Question about Whirlpool AD25BBK Dehumidifier
Ya the front will freeze - Whirlpool AD25BBK Dehumidifier
  • Whirlpool Master
  • 43,501 Answers
Here is a tip that I wrote that will help you understand why and what you cando with a dehumidifier that ices up.
Dehumidifier is Freezing up and not working
heatman101
Posted on Apr 05, 2011
Freezes up
most units draw in the front and expel from the rear air , keeping filters clean (never run without one) is important for this function , frost on coils is a sure sign that air flow is low , or might be unit has lost [part of its gas charge due to heat build up from loss of cooling
May 13, 2014 | Kenmore 54501 Dehumidifier
Zenith dehumidifier is freezing up on the front near the air intake.
check to see if the fan is working. low or no air flow will cause it to ice up. may have to remove the front to de-ice. turn the unit off and slowly pour warm water over the coils to thaw. the water should drain right into the bin. also good to clean any dust off of the coils to keep the air flow open.
Feb 27, 2014 | Zenith Dehumidifiers
Ice on front
heatman101
Aug 21, 2011 | Whirlpool AD25BBK Dehumidifier
Coil is freezing up.rusted coil sensor bracket. i need a new freeze switch sensor for the front coil. i guess it turns the compressor on and off so the coil doesn't freeze solid. can't find the...
Buck, as you seem to be aware, Fedders no longer exist as the Fedders you may have been familiar with 8 years ago. Finding manuals and parts, is like looking for a needle in a hay stack. However, the new company Airwell-Fedders may be able to help you. There Customer Support Dept 866-829-2440, is who you need to contact.
There is one other possible source, as some parts are interchangeable. Appliance Factory Parts
http://www.appliancefactoryparts.com/airconditioners/fedders/ does carry some of the older Fedders Parts, as well as Maytag. So, that may be worth a try.
Hope this helps you find the parts you need. Good luck and please let me know how it worked out for you. Thanks.
Jun 11, 2011 | Fedders A7DH45B2A Dehumidifier
Frosting up in front after it been on for awhile
Here is a tip that I wrote that will help you understand why and what you can do with a dehumidifier that ices up.
heatman101
Feb 05, 2011 | Danby DDR4588EE Dehumidifier
Water leaks out front , is it freezing up?
The incoming air temperature has alot to do with how well a unit works. As the basement area warms up the dehu always works better. The water leak may be caused by a plugged drain line or a crack in the plastic drain pan in the 150 Max. Please call the Thermastor Tech Line at 800-533-7533 x 8459. Let's see if we can help determine what is going on.
Dwaine
Thermastor Service Dept
Apr 05, 2010 | Santa Fe 4027450 Dehumidifier
Seems to freeze up
I am guessing the system has a leak and you are very low on coolant, I have had the same problem. I assume its still under warranty.
Sep 23, 2008 | LG LHD65EBL Dehumidifier
Humidifier coils freeze
I believe a dehumidifier is supposed to operate in temps above 60 degrees. Even though your house is warmer than that, the air entering the dehimidifier may be getting into that range due to it being on a basement level etc. This is perfectly normal and is not a malfunction with your humidifier.
Your options are to either place the dehumidifier closer to a heat source in order to keep the air which is entering warmer. (I've even heard of someone placing a light bulb in front the unit during winter to warm the air slightly as it enters). Because the dehumidifier's coils get cold in order for it to collect moisture from the air, if they are freezing, giving the unit a rest for a few hours every few hours may allow the coils to thaw in between and prevent them from reaching freezing temperatures while running. You could use a timer to accomplish this, but you'll want to insure that it's a commercial grade timer in order to handle the electrical draw that the dehumidifier requires.
Dec 29, 2007 | Eva-Dry EDV300 Dehumidifier
Whirlpool AD25BBK Dehumidifier Logo
122 people viewed this question
Top Whirlpool Dehumidifiers Experts
Bill Long
Mike
Terry Schneider
Are you a Whirlpool Dehumidifier Expert? Answer questions, earn points and help others
