I own an acer 10.1"
    President:
  • 1,623 Answers
It isnt that difficult actually , a how to for removing the lcd is shown here
Remove the four screw caps and screws from the LCD Bezel.
NOTE: The two center screw caps at the top of the bezel are for protection only.
I own an acer 10.1
Starting from the inside top edge, pry the bezel away from the panel. Continue moving down the sides until the bezel is removed. If necessary, use a plastic pry to release the corners of the bezel.
1063_66_97.jpg 4. Lift up the bezel and remove it from the LCD Module.
IMPORTANT: If the LCD Bezel is replaced, remove the lid sensor magnet from the bezel, and attach it to the replacement bezel.
  1. Disconnect the cable from the Camera Board as shown.
I own an acer 10.1" - 1063_66_99.jpgp://i.fixya.net/uploads/images/1063_66_99.jpg" alt="1063_66_99.jpg" class="h_mi" /> Remove the Camera Board from the LCD Module.
Remove the two securing screwsI own an acer 10.1" - 1063_66_101.jpganel. 1063_66_101.jpg
  1. Remove the four securing screws (two each siI own an acer 10.1" - 1063_66_103.jpgD Panel brackets.
1063_66_104.jpg Turn the LCD panel over on a clean surface. Remove the adhesive strips securing the LCD cabI own an acer 10.1" - 1063_66_105.jpgft the adhesive tape securing the cable connector to the LCD Panel.
  1. Remove the adhesive strips holding the MIC cable in place.
  2. 3. Remove the MIC Board from the LCD Module.
    1063_66_108.jpgRemove the adhesive strips holding the Camera cable in place.
  3. Remove the Camera cable from the LCD Module.
I own an acer 10.1" - 1063_66_110.jpg//i.fixya.net/uploads/images/1063_66_109.jpg" alt="1063_66_109.jpg" class="h_mi" />
  1. Remove the adhesive strips holding the Antenna cables in place.
to fit a new one do the steps in reverse
If you found this info useful Please vote for me
Posted on Apr 05, 2011
I have a 15 inch BenQ FP731 monitor and its been working all fine for the past year, until yesterday. I have an Acer laptop hooked up to the monitor as its screen was wrecked so I just kept the display on...
This because your ACER laptop having higher resolution than your monitor. Please lower your ACER laptop resolution as low as possible then try again.
Aug 06, 2011 | BenQ FP731 17" LCD Monitor
My acer laptop screen has multi colored lines blue and black on the monitor. Where can I get it fixed?
Bring your Acer laptop to Acer Service Center. You can search depend on your country here :
http://www.acer.com/worldwide/selection.html
Hope this help and if helpful RATE please.
Feb 10, 2011 | Acer AL1721HM Multimedia 17" LCD Monitor
My acer flat screen monitor will not come on. My mac mini starts up, but the screen stays dark. Last week, it was staying dark after the computer went to sleep; I couldn't "wake it up." After a few...
I will assume that you have checked out the power cables and external cables. If this is the case you will usually notice an indicator light from your monitor. Universally it is yellow or orange when it has power, then turns green when it detects input from your computer. If the Led light doesn't turn green even when your laptop is already booted, your culprits would be your iMac's video controller or your monitor's input cables.
Jan 29, 2018 | Acer AL1715 17" LCD Monitor
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
ACER AL 1714 SM MONITOR
Hi...there,
Well...your backlight inverter are busted.... need replaced a new one or repaired it.
Oct 12, 2008 | Acer AL1714CB (Black) 17" LCD Monitor
Acer laptop wont't turn up...
yo...
good to hear... least we know what is wrong...
so it can be one of 3 things... the first 2 are the most common and the last one can happen but I haven't seen it happen too often.
1. LCD control board is busted. Usually a circuit board that controls the picture going to the LCD screen. Usually built into the LCD monitor.
2. LCD screen is busted. The screen itself is busted.
3. Video card on the laptop is busted.
I'm going with 3 as you typed the system can't find the video card on the laptop. Try going to device manager and try to see if the computers/windows detects the video card. If it pops up you can try re-installing the drivers for the video card.
Check for any "Unknown" devices as that might be the video card itself.
Let me know what you found...
P.S. please rate my Solutions... Thanks
Aug 15, 2008 | Computers & Internet
Power issue
See if your video card inside your PC hasn't come loose. Take it out and push it back in again to reseat the card. Then, once it's firmly secured, try the monitor.
Jun 06, 2007 | Acer AL718 17" Flat Panel LCD Monitor
Recently moved monitor showing streaks
the tft screen was bumped somehow. time for a new monitor. cost of repair exceeds cost of replacement.
Jan 18, 2007 | Dell E173FP 17" LCD Monitor
Acer AL1714 17" LCD Monitor Good Power supply no power on monitor
Hello, I have to same problem. I returned my monitor to Acer but got it back unrepaired, they could not see the malfunction. But I kept on sending it back, until I got a new model. Now after 2 years I get the same thing with this monitor. But there's no warranty anymore, so I looked into the problem myself. I found out that inside the powercircuit board is connected to the mainboard through a 10pin connector. The 5 pins that are on the lowest row, show a trace of white powder, I suppose occidation. I sprayed a little of contactspray in it. I must say the problem is not gone, but much better. The problem shows not so frequent anymore and lasts not so long. At first the screen switched of for 3 to 5 minutes and came back on. Now the screen is gone for perhaps 1 second and returns. So I'm almost convinced the problem has something to do with the connection of the powercircuitboard inside and the mainboard inside, when the monitor heats up a bad connection occurs due to occidation of the 10 pin connector. If you find a solution that fixes the problem 100% let me know, please. Mario.
Dec 05, 2006 | Acer AL1714 17" LCD Monitor
Computers & Internet Logo
David Payne
David Payne
