Question about Pacific International Schwinn Protocol 2.0 26-Inch Dual-Suspension Mountain Bike
I loosend the front wheel berings on a quick release wheel but know when I try to tighten it, it gets to tight and doesn't spin right
    Brigadier General:
  • 8,546 Answers
Having trouble attaching front wheel. Owners manual or instruction sheet misplaced
How to install quick release front wheel on bicycle - YouTube
? 0:58
https://www.youtube.com/watch?v=xFx7UXyjW4Y
Dec 11, 2011 - Uploaded by Bicycles Online
When I went to reinstall my wheel my brake pads were stuck together and I don't know how to get them apart ...
How To Remove The Front Wheel of a Bicycle - YouTube
? 7:31
https://www.youtube.com/watch?v=BNwa0lONtbc
Jun 30, 2012 - Uploaded by cjhoyle
This is a quick tutorial showing how to remove the front wheel of a bike. ... Getting the lightly tightened other nut off shouldn't be aproblem.
Removing and installing your bicycle wheels - YouTube
? 4:06
https://www.youtube.com/watch?v=QslgCn9QX5I
Dec 25, 2015 | Cycling
How to change a wheel on a roller-skate?
Following the below steps you can easily change wheels of your roller skates :-
*Figure out which side of your tool fits snugly over the nut.
*Your nuts shouldn't be too tight and the wheels slide right off the trucks.
*I suggest putting a towel down to put your wheels.
*Putting wheels on is similar to taking them off. Make sure your nut is facing the right way.
*Tighten the nut with your fingers until you can't anymore.
When I purchased for myself they have given free services for it and thus I learned watching them only.
Jan 13, 2013 | Sport & Outdoor - Others
I am assembling a 24 inch girls Traverse bike. Not quite sure how the front wheel goes on the fork! Seems obvious but I got confused when I saw the quick release assembly packaged with the pedals. Not...
The Front Quick release is used on the front wheel, if the axle is hollow. If it has nuts on the outside of the axle then it does not belong to the front wheel.
The front quick release is actually quite easy.
1) Place the front wheel into the forks.
2) unscrew the nob end of the skewer (opposite the handle end)
3) insert the skewer through the axle (from right to left if looking at the front of the bike)
4) Screw back on the nob a few turns.
The actual working of the quick release skewer is a cam (there is an imprinting on the handle that says open and close. make sure the handle has "open" facing out for the next step.
5) Holding the handle in your right hand, turn the nob with your left hand until the unit is almost tight.
6) Test the tightness by flipping the handle from "open" to "close". this is a cam. if you have the correct tightness then it will have some resistance to close the lever but not be difficult. If it is really hard, then back off the nob a little and try again. If it is too easy then tighten the nob a little and try again. After a couple of tries you will get it.
7) final test. Take a finger and try to flip open the lever, if you can't then its good, if you can then go back to step 6.
Dec 12, 2010 | Schwinn Cycling
No Rear Quick Release
Some less expensive bikes do not come with quick release skewers. You just unscrew the bolts like you would any other using a wrench or socket. The will probably be really tight so you may need to bear down or use a cheater pipe. Unfortunately, these bolt on wheels tend to be solid axles and cannot take a quick release skewer. You would need to replace the wheel.
May 20, 2010 | Schwinn Miramar Women's 21Speed Bicycle
Chain has become loose and will ride off gears while in use
If its a singlespeed:
Examine the tightness of the bolts that attach the axle to the frame by loosening then with a wrench. If it was loose that could have been the problem.
Now check the alignment and equal spacing of the wheel inside the frame. Pull the wheel back in the dropouts so the chain has an inch or two of looseness. Lightly tighten the bolts and check again and crank the wheel with the pedals and spin. Check the chain and equal alignment of the wheel. Tighten the bolts that attach the wheel to the frame.
If its a quick release, make sure that when tightening you apply a good amount of force to close the lever at least 90 to 100 degrees. And do all of the above.
Feb 09, 2010 | Cycling
Blade popping off front wheel
Is the axle tight? Has the tool been dropped to warp the frame? But a quick fix if everything else is OK is to loosen up the axle and put a THIN metal shim on the backside of the axle and then tightening it back down.
Jul 29, 2009 | Makita 2107F Portable Band Saw
Replace rotor
when you take the front wheels off you will see a silver center cap in the middle of the hub take a flat heat screw driver a gently pry the cap off (don't worry if you mame it alittle) there will be a cotter pin a nut and a washer then you outter bering take them all off then the rotor will come off the inner bering is still in the rotor being held by the grease seal pry the old grease seal off and remove the bering. check berings for wear like ruff spots. make sure you buy a new grease seal for the rotor. reverse removal procedure re pack berings with fresh grease inner first place bering in the rotor put seal in place will need to tap it in carefully when putting the nut back on tighten untill snug not tight check for specs if you want i usually make it snug then 1 more turn do not over tighten and you will be good
Apr 07, 2009 | 1998 Ford Ranger SuperCab
Rear wheel problem on Raleigh X1 mountain bike
Three things come to mind when I read your question. First is the rear wheel bearings. Spin the wheel back and forth while holding onto it. See if you can feel any vibration or a rough feel in the wheel. I would think that if it were the wheel bearings you would hear or feel a grinding noise when you are riding.
If your rear wheel has a nut on both sides and you tightened them and that didn't work this means you must have the quick release system. You can tighten this by unclipping the wheel. Then hold the side that has the quick release lever. Hold onto the lever itself. Then turn the other end a little bit clockwise. Then put your wheel back on the bike and reclip the lever. It should now feel tighter. You may have to readjust the quick release lever a few times until you find the desired tightness.
Lastly the problem could be that your frame is worn out or broken somewhere. This would only show up when you are out riding because of your body weight and the strain put on the frame while you are pedalling. Also the part of the frame where your rear wheel sets may be chewed up. This would cause the wheel to never really tighten on the frame and could also cause the rear wheel to move.
I had a bike where the quick release wheel stystem went bad and it would not tighten on the frame. I believe the rod that went through the middle of the wheel hub was stretched and would just not tighten onto the frame.
I hope this has been helpful
Mar 17, 2009 | Crank Brothers Joplin Adjustable Seatpost...
Girls Huffy 16" bike - back wheel does not spin freely. It tightens up after a few spins.
Try the bearings. Try a different wheel and rim. If its not the wheel then the crank bearings( ones the pedals are on) could be bad or the chain could be not set right.
Dec 24, 2008 | Huffy 16 In. Girls Dora The Explorer...
Problems with releasing front wheel lock
I have just fixed my stroller which had a similar problem. The wheel was still swivelling but it was sticking slightly. I noticed that the pin that locks the wheel in place was half out and therefore the wheel was getting caught on it. I undid the nut that holds the end of the wheel lock cable in place and tightened this as tight as I could which pulls the pin back into place (making sure that the switch is in swivel position). I then put the washer and nut back on (making sure cable was as tight as possible).
May 30, 2007 | Zooper Boogie Jogger Stroller
Pacific International Schwinn Protocol 2.0 26-Inch Dual-Suspension Mountain Bike Logo
75 people viewed this question
Top Pacific International Cycling Experts
dante
Michial Gueffroy
Donald Ayers-Marsh
Are you a Pacific International Cycling Expert? Answer questions, earn points and help others
