Question about Acer AL2223W 22" LCD Monitor
My side bar on acer monitor screen has become white. How can I solve this problem? I was told to click on the auto configuration key but can't find it.
  • 335 Answers
If you have a white bar running up the side of the monitor, then it is probably dead. Acer has 3 year warranties on their monitors so you should call them to see if you are still in warranty. If so, they will fix it free!
If more than 3 years old, try it on another pc. If it is the same on another pc, get a new monitor.
Hope this helps!
Regards,
Joe
Posted on Apr 04, 2011
My Acer LCD Monitor shows the , auto Configuration menu and is on a black screen.
How did the auto configuration came about? Try pressing the buttons before powering up. Maybe some of it are stuck.
Feb 21, 2015 | Acer AL1916W 19" LCD Monitor
Al1916w acer monitor screen coming white
If you hold a flashlight to the screen when you turn on the laptop,do you see your windows booting up in the dark?
Aug 13, 2014 | Acer Computers & Internet
Trying to fix laptop screen that is whited out
Alex,
A primer first;
An LCD screen cannot produce light. It needs an additional light source.
A Backlight is the additional light source.
A Backlight can be a CCFL, (Or two of them), or a series of LED's.
(Light Emitting Diode)
The Acer Aspire 5732z-4855 Notebook PC uses a single CCFL, according to all of the websites that sell the LCD screen. One example,
https://www.laptopscreen.com/English/model/Acer/ASPIRE~5732Z-4855/
A CCFL is a Cold Cathode Fluorescent Lamp.
Similar to Fluorescent lighting used in homes, and businesses, but on a MUCH smaller scale.
[Average thickness is 2mm. That is a little larger than 1/16th of an Inch, or about the width of this letter -> H
Average length is almost as long, as the LCD screen is in height.
A general example of a CCFL,
http://www.laptoprepair101.com/laptop/2007/12/09/replace-laptop-backlight-ccfl-lamp/
View the last 8 photos ]
A screen Inverter is used to convert the power from the laptop, for the LCD screen, and Backlight.
(For a CCFL. Most generally LED backlighting does not use a screen Inverter )
Example of a screen Inverter used on the Acer Aspire 5732z series of Notebook PC's,
http://www.lcd-inverter.co.uk/screen-inverter.php/acer_aspire+5732z_lcd-inverter_6130.htm
Primer over.
Your problem could be the graphics chipset, Video Cable, screen Inverter, or LCD screen.
Diagnose:
1) Graphics Chipset;
Laptop OFF, monitor OFF, connect a VGA monitor to the VGA port, on the laptop.
[ Left rear side has the VGA port. It is White in color. This is a general example of a VGA Cable, and VGA connector, (Port),
http://en.wikipedia.org/wiki/VGA_connector ]
You can use a CRT type of monitor, (Looks like a small TV), or a flat LCD screen monitor that has a VGA cable attached.
Turn the monitor on. If a CRT type allow it to warm up.
Turn the laptop on. By factory default the display should show on the external VGA monitor.
If not;
Hold the Fn key down, (Bottom row, second key from left), and at the same time tap once on the F5 key.
(The F5 key is the Display Toggle-Over key)
Still no display on the external VGA monitor?
There are at least 3 display options available;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down again, and tap once more on the F5 key.
Good graphics (Display) on the external VGA monitor, means you have a good graphics chipset.
Bad graphics on the external VGA monitor, means you are looking at motherboard replacement.
Sitting here in this chair in front of my computer, I'm willing to bet your graphics chipset is OK.
If the graphics chipset is good your problem is the Video Cable, screen Inverter, or LCD screen.
2) Video Cable:
This is high on the list for being the 'culprit' of the problem.
Why?
Because of it's location.
The Video Cable connects to the top of the motherboard, in an area under the Switch Cover, and slightly to the right of the left Hinge.
It then routes UNDER the left Hinge, and up into the Display Assembly. From there it connects to the back of the LCD screen, and to the screen Inverter.
Just from normal opening, and closing of the laptop over time, the Video Cable may become pinched.
This can lead to pulling on the Video Cable, and may cause a loose connection at the motherboard side, or LCD screen side. Shouldn't be a loose connection at the screen Inverter.
This means the Switch Cover must be removed to check the connection, at the motherboard side. The Display Assembly is opened up, and connection at the back of the LCD screen is checked.
Visual inspection will do NO good. You CANNOT see usually if the connections are tight, or not. It is BEST to physically see if you can plug the cable connections in tighter.
Loose connections of the Video Cable are high on the list, for your kind of problem.
Next is damage to the Video Cable. See if there are any obvious signs of damage to the sheath of the Video Cable. Obvious damage to the sheath may mean damage to the tiny wires inside.
(Stretched/Broken)
Even if there are no signs of damage to the Video Cable, and if physically checking to see if the Video Cable's connections are loose, and this doesn't solve the problem; the Video Cable should be removed, and it's wires checked for continuity with a multimeter.
(You can take it to a 'Mom and Pop' computer store, and have it checked for a few bucks )
Video Cable checks out, the next hardware part in the diagnoses is the screen Inverter.
