Question about Car Audio & Video
I have a 96 Cadillac DeVille the radio doesn't play in the back speakers all the time and when it plays in the back it doesn't play in the front, as well as turning on and off as it pleases, can you help me?
  • thisguy1101 Apr 05, 2011
    Well i bought a used factory radio from a 99 DeVille i hook it all up but the display says "lock" , How do I un-lock it? I found a website that will give me a code but I need a 4-6 diget security number how do i get that?
    Ok i have 96 deville and i think that my radio is bad so i bought a used radio from a 99 deville. When I installed it, all it did was displayed "Lock". My question is how do i retrive the four to six diget security number, so i can buy a code to unlock?
  • 823 Answers
Make sure all of your wires connectting to the speakers are in working order. then if you have made any alterations such as sub woofers or amps check those as well too. if all the wires havent been crossed check the head unit. look to see if you connected the power to the right wire because it would work a little bit if you connected it to the stand by wire. if everythign is in good working order then look into geting the head unit checked out.
the problem is in the wiring. make sure they are sealed (electrical tape) and not crossed according to the stereos specific diagram
Posted on Apr 05, 2011
    President:
  • 2,187 Answers
If you have the speakers directly connected to the radio, it may be an issue with the radio or if you have amplifiers set up it could be the amp. It is a possibility that it could be the wiring but is less likely. IT would be wise to inspect the wiring nevertheless as the solution for loose or bad wiring is usually the cheapest.
This may be caused by terminals at the back of the radio where you have the wires leading to the speakers installed. IT may be loose or the connections are bad. As for the radio itself see if balancing the bass and the treble increases the sound of the back or the front whenever it dies on you. Try different sources of signal if it matters, whether a CD or if you have an AUX, your mp3 player. If the sound changes it may just be the radio part that is faulty. Inspect the wiring to the antenna. Otherwise it could be the radio itself that could be faulty or the amp if you have one installed.
Wiring for 2006 cts stock radio
2006 Cadillac Deville Car Radio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Dec 03, 2016 | 2006 Cadillac CTS
96 cadillac why no sound from speakers
Search Results must be wiring problem to understand how to solve this jst download the pdf file from the link
Jan 15, 2016 | 1996 Cadillac DeVille
Putting stock radio back in this 96 caddy but has no sound just the clock what could this be?
If someone else put in an aftermarket radio, they probably used their own speaker wires, and disconnected the factory wires from the speakers.
Dec 07, 2013 | 1996 Cadillac DeVille
Is there any stereo wiring diagrams or codes online
Check this for 1995 Cadillac Deville Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: OrangeCar Radio Accessory Switched 12v+ Wire: YellowCar Radio Ground Wire: BlackCar Radio Illumination Wire: GrayCar Stereo Dimmer Wire: BrownCar Stereo Antenna Trigger Wire: PinkCar Stereo Amp Trigger Wire: N/ACar Stereo Amplifier Location: N/ACar Audio Front Speakers Size: 5 1/4" SpeakersCar Audio Front Speakers Location: DoorsLeft Front Speaker Positive Wire (+): TanLeft Front Speaker Negative Wire (-): GrayRight Front Speaker Positive Wire (+): Light GreenRight Front Speaker Negative Wire (-): Dark GreenCar Audio Rear Speakers Size: 6" x 9" SpeakersCar Audio Rear Speakers Location: Rear DeckLeft Rear Speaker Positive Wire (+): BrownLeft Rear Speaker Negative Wire (-): YellowRight Rear Speaker Positive Wire (+): Dark BlueRight Rear Speaker Negative Wire (-): Light Blue
Hope this helps.
Mar 27, 2012 | 1995 Cadillac DeVille
Toyota Corolla 1997 I've installed kickers in the rear (KS series to match the front)... had those going for a couple of weeks with no problems. Yesterday i went to install the KS400 series in the...
take one of the front speakers out and pull out the head unit and unplug a set of audio wires(front right, front left ect.) and hook it up directly from the radio to the speaker there for bypassing all the cars wires. If it works then there's a problem with the car's wiring(maybe an inline amp). If it doesn't work, then try a known good speaker from somewhere else(home stereo speaker for example) and connect it to the radio, if the speaker works, your radio is fine and there may be a problem with the speakers. If it doesn't work then you have a problem with the head unit.
Jul 22, 2011 | Kicker KS400 Coaxial Car Speaker
WHAT ARE THE SPEAKER COLOR CODES
2000 Cadillac Deville Car Stereo Wiring Diagram, SPEAKERS ARE HILITED
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: 6?
Car Audio Rear Speakers Size: 6?
Mar 29, 2011 | 2000 Cadillac DeVille
I need to see a picture of a the back of a cadillac deville 2000 radio. i need to see the wiring
Nov 03, 2010 | Car Audio & Video
What newer model of cars have radios that will fit my 1986 Cadillac Sedan/Deville? I prefer cd player and time display?
if your radio still works why not go for a mp3 player and an fm transmiter.that way you can down load as much music as you can take and not have cd*s in the car waiting to get stolen...you do know that the cd is now obsolete???(you can play your mp3 in any car with an fm radio......)NO WIRES.....
i down load to my phone and then set up the bluetooth (blackberry)and it also gives me route maps.....but then we are in front of you tech wise....but behind japan...clever what......
Aug 22, 2010 | 1986 Cadillac DeVille
What is the color codes for the radio of a 1994 cadillac sedan deville? the ends have been cut, so cant use a harness
from the factory service manual radio diagrams.
1994 Cadillac Deville Sedan Car Radio Wiring Guide
Car Audio Front Speakers Size: 4′ x 6′
Car Audio Front Speakers Location: Dash
Car Audio Rear Speakers Size: 6′ x 9′
Apr 07, 2010 | 1994 Cadillac DeVille
I need the stereo wiring diagram on a 2001 cadillac deville
2001 Cadillac Deville Car Radio Wiring Diagram
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Oct 13, 2009 | 2001 Cadillac DeVille
Car Audio & Video Logo
20 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
