Question about Dryers
Dryer is squealing...i assume it needs a bearing replacement...if so what is part number and how do i fix it?
  • Dryers Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Posted on Apr 05, 2011
Dryer runs but makes loud screeching noise like a fan belt or similar. Does some drive belt need to be replaced?
yes most likely it is the drive belt. pretty easy replacement. go to repairclinic.com or appliancepartspros.com for very good videos to show you how this is done. good luck
Jul 11, 2015 | Dryers
How do I stop dryer from squealing
the squealing noise is most likely a loose drive belt , the drum is powered by a large belt to a motor , the belt and idler pulley are most likeslyin need of replacement
Dec 11, 2014 | Dryers
Frigidaire affinity front load dryer
You need an upper felt and a rear drum bearing. If you buy the felt make sure you get the special adhesive to install it. The squeal maybe part of this or it could be the rear drum bearing. You can learn how to replace the rear drum bearing here in the article I wrote. http://gomestic.com/do-it-yourself/how-to-replace-a-frigidaire-dryer-rear-drum-bearing/
Jan 29, 2014 | Dryers
We have Maytag Neptune dryer that's a front loader, it's about 10 years old, not sure of exact model. We went to run it the other day and hear this high pitched squealing noise. We were assuming it was...
Yes it could most likely be the idler pully mounted in photo as part 38 Click Here=> Maytag MGD6300T Gas Dryer Part 38 is your dryers Idler & Pulley Assembly Part Number Click Here=> 8547174 There is no photo for that link but that is the OEM part number. When the bearings fall out of the pulley this begins a cycle of from bad to the belt (39 in photo) part number Click here=> Belt, Drive 8547168 Should you have more questions please ask, Thanks, Sea Breeze.
Sea Breeze
Dec 06, 2010 | Maytag MGD6300T Gas Dryer
Squeal when dryer turning
The problem is that your dryer needs a new drum bearing.
Jul 25, 2010 | Fisher and Paykel DEGX2 Dryer
Front bearing needs replacing
this will help to change front pads
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Feb 25, 2010 | Hotpoint Dryers
I have a dryer that is making squeal as the
Your problem sounds like drum rollers have flat spots on them or in need of lubrication.
If you have a front loading machine, Unplug the dryer, remove the front of the dryer. This will expose the drum and belt, remove the drum and belt and this will expose the drum rollers.
Check your rollers for flat spots, if they have flat spots on them replace them.
If they don't then they probably only need lubrication. Lubricate the shaft of the roller with a good grade of machine oil such as 3 in One oil. Reassemble the dryer, plug back in. This should solve you noise problem.
Good Luck,
I hope this helps
Oct 11, 2009 | Dryers
My dryer is making a really loud noise when the clothes are spinning in the dryer. There is a loud rumble and squealling noise.
The squealing noise coming from your dryer is caused by the front glides located on the top bearing, they act like a pad against the drum and when gone, will make an awful squealing. part number for the 4 glides that may be needed is WE3X87 this is a common problem as it is a wearable part. if you don`t replace these in time it will grind all the way through your top bearing and start to deteriorate your drum. if its been like this for a while you may also need a GE drum bearing they come in short and long sizes. and are relatively cheap to replace.hope this helps
Thanks
Oct 11, 2009 | GE DBSR453EBWW Electric Dryer
Noisy dryer......when engaged...making squeaking/squealing noise.
If the noise is like a shaking of rattling , like coins being shaked , then it is an object trapped inside the drum.
If instead the noise is a loud grinding , that may get louder on high speed, then it is usually a bad drum bearing.
If dryer is not cooling, check that the noise is not coming from the ventilation fan.
Rollers and belt tensioner can also make noise.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 09, 2009 | GE Spacemaker Washer and Dryer Electric...
Dryer really squeals
Ok this is a really broad question, Kenmore will squeal when a belt tensioner or motor bearing is out, a frigidaire or small kenmore with control panel above the door and serial number starting with x will squeal when the bearing is out on the drum or the motor. This is a general cover on dryer noise with a model like Kenmore series 80 I can give solutions ok?
Sep 20, 2008 | Dryers
Dryers Logo
Top Dryers Experts
Dan Webster
Dan Webster