[Acer nomenclature for the Video Cable is LCD Panel Cable]
3) Screen Inverter:
The thin plastic frame in front of the LCD screen is the Display Bezel.
[Acer nomenclature for the Display Bezel is LCD Bezel.
The LCD screen is an LCD Panel.
Display Assembly is an LCD Module ]
The screen Inverter is located behind the LCD Bezel, and mounted towards the bottom of the LCD screen.
Testing requires a sensitive multimeter. Read fairly expensive,
http://www.fonerbooks.com/test.htm
If you do not have access to a sensitive multimeter, then the next course would be to replace the screen Inverter.
Due to the low price of a new one, this parts changing solution IMHO is feasible.
Screen Inverter is not the problem, then the problem is the LCD screen.
I believe your problem to be the Video Cable. Loose or damaged. If not then the screen Inverter.
This is a link to a free Service Manual,
http://www.tim.id.au/blog/tims-laptop-service-manuals/#toc-acer
Drop down to the subheading - Aspire 1200. (1200 in Blue)
Go down to the 9th line (5720G in blue), scroll across, and click on the blue - 5732Z
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name (5732Z) it may take up to 30 seconds, before the first page comes up.
This is a direct link. If clicking on it does no good, then copy it, and paste it in your browser search bar. Then press the Enter key,
http://support.acer.com/acerpanam/Manuals/acer/2009/ServiceGuides/SG_Aspire_5732Z_5332_10192009.pdf
1) Removing the Switch Cover - Page 71
2) You MAY be able to split the LCD Module open, (Display Assembly), and be able to physically check the video cable to LCD screen connection.
If so go to Page 95.
If not remove the LCD Module - Page 73
For additional questions please post in a Comment.
Regards,
joecoolvette
Oct 06, 2012 | Acer Aspire 5732Z-4855 Notebook
White Screen Problem while starting Acer Aspire 2710z laptop
Unfortunately it sounds like bad memory. Depending on your memory configuration you can try swithing out memory sticks. Check with your manufacture about memory configuation requirment before trying this. If you're unsure how to do this it's best to take it to someone who does know how.
Mar 25, 2010 | Computers & Internet
A MESSAGE KEEPS POPPING UP ON MY SCREEN AUTO CONFIG HOW DO I STOP IT
Think I fixed it.. My monitor kept flashing autoconfig and shaking a little, so I went to control panel - clicked on system - clicked Hardware - clicked on device manager - clicked display adapters - and updated the driver. Re-booted computer..
So far so good... Fingers Crossed..
Oct 23, 2009 | Acer Computers & Internet
Acer x193w LCD Monitor repeatedly auto configures.
Here is a link to get the manual:
http://www.acerpanam.com/synapse/data/7117/documents/X193W%20(Qisda)%20user's%20manual.pdf
Starting on page 15 are the directions for the monitor controls. Page 17 indicates a "RESET" feture to Clear the Old-Statuses of "Auto-Configuration". There are quite a number of setting for this monitor.
Jun 11, 2009 | Acer X193W LCD Monitor
Desktop problem
It is possible that the task bar is in 'auto hide' First thing you should do is rest your cursor on all four sides of your desktop for a few seconds and see if it appears. If it doesn't than move your cursor to the bottom of the screen and right click and choose 'properties' and uncheck the 'auto ide box'. I am not positive that this well solve your problem, but its the best I can do at the moment. I well research it and find more info, than I well post it for you.
Jan 20, 2009 | Acer Aspire One PC Notebook
Problem with ACER aspire 4710Z
hi, if u have the orignal bill, ACER has international warranty, u can take it to any ACER service center, or try uninstalling the video drivers and reinstalling it. if that does not solve, then u need to go to ACER.let me know
Jan 05, 2008 | Acer Aspire 5610-4648 Notebook
Hooking up a second ACER monitor as an extended desktop
I have 2 acer AL2016W's and have the same problem. The earlier ones with the VGA only are the problem from what I can see, they just don't play nicely with the video card for some reason.
First, on your main monitor, click "Show displays in menu bar" on your monitor control panel. This will let you set the resolution for each monitor from the main one, click on the little monitor icon on the top right screen to do this.
If that doesn't work try this:
Connect one acer as the main monitor and one crappy vga crt monitor as the second.
Set mirrored desktop in the system preferences so that the crappy CRT is displaying the exact same resolution as the acer. (1680x1050 59.9Hz)
Disable mirrored desktop. You should now have an acer and a crappy CRT both running 1680x1050 in extended desktop mode.
Shut down, reconnect the acer in place of the crappy CRT.
This should "trick" your video card into having the right resolution, otherwise you'll just get the stupid "input not supported" screen, with no ability to auto configure or use any of the built in controls.
Nov 20, 2007 | Acer AL2016W 20" LCD Monitor
Blurry Screen
Delete the plug and play monitor driver and reboot. Trouble is this worked for only one day and had to be done the next. Wish I knew a permanent solution. It appears to be a driver issue. Will see if I can reload the monitor specific drivers instead of plug and play.
Feb 23, 2007 | Acer AL1916B 19" LCD Monitor
Acer AL2223W 22" LCD Monitor Logo
66 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
