Question about Whirlpool ET1WTKX Top Freezer Refrigerator
Water is coming down thur the 2 vents in the refrig, and the freezer has ice on the floor.
  • Whirlpool Master
  • 3,361 Answers
The defrost drain line in the freezer has frozen closed with ice.
Defrost the drain hole with hot water or a hair dryer.
Turn the refrigerator OFF before doing this.
Posted on Apr 04, 2011
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Water accumulates and freezes at the bottom of our freezer. Once the bottom of the freezer has formed a slab of ice the water eventually drains out of front of freezer and leaves a good size puddle on our...
your refrig. goes through a periodic defrost cycle whereby this water is produced. It is supposed to travel down to the evaporation pan near the floor of the frig. Your evaportation pan may be clogged, remove the front lower panel and get a flashlight and examine it., or the tube leading from the freezer floor may be clogged or have ice it it. Check that out and if the opening of the tube has ice in it, melt it with a hair blow dryer
Oct 06, 2009 | Refrigerators
Water on floor of refrigator. Our refrigator is a Frigidaire Crown series model no. F44Q18CC. We have never had the ice maker hooked up sence we owned our refrigator.We bought it about 5 years ago. Lately...
Water collects INSIDE the refrigerator ? It is coming from the freezer. You have a plugged up defrost drain - look for a drain cup inside your refrigerator section agains the wall, this leads to a plastic tube that connects through the back wall of your refrigerator down a drain tube - see if you can remove this and with an object pass it through the drain tube to dislodge anything obstructing the water passage - if you do not have a drain cup in refrigerator then look in your freezer behind the panel you should see a drain hole below the evap fan, where the ice melts and drains through the tube - if this area is iced up or blocked water will overflow to your refrigerator through the cooling vents :)
Sep 18, 2009 | Frigidaire Refrigerators
Frost inside and ice on floor of freezer
The water can only come from 2 places, the drain is blocked or the ice maker is over filling.The temps are too good to have any other things going wrong. Let me know, Thanks, Sea Breeze
May 18, 2009 | GE Refrigerators
My refrige leaks water on the floor from the freezer side on the left. I turned the water off and disconnected the water line. Still once or twice a week the refrige leaks water on the floor.
Sounds like ice build up on the freezer coils. Disconecting the water line doesn't stop regrigerant from flowing through the coils since they are still working. Easiest way would be a hair dryer to melt the built up frozen consensation. After you should see no water on the floor and you can turn the water back on (i assume the water is for your ice water and ice cube tray).
Apr 16, 2009 | GE GSH25JFR Side by Side Refrigerator
Water leaking onto floor
unplug it again , sounds like your drain line has frozen, instaead of defrost water going down the tube and under refrig in drain pan, becuse tube is frozen its draining into freezer compartment and eventually spilling out through front of unit. totally defrost unit and behind back wall of freezer youll see a metal trough designed to catch water, in the center (under the ice is gonna be the drain hole, pour boiling water down until it runs freely
Feb 23, 2008 | Kenmore 71279 Bottom Freezer Refrigerator
SIDE BY SIDE MAGIC CHEF REFRIG
your drain line is frozen. you nee to put hot water down it
Feb 17, 2008 | Magic Chef (CSD2610KRW) Top Freezer...
Whirlpool ET1WTKX Top Freezer Refrigerator Logo
76 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
