Question about Lavelle Industries Korky& Universal Toilet Repair Kit
I have a korky 528 anti-siphon valve on a swiming pool. I would like to know how to adjust the water to a lower level as it is a little too high for proper skimming of the pool. Thanks. Russ Myers
  • frank addvensky Aug 30, 2013
    Gary- I too have a similar problem as Russ. However, your answer refers to a toilet. It looks like his pool builder and my pool builder installed the Korky 528. How do we adjust for less or more water into the pool---thanks, Frank
2 Suggested Answers
aquaman987
  • 927 Answers
SOURCE: korky anti siphon 528 is
If the water is reaching the tank overflow tube, the float valve is not stopping it fully. If the valve is new or not too old and you have instructions or know how to disassemble it, you can flush it to ensure there is no debris in the valve or on the seat. Although the manufacturers recommend this, I have never found anything on the seat.
If you can't do this, a new float valve assembly must be installed.
Gary
Posted on Feb 26, 2011
Pool overfilled, I thought because of rain. This wknd I backwash drained it to the proper level. 2 days later it was overfilled again...no rain. I don't know, but think I have an auto fill.
look for a smaller cover and open it up until you find something that looks like this one or even one that could look like a toilet fill... I've seen it. Thats the auto fill and they're relatively cheap, but to save you some money look for a little outlet (1-2" hole) in the pool right near the auto fill and plug it up with a rag. if water starts coming from the top of the fill area then it could be the filler or the fitting it connects to. Once you've determined if its the auto fill then shut the water off, most times it can be shut off with the landscaping but not always, you might need to shut off the water supply for a bit. then it just counter-clock screw out put in the new one and play with the levels you want it at. DONE!
http://www.amazon.com/Water-Leveler-Valve-Restrictor-Fountains/dp/B005SVW4UU
http://www.amazon.com/Korky-528-Quiet-Toilet-Valve/dp/B00002N6MY/ref=sr_1_2?ie=UTF8&qid=1448043014&sr=8-2&keywords=leveler+fill+valve
Nov 12, 2015 | Hayward Pool & Spa
Can i change spider gasket while pool is full
In most cases, Yes!
All depends on water levels in relation to Grade of equipment to water surface level!
If filter valve is lower than level of pool surface water level, hopefully you have isolation / shut off valves before and after equipment? If you don't then answer to your question is no.
If you do have valves and when those valves are closed, then answer to your question is yes.
Answer is also yes, if pool water level is lower than filter valve.
May 13, 2015 | Pool & Spa
Korky anti-siphon. Tank water slowly drops, accompanied by a hissing sound. Then, after dropping about 1/2 inch, it refills. Wha?
either the fill valve is running and water is draining into the bowl via the overflow tube in the tank or the flapper is bad (or foreign matter) and it is allowing water to escape into the bowl slowly...causing the fill valve to run every few minutes or so. hope this helps but if you need anything else just text me here:)
Jul 29, 2011 | Lavelle Industries Korky& Universal Toilet...
Since I replaced the insides of my toilet with the fluidmaster 400 anti siphon, the water seems to no refill the tank after I flush the toilet.
You are going to have to adjust the valve you just installed. Most can be adjusted by pulling a ring close to the bottom upward and pulling the neck of the valve up, in turn adjusting the water level in the tank. There should be instructions in the box on how to raise the water level.
Jun 21, 2011 | Home
Korky anti siphon 528 is leaking, water is high and leaking in drain pipe
Gary
Feb 26, 2011 | Lavelle Industries Korky& Universal Toilet...
Water seems to keep running very slowly, can't hear it, after it apparently stops after a flush. Eventually reaching the over flow tube in the tank. I have replaced the Toilet fill valve twice, The first...
Rossouw R. im a plumber.
Were the flexi hose go in to the toilet and conect up to velve thread tape. unscrew the flexi hose and then the plastick nut holding the velve on to the sistern.
put the new velve in and bobs ur uncel.
Its very easy, just look were the 2 seal rubbers are when u remove it, may be 1 rubber.
and the flout of the velve will be a cup or ball, thast ajast that tothe right water level, u will c were the flout or ball is on new velve there will be plastick with bumps un it [most commen] if not let me know bt around that area u should find somting to adjust the hight. sorry for spelling errors, im a plumber nt a english major lol
plz let me know if u get in a rut .that is realy the onley solution.
Jun 11, 2010 | RTO Fillpro Anti-Siphon Toilet Tank Fill...
Washer appears to be leaking towards the top back right..
sounds like your main tub seal is leaking, also check the hose running to your water level switch,,and your outter plastic tub could have a crack in it
Feb 15, 2010 | GE WBSR3140DW Top Load Washer
How do I lower the water level in my pool? Show a diagram, so I can see what values I need to turn and adjust. My pool has a float mechanism and a drain fuction at the main control panel but I am not sure...
Their is no valve to turn the float valve need's to be lowered. If the level has been good and has just started to run high you may need to replace the float valve. At your house you will find a pipe coming off one of your hose bib's and running into the ground. This will be the pipe that has a valve to shut the leavler off.
Jan 21, 2010 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Gmax flushing system won't stop
WATER LEVEL IS NOT PROPERLY ADJUSTED. REDUCE WATER LEVEL TO FILL LINE
Jan 07, 2010 | Toto Drake Tank W/GMAX RH COTTON WHITE...
Kohler two peice toilet the water just circles and will not flush.there is plenty of water in holding tank that run through
These models need to have a flush valve flapper that has a styrofoam float on the lift chaninof the flapper. Go to hardware store or home improvement store and get a 'Korky brand toilet tank flapper with float 'ball". Cut the rubber ring piece away from the flapper and you don't need it (see cut here marks on flapper). Install flapper and adjust the float fairly close to the flapper.
When the water level drops in the tank and reaches the level of the float on the opne flapper, the flapper quickly closes causing the toilet to have a "surge" of siphon action which forces the water in the bowl to be drawn out.
Jun 29, 2009 | Kohler K-3422 - Wellworth Elongated...
Lavelle Industries Korky& Universal Toilet Repair Kit  Logo
2,244 people viewed this question
Top Lavelle Industries Home Experts
Donni Steen
Tom Chichester
Are you a Lavelle Industries Home Expert? Answer questions, earn points and help others
