Question about Lands Phones
Panasonic KX TA824, Verizon FiOS, When i type extension 101 from a voip phone i get extension 110, from a cell it works, never had this problem on copper just with fios.
  • 1 more comment
  • carl_diesing Apr 06, 2011
    He did not answer my question.
  • carl_diesing Apr 07, 2011
    This is a DTMF issue, i'm looking for a technical solution.
  • carl_diesing Apr 08, 2011
    Thanks Carl, yeah, I've never used FixYa so I decided to see how good it was. I'm a big believer in getting many different opinions. Truth is it seems that FiOS believes the problem is on their end and a trunking issue. I'll let you know if anything changes.
  • Lands Phones Master
  • 2,460 Answers
You were doing fine in the free forums. Your first digit is probably breaking up from the VoIP phone, either it's cutting the audio through on a bounce or the first digit is being resent. A good digit analyzer will prove it. Try dialing 12 anything or 13 anything and see if you ring 112 and 113, or just stop at 2 digits and see if you're still getting 3. I don't have an answer but to try a different VoIP phone and/or look at the ATA.
Carl
Posted on Apr 08, 2011
  • Carl Navarro
    Carl Navarro Apr 08, 2011
    Thanks. Be sure to post the follow up in the other forum where you posted.
    President:
  • 3,278 Answers
Hello, Carl.
If you had the same VoIP phones and this occurs with all of your phones and the only change you made was moving to FIOS, then contact Verizon. Moving to FIOS is the only variable.
Hope this helps.
Posted on Apr 06, 2011
    Top Expert:
  • 79,865 Answers
Test
Posted on Apr 05, 2011
  • yadayada
    yadayada Apr 05, 2011
    I am sorry, answered this question in error. Please disregard.
I want to turn off the beeping when i place someone one hold
The beeping when someone is on hold comes from the main control box, not from the phone itself. You must be able to enter the Panasonic system's programming mode from a display phone connected to Jack 1 which is usually extension 101 in both the older 624 system and the newer 824 system. The Programming Code is "111" and this is covered in the KX-TA824 "Programming Manual" Version 3.0 on page 27. The two choices are "External" and "Tone," and you want "External" which deactivates the beeping tone and activates the miniature (3.5mm) phone jack on the control box for incoming audio (Music on Hold: "MOH"). By selecting "External," hold will be silent (no beeps) unless you connect an audio source to the jack. Entering the programming mode is covered on Page 15.
Apr 04, 2014 | Panasonic KX-T7731 Corded Phone
How to set delay ring Panasonic KX-TA824
First assing the flexible ringing day, night, lunch in programs 408 to 410, the assign the delay ringing for the extensions you want in 411 to 413.
Jan 25, 2014 | Panasonic KX-TA824PK Phone
This is for the kx-ta824. I am trying to add 82470 extension card to get 32 extensions.
That would be a trick. 824 means 8 lines and 24 extensions. An 82470 fits in one of the 2 remaining slots of the 824 system and it has no lines and 8 extensions. For the price, it's a pretty worthless card, as it will have no resale value. I think the price difference between an 82470 and an 82483 (3x8) is about $100 and maybe $50 more than an 82481 (2x8).
Carl
Aug 25, 2011 | Panasonic KX-T7730 Corded Phone
How do we make internal calls with Panasonic KX-T7433 handsets?
By default, Panasonic numbering is 101-164 and 201-264. The Intercom gives you dial tone and you dial the 3 digit extension number. Dial 0 should ring extension 101. Normal digital phones start at 101-116 on a TD816/1232 cabinet.
Carl
Jul 13, 2011 | Panasonic KX-T7433B Corded Phone
Hi..Caller ID function not working on our base and handset phones Model No. KX-TGA641. Used to, but now does not. Pls help! Thank u
I have a problem on a Panasonic two line handset phone that when one line is plugged into a VoIP line, it makes the caller ID not work for the other line. After going back and forth with Verizon, we finally figured this out. I haven't figured a workaround. And in my old house I used to have a VoIP line and a FiOS line and it worked. So either something has changed or the difference between FiOS and regular copper line from Verizon is making the difference. peter@phipower.com
Dec 30, 2010 | Panasonic Lands Phones
The Panasonic KX TA824 system phone How can I make that when somebody is on the corldess phone that is connected to the system Lets say extension 105 when a call comes in to extension 105 I should not get...
On an 824 you only have one option, call forward busy/no answer. It means all calls transferred to that extension would go somewhere. Since an 824 has no ring groups, you can't make the system do a double hop (CF busy to 101 and if 101 is busy CF to something else) but at least it's something.
From the cordless, dial 712 1xx # with xx being the extension of the forwarded number. (710# cancels).
Carl
Oct 31, 2010 | Panasonic KX-TA824PK Phone
Can`t change the hour on my telephone.Panasonic KX-T7431 Digital.
You can, but the real question is will it stay changed? The time is altered by CID or by manual change. If you change it and it changes back, then whatever transmits the time after 2AM is messing with the clock.
As a start try PROGRAM **1234 from extension 101 and dial 000. It will guide you through the sytem time. If it doesn't stay the next morning, then you probably have VoIP or some alternative box sending you the wrong time.
That's a whole other thread.
Carl
Aug 30, 2010 | Panasonic KX-T7431 Corded Phone
D1232 extension programming issue
Welcome to Panasonic TD programming....
Even though the hardware doesn't exist, the numbers do. The universe of 101-164 and 201-264 are already taken. Oops, 200 might be available, 100 might be available. 167 and 168 and the 80's might work.
It's a 3 step process. Change 210 to 200 change 225 to 210 and change 200 to 225. There's your "swap".
Now, keep in mind that the XDP port for 110 is 210 and if your voice mail is analog.....Ah, but that's another thread.
Carl
Sep 19, 2008 | Panasonic KX-T7453 Corded Phone
Caller ID still not right
I have the same problem. By chance are you using Verizon FIOS? One line is VOIP and shows CallerID and the other does not.
Feb 08, 2008 | Panasonic KX-TG6702B Twin Cordless Phone
Lands Phones Logo
105 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
