Question about Refrigerators
WHERE DO I FIND INFORMATION ON WHICH SHELF TO REPLACE IN MY AMANA SIDE BY SIDE
  • Refrigerators Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourselfonline...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
Here is one site that I recommend http://ping.fm/zJDAM
heatman101
Posted on Apr 05, 2011
Amana D965e-e dehumidifier leaking
I encountered a similar problem (using the bucket, but still getting water leaking onto the floor) with my 970E-E. The problem is a design flaw. If the bucket is not firmly pressed into the dehumidifier, there is a slight air gap between the bucket and the dehumidifier on the left side. Within the gap, warm moist environmental air cools. Water condenses in the gap and pools up at the bottom of the bucket shelf, eventually spilling over onto the floor. You can check and see if this is your problem by pulling out the bucket and inspecting for droplets along the left side of the bucket shelf. My solution was the bungie the bucket into the shelf firmly so that there is no air gap.
May 29, 2012 | Amana Dehumidifiers
THE WATER GETS FROZEN INTO THE PLASTIC TUBE ROLL WHICH SERVES LIKE A DEPOSIT TANK TO COOL THE WATER.
the fresh food side is too cold . if colder than 38 deg it can freeze water tubing . there are kits for amana and maytag and jen air to prevent this ( and what is in kit is rubber shelf blocker strips that install on the back edge to prvent change of air flow . they can be ordered from amana for your model .. and you might ck the tempt in fresh food side and adjust to 38 deg . this can help . also adjust the freezer to a higher # this will slow the cold air comming from the freezer side . hope this helps mm
Dec 11, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have a small 4 shelf upright kenmore freezer.the bottom shelf is not working.i put frozen items there and they all would stay cool but not frozen and then turn bad.the rest of the shelves are working...
all shelf's should have frost on them / when the ref charge is less than needed . one shelf at a time will loose its frost. it needs a recharge . if it was the door seal you would see large amounts of frost on shelfs where the leakage is . so look to add some refergant . mm
Dec 07, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Food freezes on shelf below the deli drawer-amana side by side
look between those shelves
you will see hole that goes straigt through to the freezer , your vent diverter may have become dislodged and freezer air is flooding that shelf space
Oct 06, 2009 | Refrigerators
The vegetable department and the deep side of the shelf - food become frozen ??
I do not know what brand and model you have but there are several controls that you may need to look at. Some of these shelf's have a control lever to adjust air flow. Check your two control knobs at the top and set them to initial settings. Hope this helps. Let me know if I can help you with anything else.
JimmyC
Sep 25, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Refrigerator light will not go off
How do you know it wont go out if you close the door? More than likely the light switch is bad its located in the middle at the top when you open the door.Push it in, if the light stays on see if something it blocking it, if not replace the switch.
Feb 17, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Bracket holding glass over fruit / veg compartment broke
http://www.partselect.com/Schematics/Maytag/54436.gif Maybe this diagram will help you. www.partselect.com I just replaced the Crisper Shelf Frame. I received it very quickly. I am now looking for some sort of support for the whole shelf, because it still seems to be sagging. I may have to invent something. If anyone out there has a solution, please post it.
Aug 26, 2008 | Amana ARB2217CSR Bottom Freezer...
Refrigerators Logo
675 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
