It appears that the USB ports can't read any devices at all such as mouse or flash drive
  • Computers & ... Master
  • 5,100 Answers
What type of computer are you using? If it is a laptop, try disconnecting all of the peripherals and the charger. Then remove the battery. Press and hold the power button for 15-30 seconds. Reconnect things and try to see if the computer boots up and then recognizes the devices. Try a minimal number of peripherals to start. For a desktop, you can try something similar (disconnect your power cord from both the computer and the outlet) or access the motherboard and remove the CMOS battery (or use the clear CMOS jumper).
For Windows on a laptop, use the unit's laptop and touchpad to enter the Device Manager. Uninstall the USB drivers (Start > Control Panel > Hardware and Sound > Device Manager in Windows 7). Then restart the computer. If you have a desktop with a PS2 keyboard, you can do the same thing by using the keyboard. (Windows Key > Control Panel and use the arrow keys).
Try accessing the keyboard when you turn on the computer. For this you need to press and release the key every second from the time you press the power button. Try F8 to boot into safe mode (then delete drivers) or return to a known good version of Windows. Try entering the BIOS (F1, F2 or F10 depending on the brand of computer). If you have a recovery CD (install or upgrade disc), try booting to the CD and repairing Windows to a known good state. If your computer has a recovery partition, you can try rolling back the system by pressing F11.
I hope this helps.
(I've had this happen on a laptop and the reset via the power button worked when the battery was removed. On a desktop, it went back to HP under warranty since I couldn't get any keyboard to respond.)
Posted on Apr 05, 2011
USB ports not working
did you try with other USB devices, for example USB mouse or Keyboar. if those things acan work then there must be some issue with your flash drive. if all the devices are not working then you should see in device manager your USB driver are upto date or not.
Jul 22, 2012 | HEWLETT-PACKARD HP ProBook 4510s Notebook
I got a new transcend USB jetflash drive 16GB, but my system not showing any response towards it, what shall i do..??? is to download a software for it...??
Flash drives do not need a drivers (plug and play). There are several possibilities:
1. Assumptions: USB port error, computer drivers normal, normal flash drive.
Solution: insert a flash drive into another USB port. If the USB port 1 is not detected, insert flash drive into a USB 2, USB 3 or USB 4.
2. Assumption: normal USB ports, computer driver error, a normal flash drive
Solution: reinstall the chipset drivers, or USB.
3. Assumption: normal USB port,
computer driver normal, flash drive is broken
Solution: try to insert the flash drive into another computer. If the flash drive is not detected, it means your flash drive is damaged.
Solution to determine the cause of damage:
1. If you have a USB mouse, use the mouse to check the damage to the USB port. Example: connect the mouse to the USB 1, USB 2, USB 3 or USB 4. If every USB port, mouse is detected, the conclusion normal USB port
2. To check your computer's drivers, right-click My Computer - Properties - Hardware - Device Manager
3. If points 1 and 2 are normal, the possibility of flash drive damaged.
Because the new flash drive, flash drive is most likely normal. Based on experience, cause damage to the flash drive is a USB port is dirty. The USB port is dirty, can cause short-circuit flash drive. The characteristics of short-circuit flash drive. When inserted into a USB flash drive (about 5 seconds), the temperature of the flash drive become extremely hot. If there are problems like this, immediately unplug the flash drive, to prevent permanent damage.
I hope this information helps.
Oct 11, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cannot get a SanDisk flashdrive to go into either of the USB ports on my new desktop computer. I am using the USB ports located on top of the computer
To test the functionality of the usb ports in front of the computer
1. Insert another flash drive or another usb device like a usb mouse on front the computer 2. If it detect the usb device that means 2 things flash drive might be bad and the front usb port is working 3. If it does not, It means that the flash drive might be bad or the usb port is not connected to the front panel of the computer 4. Try also inserting the flash drive at the back of the computer see if the usb drive is detected in all ports 5. Check the BIOS for any usb port associativity
Jul 05, 2011 | HP Computers & Internet
HP Pavilion zv6000: USB ports are inop. USB port on rear of computer works fine. USB port on left/front will power my flash drive, but the light stays on constantly. The flash drive is does NOT show up in...
