Question about Philips SA1928 MP3 Player
How can i remove the cover of my mp3 player ? cause i want to fix and soldered the socket for earphone cause its been damage.
    Problem Solver:
  • 10 Answers
I dont think u should remove the cover and do any repairs on your mp3 player you might void the warranty
Posted on Apr 05, 2011
How do i make earphones and head sets work for my coby again? the mp3 itself works fine, but when i stick earphones into it, no sound will come out. audio can only be heard if u jiggle the phone piece at a...
The earphone socket on your player is faulty. Most likely the socket is loose on the circuitboard and needs to be re-soldered to the circuitboard.
If you do not have the DIY skills, then take it to your electronic repair shop.
May 06, 2011 | Coby MP-610 MP3 Player
Only my right earphone works on my sansa clip 4gb. i know its the player because i tried different sets of headphones. Whats the problem?
The phone socket in the player is probably faulty or it mat have a dry solder joint connection.
Either way to solder or replace the headphone socket requires dismantling the player.
Jan 21, 2011 | SanDisk Sansa Clip MP3 Player
When I plug the earphone jack into my MP4 player, I only get sound from one earpiece. I have tried several earphone sets to determine that it is not a problem with the earphones
Hi, this is a very common problem, after you have pulled the ear phones in and out a few times the solder on the earphone socket becomes brittle and breaks making you lose the connection with the circuit board, now as you have ruled out it being an earphone fault then the only possible problem could be the solder.
now sometimes if you wiggle the earphone at the part that goes into the mp3 you can sometimes get the sound working again, but this dont always work so dont rely on this,
now the problem you have is that the cost of getting this part fixed would cost a lot more than buying a new mp4 player.
the cheapest place to try and get this fixed is a tv repair shop, tell them exactly what the problem is so they dont have to test it and see how much they will charge you to resolder the earphone socket back in place properly.
that would be the cheapest option and could possibly get it working again if they will do the work for you
im sorry their is no easy fix but without getting the earphone socket re-soldered it will just never work
let me know if you need further assistance ok
Aug 18, 2010 | Naxa Electronics Audio Players & Recorders
Mach Speed Eclipse: No Vocals!!
This is caused by the grounding connection on the earphone socket becoming disconnected, either due to faulty earphones or poor soldering.
If changing the earphones does not work, then the only fix is to dismantle the player and re-solder the headphone socket connections.
Aug 03, 2009 | Audio Players & Recorders
Ear phone not working
If it is not your headphones then try checking the connections. Remove the back and check the connections to the audio socket. They may need re-soldering to the main circuit board.
Hope this helps,
Mowcius
Jul 02, 2008 | Rio Carbon MP3 Player
Mp4 ear phones
hi the problem will be with the earphones after a bit of use the wires inside the plastic casing covering the wires where they plug into the mp4 these wires fray and eventually short out it is best to replace the earphones as soon as possible as shorting out will eventually cause the mp4 to overheat and short out.
If you have replaced the earphones and are still getting the same problem then it will be the solder points on the jack plug that you plug the earphones into the solder eventually will work lose causing bad connection but first repalce earphones then if you still have the problem but you probanly wont as the solder failing isnt a known problem with this product then you will need to take the cases off and get to the board where the earphone socket is soldered onto the board then you need to resolder the solder joint that connect it to the board.
But first repalce earphone with new ones as using someone elses or old ones might have same problem let me know if you need further assistance
Jan 16, 2008 | Konaki MP4-NS MP3 Player
My mp3 doesnt play music properly
This is caused by the ground connection from the earphone socket not making contact with the main PCB.
This can be repaired by anyone competent with a soldering iron.
The four contacts on the earphone socket need to be re-soldered.
Aug 28, 2007 | Philips SA1100 MP3 Player
Headset jack
Ok often this is caused by one of the cables in the earphones breaking.. try another set. Sometimes it can be the socket on the unit breaking at the solder joint on the PCB, if it is, and ya can solder? it is a pretty easy fix. But I would "Punt" for a broken earphone lead.
Aug 08, 2007 | SanDisk Sansa c200 MP3 Player
Lock up
Sounds like the ground connection (-ve) to the earphone socket is broken.
When you plug in the earphones, they ground through the control section on the board. Poor sound is another sympton of this problem.
If you have any soldering experience, dismantle the player, and re-solder the 4 connections to the headphone socket.
May 18, 2007 | Philips PSA232 (512 MB) MP3 Player
Sound capabilities
The symptoms you describe are caused by a break in the earphone socket ground connection.
If you are confident enough, dismantle the player and re-solder the 4 connections to the earphone socket.
Oct 04, 2006 | Philips GoGear HDD6330 MP3 Player
Philips SA1928  MP3 Player Logo
63 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
