manual maintenance schedule . You have a deck belt worn 2) Test the drive Belt for replace 3) Test the input voltage motor, if there are the motor need repair 4) Test the output voltage from motor board, for input main motor, if there are NOT the board is faulty.
RUN the software calibration for easy diagnose and troubleshooting. See my personal TIPS for HELP.
Apr 27, 2012 | Treadmill Doctor PROFORM 770 EKG TREADMILL...
Motor has burning smell. belt and controller were
May I ask witch belt? Most treadmills have two belts, one to drive the gearing and one the patient walks/runs on. The tension and alignment are factors in the load on the motor. Too much tension on the belt the patient stands on will overload the motor. Alignment of both belts is a load factor. Eliminating the belts, tension, belt rollers, and control only power wiring and the motor is left. If the motor is the culprit call a local electric motor repair shop for testing and possible repair. Maybe cheaper than a new motor. : ) : )
Feb 28, 2010 | Parker Laboratories Medical
Proform 765 EKG
If I understand correct, the treadmill will not run correct unless you have the safety key in. Well yes this is correct because once the safety key is removed the treadmill will stop. If your treadmill is running extremely fast just by turning it on, you may need a new speed sensor. www.AtlantaFitnessRepair.com
Aug 10, 2009 | Proform Sport 1000 Folding Treadmill...
Exercise & Fitness Logo
751 people viewed this question
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
