Question about Bosch HBN5450UC Electric Single Oven
I have a Bosch HBN5450UC we had to remove to have a now oven cabnit installed and when we turn on the power and try to start the oven it would not heat up. Everything else is working just fine but it juat will not hee up when the door is closed. what could be the problem?
catriver
  • 878 Answers
SOURCE: The oven door are not closing all the way
spot, Maytag put out a service bullitin on this issue....TDC-0017B-B, They put out a new hinge kit...part #12002111 for single and 12002112 for double units. This may be covered under this service flash. Call Maytag service and inquire about the above mentioned service bullitin. Problem addresses doors not closing...Catriver..post back.
Posted on Sep 03, 2006
SOURCE: Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Posted on Jan 17, 2008
ginko
  • 19396 Answers
SOURCE: Bosch oven won't pre-heat/heat with door closed
Some oven has a door sensor, which prevents heating when door is open, evidently this is faulty, you need a service manual to identify and replace the part, If I find something I will post here.
Posted on May 24, 2008
  • 116 Answers
SOURCE: Oven door not closing correctly
There is some adjustment for the hinges but it involves removing the oven from the wall. On either side (outside) of the oven there is a screw on panel. This panel has screws around the perimeter which can be loosened and shifted somewhat to provide a tight seal.
If there is door is open by any greater than 1/2 inch when it is supposed to be in the closed position then I am afraid that you will have to install new hinge assemblies.
You will have to check your owner's manual to see if you qualify for any warranty repair. The hinges usually cost around $100 each. This link will show you what the hinge assembly looks like:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=1094528&PPStack=1
Posted on Aug 06, 2008
SOURCE: bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Posted on Mar 31, 2009
Hbl8450 E118 error
E118 indicates a comma error. You could check for loose connector block or plug on ribbon cable. Best course of action is to call a Service Engineer.
Sep 19, 2017 | Bosch Ovens
Bosch HBL 645 Convection Oven -- No Heat
first out put voltages measures,when output voltages ok , then see the control circuit.after tnat every thing ok. replace heating elements.
Dec 10, 2007 | Bosch HBN 442 / HBN446 Electric Single...
Bosch built in oven
ok try there maybe a recall list as there is with there dishwashers try the list see if ure model number is on the list then if it is either send it for repair or rtn it most people still are using recall listed units
Apr 25, 2013 | Bosch HBL5450UC Electric Single Oven
Bosch wall oven turns on when mcrowave is on
Contact Bosch website and ask customer services if they have had this problem before. It may be subject to recall if there is a fault. Also have a word with the installer. If there is any leakage of radiation it MUST be stopped.
Dec 10, 2017 | Bosch Appliances 27 in. Wall Oven Electric...
We own a Bosch (Built-in) oven HBN4305.0B and the top grill/oven element has failed. Can you please advise on replacement procedure
With the power turned off it is usually a case of, in most ovens, just removing the element by unscrewing two screws. Unclip the wiring and make a note of what wires go where. Find a new one and install in reverse procedure.
Feb 10, 2011 | Bosch Ovens
How do I set the clock
Set the clock by following these steps: a). Touch TIME pad. b). Turn rotary knob clockwise until CLOCK appears. c). Touch TIME pad. d). Turn rotary knob in either direction. The time displayed will change in 10-minute increments and indicate AM or PM. Turn the knob in the opposite direction and the display will change in one-minute increments. e). Touch TIME pad. The clock is now set. in some units there is button instead of knob in that case the clock indicating button has to be pressed . This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Feb 06, 2010 | Bosch Appliances 27 in. Wall Oven Electric...
Bosch oven
looks as though youre circotherm element has blown (open circuit) you will need to remove oven and check with multimeter should read around 35-37 ohms on 2.5 kilowatt heater if open circuit will need replacing easy to do on most ovens and no too expensive around £30-£35 for element depends on model and output power.
hope this helps
Jan 17, 2008 | Bosch HBL 745 Stainless Steel Electric...
Fan won't turn off & upper oven work in Manual mode
This sounds like a control panel issue, you may have to replace it, about $300.00
Jul 09, 2017 | Bosch HBN 455 Stainless Steel Electric...
Fan oven not heating, bosch hbn 202t
the fan oven element is separate from the grill element. the problem is that the circular element round the fan is blown. remove the back panel of the oven and you will see the element. replacement is easy. on most bosch, the element is removable from inside the oven but for some you have to remove the oven and take off the back casing
May 04, 2007 | Bosch HBL 5032 Electric Single Oven
Double oven / convection not working
It is likely that the convection element is burned out and needs to be replaced. If all other functions are working then this is the place to start. Teh back panel inside of the oven can be removed by removing the 4 visible philips screws on it. The element should look smooth and round, if not then it needs to be replaced. Be sure to turn power off to the oven before replacing it. Remove the screws that fasten the element to the back wall and gently pull the element away from the wall an inch or so. the wires will be exposed and can be unclipped from the element do not let them fall inside of the back of the oven or you will have to remove the oven from the wall to get at the back panel. Install the new element in the reverse procedure. If the element looks good then it will have to be tested with a multimeter to verify that it is still good before proceeding to check the selector switch for burn marks.
Dec 10, 2006 | Bosch HBL 455 Stainless Steel Electric...
Bosch HBN5450UC Electric Single Oven Logo
78 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
