Question about Nokia N70 Cellular Phone
Battery runs down fast.
Original battery runs down fast after complete charge and full charge
  • 3 more comments
  • pasgenesis Aug 05, 2008
    please, I need an answer as soon as possible
  • pasgenesis Aug 06, 2008
    Thanks once more.My phone is not up to five months old.Blue tooth is not on.It is true that I make good use of the camera. I will try the solutions you have attempted and see what happens.
    regards
    pasgenesis
    Cameroon,Douala
    23
    regards
    pasgenesis
    Cameroon,Douala
    237
  • pasgenesis Aug 07, 2008
    I am so happy my phone works now perfectly well.I applied all the instructions the Joshi_Z gave me via net.\\\\\\\\\\\\\\\\every thing is ok.Thanks a million
  • pasgenesis Aug 08, 2008
    hello Joshi_Z,
    Thanks for your solutions .the life of the phone is improving every day after you gave those intelligent instructions.God bless you richly.Thanks and buy.I suggest you visit Douala- Cameroon and educate some technicians for this great job you are doing..........It will be nice you open a centre for repairs and consultation office........... in the economic Capital of Cameroon-Douala.Once more thank you and take care.
  • 567 Answers
Hello there....well its quite simple...
how old is your phone ?
i am assuming its an old phone so it is time to change the battery...you will see that batter is slightly puffed or out of shape ...in that case you should immediately change it
if its a new phone....then check if blue tooth is on or off....it should be off....and if you use the phone a lot then also the batter will run out in 3 hrs and 30 minutes of talk time...playing music as well as keeping the camera on for a long time will drain the batter
so it depends on how you use it ....if you have more question we will take it from there
Hope this help
Cheers
Posted on Aug 06, 2008
  • Anuj Joshi
    Anuj Joshi Aug 08, 2008
    hi...
    nice to hear that the problem is solved
    well to improve it more what you can go is reduce your screen brightness,keep the vibration mode off,dont use any screen savers...etc
    basic thing is don't use the applications when the are not required
    and to really improve your battery life only charge you battery when it is completely drained when the phone shuts itself down....dont charge it when half of the battery is remaining ....
    thanks...and take care
    bye
Craftsman fast charger
run all 3 batteries down to full dead then fully recharge. some times this can help
Nov 27, 2013 | Garden
My nokia e61i charges for a small period of time and full battery
i think you have to replace the battery, and try to buy the original or genuine battery.
Apr 10, 2010 | Nokia E61i Cellular Phone
My laptop gives me only 6 minutes on the battery after using an hp recovery disk. can you help me?
"Test your Power Supply output with a meter and compare to the spec on the bottom of the laptop. If it is O.K. then follow the steps below!
Depending on how old the battery is you may need a new battery. The software install "Recovery Disk" has no bearing on the battery life! Go into Control Panel-Power Options-Meter and see if the battery is taking a charge first. Assuming it is charging let it get to 100% and see what is says for time such as 1.2hr. etc. The battery has a memory and if it is charged before it is totaly discharged it sets a new memory. This means that 100% becomes less and less operational time. If you see the battery is charging and reaches 100% very fast, then you have the situation I just outlined. To try to reset the battery to it's original state you need to run the battery down to "DEAD" zero charge. Next put the battery in a ziplock bag and seal it. Now put it in the freezer for 2 days after which remove it from the freezer and let it come to room temp. Re-install the battery and charge it oner night. Repeat the process above in the Control Panel to see the time associated with a full charge. This does work 90% of the time if the battery is still good. The cold sets the memory back to it's original state. Physics\Cemestry!!!!!
P.S.
Dec 09, 2009 | Gateway 7405GX Notebook
Some of my phones will not stay charged even though I have let it on the unit. Do I need to replace the batteries?
If they charge, but then run down fast, it's a sign that the batteries are just too weak to take/hold a full charge and, yes, it's time for replacements.
Nov 01, 2009 | Uniden Cordless Phone
How long does it take to charge the battery to a full charge...thanks,judy....on a presario V2000
usually 8 hours is what is suggested when you get a new battery. i like to burn down the power on the battery completely till it turns the unit off, then let charge for 24 hours just to reset the battery correctly.
Jul 19, 2009 | HP Compaq Presario V2000 Notebook
My g1 will not charge fast like it use 2
Have you tried recalibrating the battery? To do this you use the phone until it completely runs out of battery and switches itself off. Make sure it has completely run out by continuing to turn it back on until nothing happens except a red LED coming on. Then charge it while it's off until the green LED has been on for 2 hours. Hopefully this will improve your battery life.
Jun 10, 2009 | HTC G1
Problem
How old is the battery? Have you let the battery run down completely and then fully charged it back up?
Was the phone a display model when you purchased it, or was it in an unopened box? How fast does the battery run down? Have you checked the owner's manual to see how much talk-time you get out of the fully-charged battery? Let me know... Thank you and hope to hear form you soon. billyho1977@FixYa
Sep 16, 2008 | Nokia 5300 Grey Cellular Phone
Nokia n81 running a new battery down in 6-8 hours on standby mode
Even if the battery is new, if it is not charged properly it can run down pretty fast. To reset the battery I recommend running the battery all the way down - charging the battery all the way back up to full - and then repeat. Also, make sure you do not charge the battery after it is full. Most phones or charge units have signals to tell you when the battery is fully charged. Do not charge the battery overnight.
These are the best ways to protect the life of a battery.
Jul 30, 2008 | Cell Phones
New battery runs down fast
bad battery.. RMA that back to where you bought it from. probably wasnt a new battery they sold you. id charge it from completely dead to completely full one more time and if you dont get at least an hour out of the batt then i would return it..
Jan 18, 2008 | Averatec 3200 Notebook
Nokia N70 Cellular Phone Logo
115 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
