Question about KitchenAid Kitchen Ranges
The igniter wants to keep firing - KitchenAid Kitchen Ranges
  • KitchenAid Master
  • 43,501 Answers
Here is a tip that I wrote that will help figure out why the burner spark keepson clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Apr 05, 2011
Would a crankshaft sensor keep the car from firing an or getting gas..?
It would definitely keep the ignition from firing if it was bad. The computer would think it isn't turning over and the fuel pump won't feed an engine that isn't turning over either.
Dec 21, 2016 | Cars & Trucks
Should the igniter fire constantly?
Hard to answer the question with out the make and model information. Generally heaters that use an electric igniter in place of a pilot light only fire the igniter until the flame is sensed. If it keeps firing after that then the sensor that heats up to tell it the flame is lit could need replacing.
This link might help you understand it better.
How to Keep Your Electronic Ignition Furnace Working Properly
Sep 08, 2015 | Heating & Cooling
How do I get my gas stove to fire?
Mine has the same problem, turn the knob thing so its on.. press and hold the gas buttong and ignite it with an ignitor, after igniting keep holding the gas button for another 20-30 seconds and you're set.
Sep 04, 2014 | Heating & Cooling
All 4 igniters keep clicking, when one is on
All of the igniters are connected to one source. A series of small switches mount on each stem of each burner. Any of them can fire up the spark box and it in turn it fires off all the ignitors. If a boil over spills liquid into one or more of them switches the resulting continuity causes the clicking. Removing one wire at a time from each switch till the clicking stops is the solution.
Aug 05, 2009 | Jenn-Air 34 in. Expressions CVGX2423 Gas...
Whirlpool Cooktop igniters keep firing, even after igniting
when you cleaned the unit you may have gotten water in side the igniter, dry it out w/ a hair dryer. Once dry should work .
Mar 29, 2009 | Dacor Preference SGM365SS Gas Cooktop
Dyna Glo forced air propane heater
...found out that this is a continuous ignition heater so the igniter is always on.
Sep 22, 2008 | Reddy Heater-30,000 BTU Propane Forced-Air...
Igniter keeps firing
The problem resolved on its own. I'm guessing some moisture from my cleaning was the culprit...when the moisture dried the igniter stopped sparking.
Jun 01, 2008 | Jenn-Air 30 in. CVG4280 Gas Cooktop
Ignitors keep firing by themselves after my aunt cleaned them 24 hours ago After she did the major cleaning of the stove I used the oven and it worked fine. I lit a burner (Probably front?) and the left...
Apparently there was a water spill around the burner control knob and in the burner itself; We ran the burner to create heat and then turned it off and let the water dry out and evaporate from the burner and igniter area.
May 26, 2008 | Kitchen Ranges
Igniter
igniter's are bad and, or, a short in the wiring or switch. replace the igniter, then check to see if problem still exists, you can also check wires going from igniter to switch with ohm meter for continuity and shorted wires.
Nov 18, 2007 | Frigidaire PLCF489AC Dual Fuel (Electric...
Open Questions:
Kitchen Ranges Logo
77 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
