Question about Kohler K-454-4S-CP Memoirs widespread lavatory faucet with Stately design a
Kohler K-454-4S-CP Memoirs widespread lavatory faucet with Stately design Problems & Solutions when the fawcett is turned on(hot water) ,water starts to leak from under the housing that covers the interior cyclynder. Is it the o-ring type washer(s) that need to be replaced ?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: Greetings, I have kohler
That is a common problem and one that is very hard to fix once the water has been leaking for a time...the leaking water will leave a mineral residue that will keep you from being able to adjust the brass nut that you say will not move....
What you really need to do to stop the leak is to turn the brass nut down, or tighter to put more pressure on the packing around the stem to keep it from leaking...
If you cannot turn the nut anymore then you have no choice but to replace the faucet... if you force the brass nut too hard you will break the faucet anyway...
I have tried to use a penetrating oil like PB Blaster or WD-40 with limited success...it maybe worth a try...just be careful that over spray and run off do not ruin the finish on the sink...
heatman101
Posted on Jun 22, 2011
  • 92 Answers
SOURCE: The cold-water handle on my
He needs a handle puller. Once the screw is removed the handle puller has a long point on it that goes into where the screw was and then the outside of the handel puller clamps around the handle. You then turn the T part of the puller and up come the handle with no damage
Best of luck Rich
Posted on Sep 07, 2011
Dripping water unless I totally shut off cold water line.
If you will make contact with George at M-One-Specialites he can track that down for you and help you get that fixed.
He has a very extensive list of repair parts for faucets.
Rod
US Parts Center
Jan 29, 2013 | Kohler K-12265-4-CP Fairfax Widespread...
The cold-water handle on my Kohnler K-454-4S Memoirs Widespread Lavatory Faucet is dripping. Kohler sent me replacement cylinder GP77006-RP, but my handyman can't remove the handle without fear of...
Best of luck Rich
Sep 03, 2011 | Kohler K-454-4S Memoirs Widespread...
Our Kohler K-454-3S is leaking when we shut it off.
replace the (either) O rings or washer, if its a washer setup I recommend replacing the seat also you can click on this link to see a normal repair for your problem ,, http://www.youtube.com/watch?v=ubp2W-3thOo Please take a moment to rate my reply and research for your problem,, Thanks Good Luck
May 08, 2011 | Kohler K-454-3S-AF Memoirs+ Widespread...
Our cold water handle has to be removed and cleaned every month or so in order for the fawcett to move freely. The hot water handle seems to be fine. It's a Kohler forte and is around 3 years old. Thank...
This is due to impurities in the water. The hot water heater separates alot of the crud in the water and the cold water goes right to the sink. adding a filter to your system will prevent the buildup.
Thank you Joe
Feb 15, 2011 | Kohler Forte Two Handle Centerset Lavatory...
One of the handles on my Kohler faucet does not turn (at all). The model is very similar to the Kohler Memoirs centerset faucet I've noticed that the other bathroom faucet (dual sinks) is beginning to be...
Removing the faucet stems and coating them( inside and out) with plumber's silicone lubricant should solve the problem. If the stem is too corroded, you may need to replace the stem.
Sep 08, 2010 | Kohler Memoirs Centerset Lavatory Faucet...
Hot water faucet has seized up.
the cartridge is either broken or seized up due to rust in the line. make sure you turn the water off to the faucet and disconnect the supply tube from the stop (valve). be carefull with the supply tube , you might have to replace it so have one handy. try to clear the tube. then run a little water out of the stop to see if you have water running to the faucet or if it is plugged with rust. then go to the top of the faucet and remove the handle so you can get to the cartridge. use soft jaw pliers to gently pull cartridge out. look at cartridge and see if the are any defects. if so you will have to replace it , take the cartridge to your nearest Ace Hardware, Home Depot, Lowes , or Menards and show them your cartridge and they will get you a new one. if it is a special order faucet call the manufacturer with model number and they will help you. when you reinstall new cartridge make sure you clear out any debris and use valve grease to lube up your new piece. reassemble and turn water back on.
hope this helps
Jul 06, 2009 | Kohler Memoirs Stately K-452-3S-CP Two...
Kohler K-454-4S-CP Memoirs widespread lavatory faucet with Stately design a Logo
70 people viewed this question
Top Kohler Plumbing Experts
Mike
Donni Steen
Are you a Kohler Plumbing Expert? Answer questions, earn points and help others