After reading the description, I think you need to try updating BIOS and latest device drivers for USB. Because USB are getting power on that means there would not be any fault to from the motherboard.
So please try updating latest BIOS for your notebook.
If you can provide me the product no for your notebook and the operating system which you are using currently then I can find the one for you.
Otherwise you can also do the same.
Type in the product no. on www.hp.com. Then go to software and driver download page, select the proper OS and search in BIOS ROM pack available for your notebook.
I hope this will help.
Jun 11, 2010 | HP Pavillion ZV6000 Notebook
Mouse does not work when used under xp. Followed installation guide but mouse appears inoperable. Mouse batteries are good and usb receiver working but no cursor movement with mouse. Attempted several...
I called Dynex customer support and they walked me through the troubleshooting process. It turns out there was a problem or conflict with one of my usb ports. The port recognizes my flash drive and other usb devices but not the mouse. I tried using the other two remaining ports and the mouse was recognized and works just fine.
Feb 16, 2010 | Dynex Wireless Optical Laptop Mouse...
Cannot conect with usb
Try the USB memory-stick in another computer.
If it does not work, then the memory-stick is broken.
If it does work, then the memory-stick is OK.
Try a USB mouse or USB keyboard in another computer, to prove that the device works in that computer.
Try the same USB mouse or USB keyboard in a USB port in your computer. Try each USB port.
If the mouse/keyboard does not work, then there's something wrong with the USB ports on your computer, either "hardware" or "software".
Open "Device Manager" in Windows, and check that the software device-drivers for the USB hardware are correctly installed.
Try "reinstall device driver" to see if Windows can repair itself.
Dec 30, 2009 | Electronics - Others
SIIG Hi-speed USB 4-port cardBus - iphone/flashdrive problems
Remove your device from the device manager and reboot unit.
Restart and reload device drivers.
Make sure the driver are for xp pro
Nov 14, 2009 | Electronics - Others
I just bought a new mouse for my laptop. It is a Targus Kaleidoscope Optical Mouse. For my HP Pavilion dv2700, I plugged it in and it will not work,it did install itself several times.Everytime I plugged...
First thing you need to do is to know that the USB ports of your laptop is really working. Insert another usb devices or storage such a flash disk. If the flash disk being inserted is not recognized by the system then the usb port you had inserted is malfunctioning or it is defective. But if the other usb devices like the flash disk is working then your new bought mouse is defective. Try to plug the usb mouse to the other ports available in your laptop.
Oct 29, 2009 | Targus Kaleidoscope Optical Retractable...
Micro sd 2gb card, not read.
Sometimes when a flash memory stick fails because it was not removed from the USB port properly. If the device is removed by just pulling it out of the USB port, it can cause the flash device to fail, you must click on the Safely Remove Hardware icon on the Task Bar and select the device you wish to remove and only do so when instructed to do so.
When the flash memory device appears to malfunction it maybe possible to restore it by reformatting it. Insert the flash drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Healthy.
You need to format the external drive. Format the drive as primary drive and in FAT32. (FAT32 will allow data to be exchanged between MACs and PCs).
Insert the external hard drive into the USB port then Click on Control Panel - Administrative Tools - Computer Management - Disk Management.
Then right click on Disk 1 removable drive and click Format. After the flash drive has been formatted it will indicate that it is Health.
Oct 17, 2009 | HP Compaq nx6110 PC Laptop
Computer will not find flash drive
Does the flash-drive work on *ANY* computer?
If not, the problem is the flash-drive.
Does your computer have more than one USB port?
Does it work in *ANY* port?
Does a *DIFFERENT* USB-device (mouse, keyboard, printer) work in the USB-port that you are trying to use? If not, the USB port has a problem (either software or hardware).
Sep 16, 2009 | SanDisk Televison & Video
Computers & Internet Logo
David Payne
David Payne
