Question about Lorex Lw2002w 2.4" Lcd 4-channel Ultra-digital Wireless
Battery not holding a charge on a lorex lw2002w receiver. Is the battery replaceable? If so where can I buy it?
Need Owners manual 4 Lorex LNC201
About 75,300 results (0.48 seconds) Search Results
    [PDF]LNC200 Series LIVE Ping Wireless Network Camera ... - Lorex
    https://www.lorextechnology.com/.../LNC200_SERIES_MANUAL_EN_...
    Oct 16, 2012 - If you require further installation assistance, please visit ... Thank youfor purchasing this Lorex wireless network camera. This user's guide refers to the following models: • LNC201. • LNC204. Contents. Before you start, make ...
    Lorex Support - product manuals and remote video monitoring
    https://www.lorextechnology.com/support/
    Lorex Support - Get online help for your setup problems using lorex self-serve and access your lorex information, products manuals and documentation. ... Find out all the ways you can get support and service for your Lorex products. ... Some products may have the Model Number located inside the battery compartment.
Jan 25, 2016 | Lorex Home Security
Battery wont hold charge model #WL 2401
I have the same Lorex unit and was down to no more than 5 minutes of battery life. After disassembling, I found that the lithium ion battery was bulging, a sign of battery failure.
A Google search of the number imprinted on the battery (503778) lead me to a seller in Sweden with these battery specs:
  • Polymer battery 3.7V 1600MAH 503778P 78 * 37 * 5MM electric GPS navigation eBook
I ordered the $10 battery (free shipping) and received it in about two weeks. I then swapped in the new battery (splicing and soldering to the old leads). I now get about 2-hours of video-on run time while on battery.
Jul 21, 2013 | Baby Gear
I need to reset my password on my lorex l154-81. Is there anyway possible to do this???
You would reset it just as you would reset the bios password on a pc. Remove cover to dvr to gain access to the inside of the unit. On the main board you will see a cr2032 battery. Remove the battery, power up the unit ( with battery out) and once the unit powers on it will say " system reset please power off". After powering the unit back off re-install the battery, power the unit back on and the system in now reset.
Jan 21, 2011 | Lorex L154-81
Does the lorex dvr support my MAC os on my pc
Hi Kavya,
Which model of Lorex DVR are you using? Currently, only some of our security DVRs are compatible with Mac OS X (via Safari). Our line of Edge and EDGE+ DVRs (LH300 Series) are Mac compatible and offer full remote viewing, playback, backup, and setup using Safari.
Please give us a call at 1-888-42-LOREX(56739) or visit us online at www.lorextechnology.com
Cheers, Lorex Support Team
Nov 11, 2010 | Lorex (L3501090)
GPS receiver of Magellan maestro don't hold the charge/do I need to change the battery inside or needed to be repaired?
you should charge it and then when youre done dont forget to turn it off if that dont work then got to radioshack and buy a new battery!
Apr 12, 2010 | Magellan Maestro 4040 GPS Receiver
Delphi SkyFi3 Battery WIll Not Hold Charge
You can buy a whole radio for as little as $30. I would even call XM and tell them you're going to cancel because your radio died, and they might sell you one if you guarantee to stay with them for a year?
Aug 02, 2009 | Delphi SKYFi3 XM Radio Receiver
Gps wont turn on without it being connected to chargers
This means that the internal battery of the gps system is completely dead and can not hold a charge. All you will need to do is replace the battery and it should work like new. The battery is fairly cheap to buy and replace.
Jul 01, 2009 | Magellan Maestro Elite 4370 GPS Receiver
My battery is not charging and i just replaced charger
There is probaly a loose connection from the input for the charger.
but sometimes thats not the problem.
This happenned to me before , and I just called the company that made the laptop, and they said to just buy a new battery instead of going through the trouble of trying to repair it, which would take about 15-$ and 2 weeks. I would just buy a new battery for about 30$.
Feb 23, 2009 | Gateway M305CRV Notebook
Lorex Lw2002w 2.4" Lcd 4-channel Ultra-digital Wireless Logo
119 people viewed this question
Top Lorex Home Security Experts
Henry  Thomas
Henry Thomas
Lawrence Oravetz
Are you a Lorex Home Security Expert? Answer questions, earn points and help others
